Techman
Everything posted by Techman
  1. There are new firmware updates just released that address the PG3 issues
  2. What is your current ISY firmware version
  3. Techman posted a topic in eisy-ui
    Once you've migrated to eisy-ui be sure to create a backup system .> backup and restore It's also a good idea to create a backup anytime you've added devices, programs, etc.
  4. That feature is currently not available in eisy-ui. Hopefully it will be included in a future update
  5. It could be due to a noisy transformer, after 10 years things can fail Did moving the PLM resolve your problem?
  6. Did you do a Synchronize in UD Mobile after the migration
  7. Can you expand on what didn't migrate. Do all your Insteon devices show up and work in eisy-ui
  8. Are the failed devices battery powered
  9. @KYnewbie Probably noise/interferrence on the powerline. Take a look at this troubleshooting article INSTEON: Troubleshooting Communications Errors - Universal Devices, Inc. Wiki
  10. Have you tried doing a power cycle on the eisy
  11. I noticed that you have pending writes for Z09, are there any other pending writes for your Zwave devices. You should clear up all of the pending writes You have some of your programs disabled which may be preventing the display of all the device nodes.
  12. Most likely coming in a future eisy-ui release. eisy-ui is a work in progress
  13. have you tried rebooting eisy
  14. Do a power cycle, that should clear things up Let me know if the memory usage went down
  15. If you don't need Zigbee the Zooz Zwave 800LR dongle works out of the box, no issues, with eisy.
  16. Currently the only options are on and off.
  17. @Gogamer4 From UDI- If you're on an older firmware, you may already see an early version of eisy-ui — but it may be missing key features, including backup. Upgrading to IoX 6.1.1 is required to use eisy-ui for day-to-day management. For the next few weeks, keep Admin Console available for anything not yet in the browser — but check back often, as updates are moving quickly. If you're feeling adventurous, a beta build may already have what you need. If you're currently on a version lower than 6.0.0, please open a support ticket for personalized upgrade instructions before proceeding
  18. @dwengrovitz I'm runing 1.3.11_1 and i'm able to view both the device and PLM link tables in eisy-ui Did you try rebooting the eisy
  19. @bmercier The migrated bluetooth plugin in eisy-ui is showing a 0 or 1 for status. It should show Paired or Unpaired A reboot didn't resolve it.
  20. Thanks, I missed that, have to clean my glasses
  21. How does one enable a disabled program in eisy-ui Clicking on the disable icon did nothing, I don't see any other options
  22. If you DON'T use Zwave or if you have the 500 series Zwave dongle then this is the firmware to use (1) ISY 994i Series including Z-Wave support' The #2 option is for systems that don't use a PLM
  23. I'm on windows 11 with edge browser, I don't have the blue line issue or the search issue in 1.3.11
  24. Not sure about the Polisy, but for the eisy you first have to backup the zwve/zmatter dongle, then remove power and remove the zmatter dongle. Plug in the aerotec dongle and do a restore zwave/matter. If you don't have a backup of your zmatter dongle then you'll have to rebuild the zwave/matter from scratch.
  25. Even though it doesn't say to reboot it's probably a good idea to reboot after the update has completed
