Techman
Everything posted by Techman
  1. Even though the Zwave/Matter board is Zwave LR certified it appears that the current software doesn't support LR. I have an open ticket and should know more next week and will post the results
  2. Techman replied to danncas's topic in eisy
    It's possible that your Insteon mesh network is marginal, or that you have noise on your powerline that's interfering with the Insteon signals . How many dual band devices do you have in your system. If everything was working prior to moving over to the eisy try doing a restore device on the insteon devices that aren't working properly.
  3. If the PLM was linked to another Hub then you will might have to factory reset it as the PLM contains the link tables of the previous hub and may not be compatible with the eisy Do you currently have a working, and populated eisy? The replace PLM instructions are attached. Replace PLM Procedure (EISY or POLISY).pdf
  4. @NewB Scenes reside in the PLM and the devices. You could disconnect the ISY and the scenes will still work. It's possible that when you initially restored the new PLM the scene's links got corrupted. Take a scene that isn't working and do a restore device for each device in that scene. If that corrects the problem then you'll have to do it for each scene that isn't working correctly. If that doesn't correct the problem then you'll have to rebuild the scene
  5. @NewB Assuming you have the ISY994, here is the replace PLM procedure Replace PLM (ISY994).pdf
  6. Techman posted a topic in UD Mobile
    @Javi Just updated to UDM to 1.5.10 on android. I'm now getting the following error every time I synchronize. This wasn't the case with the previous version>
  7. Techman replied to bmercier's topic in eisy-ui
    Just upgraded to 1.0.2, All is good Thank you
  8. ¿Funcionaba tu eisy R2 después de migrar desde el ISY? Si su único problema es conectar el EISY R2 a Internet, el problema podría estar en el cable Ethernet o en su router. ¿Has probado a desconectar la alimentación del EISY R2 y luego reiniciarlo? ¿Puede comunicarse en inglés?
  9. Techman replied to bmercier's topic in eisy-ui
    @bmercier I did an upgrade packages (twice) and I'm still on 1.0.1_2 UPDATE: I've tried several more updates and reboots, I'm still stuck on 1.0.1_2
  10. When you swapped out the PLM did you follow the atached procedure ? Replace PLM Procedure (EISY or POLISY).pdf
  11. Techman replied to bmercier's topic in eisy-ui
    Under select tool, when I select eisy-ui I get the following: File not found: eisy-ui-1.0.1-2/index.html
  12. The UDI Zwave/Matter/Zigbee board is Zwave LR certified however the current eisy/polisy firmware appears not to support Zwave LR, only Zwave mesh The following is from the web: To include a Z-Wave Long Range (LR) device without using mesh, ensure your controller (700/800 series) has firmware that supports LR, set the controller region to "US-LR", and use SmartStart (scanning the QR code) to provision the device, specifically selecting the "Long Range" protocol instead of mesh. LR devices communicate directly with the hub, bypassing mesh routing.
  13. Found this on the web: SmartStart Requirement: Z-Wave LR requires inclusion via SmartStart (scanning a QR code). If you added the device using the "classic" manual pairing method (pressing a button on the device), it was almost certainly added as a standard Mesh node.
  14. To use Zwave LR the device must be included with S2 AUTHENTICATED security enabled. Unfortunately I haven't found a way to determine if a device was installed as Mesh or LR as the include process doesn't appear to offer that option
  15. If a program doesn't have an IF clause then the THEN clause will always run
  16. Techman replied to Techman's topic in eisy
    My PG3 dashboard shows 6.0.5
  17. Techman posted a topic in eisy
    Update from 6.0.4 to 6.0.5 went smoothly. No issues.
  18. If you are referring to the number after the plugin name, i.e. ELK(2), that's the slot that the plugin is installed in.
  19. Techman replied to RKenny02's topic in eisy
    Under the Configuration tab make sure the "Insteon Support" box is checked
  20. Techman replied to danncas's topic in eisy
    Scroll down to the bottom of the file which has the setup info GitHub - Panda88CO/udi-Blink: Blink Node Server fir udi · GitHub Once you have completed the setup, synchronize UD Mobile which will add the node server
  21. Did you clear your java cache checking all 3 boxes, and download the IoX Launcher from here: https://isy.universal-devices.com/start.jnlp In the admin console, under "Files", do a "Restore Devices"
  22. Eisy-ui loads when you open admin console. By using https://eisy.local:8443/desc you bypass eisy-ui. Probably a bug that needs to be fixed. When you type in https://eisy.local:8443/desc into the admin console click on save so it will be there next time you open the console.
  23. Admin console isn't designed to to be left on for extended periods. It's probably timing out
  24. Try to rename or modify the the customization, if successful then try to delete it.
  25. Probably best to open a support ticket
