  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
atmarosi
Everything posted by atmarosi
  1. Nice sleuthing! Keep us posted - I'm sure there are some lurkers that can benefit!
  2. 401 = auth error; did you take a look here? Eisy:User Guide - Universal Devices, Inc. Wiki I don't have an eisy - i'm stuck on Polisy but from what I understand the eisy-ui changes things up a bit....assuming you did the upgrade of course.
  3. From the spec sheet - FilterLinc 1626-10 NOTE: FilterLinc should be installed between the offending device (noise-maker or signal-absorbing appliance) and your home's AC outlet. Another great post: Where to put the noise filter? - ISY994 - Universal Devices Forum
  4. You have to 'backup' aka export the config; and then restore it on the new device. They don't back up to iCloud natively like others are doing.
  5. REST API network based calls to devices would be another way. The UDI device would do all the Insteon comms.
  6. Can't say I've worked with the remote before - but you'll need to figure out how build the API call with the token/auth; someone built something similar for HomeAssistant:
  7. You would want to send REST API calls from the Sofabaton to the UD side: ISY Developers:API:REST Interface - Universal Devices, Inc. Wiki Wiki has a great write up on how to use the REST API it has available.
  8. You could have the program capture/write out the current level in a variable; turn them off; then turn them back on via the stored state - can't say I would know how to write it but sounds do-able...
  9. If you turn off/on the light does it go back to it's prior setting right now? If so it should do the same thing if you off/on the lights via a program.
  10. According to the python library that the PG node uses - this model + FW combo you have (HS200 HW 5.26/FW 1.0.3) requires auth.... You may need to do something extra in the config of the device/node server to get it to talk to it...seems like this post has mentioned a beta version that might fix it:
  11. Here is an idea: https://www.reddit.com/r/Soundbars/s/ynm3ScQKwZ
  12. What about like this? Open the Apple TV Go to Settings Remotes and Devices Control TVs and Receivers Click it to turn it off
  13. Canโ€™t you turn off CEC in the Apple tv?
  14. I would try turning off any stateful inspection you might have for the EISY via the PAN (Palo Alto). We're a PAN shop at work - and I know it will scrutinize traffic very much and sometimes tooo much. Since it's is unable to reach the internet it likely doesn't send the traffic out to the portal (guessing). So that would explain why when it's unable to ping the internet it stops trying to connect to the portal and not showing any traffic as well. Since you can't reach the internet from the EISY - it obviously won't reach the UD Portal. Assuming you don't have similar issues with other devices on the network I would see how the traffic is any different - different rules? Different path? etc. I'm leaning towards the PAN getting in the way....
  15. Maybe ssh into said eisy and run a ping out to the UD portal and see if maybe the path that itโ€™s taking is troubled? Is the eisy connected to a different switch maybe or AP than your phone or other things?
  16. https://shop.insteon.com/products/led-flicker-glow-eliminator?srsltid=AfmBOopOitXjjLRMMOtmR6bSOykiQ4h5NGuyzQY4OngE1IH9zowHPqHB try these
  17. atmarosi replied to BRMeeke's topic in IoX Support
    Instructions seem to be using the same reset button: Further I don't see any mention of any other orifice:
  18. atmarosi replied to BRMeeke's topic in IoX Support
    Are you still on a ISY994? Resetting Your ISY - Universal Devices, Inc. Wiki As long as you don't hit the 30second factory reset I don't see how you would...
  19. atmarosi replied to BRMeeke's topic in IoX Support
    Check this? https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Resetting_Your_Userid/Password
  20. Wired Polisy here. Upgrade went without issue. Took about 20 minutes.
  21. Motion sensors
  22. I would monitor the ping to the IR device and see if itโ€™s not happy with the new WiFi. If that shows signs of 100% reliability then look at the way the IoX device is reaching the device and see if you can setup a monitor by running a query to the global cache NS maybe and put a THEN to notify you of its failure? Might be able to use that to troubleshoot the WiFi link to the IR device.
  23. Wish I had something to suggest. If no one else does there is always a ticket with UDI.
  24. Tried a reboot of the EISY yet? ๐Ÿคž
  25. First for everything. Nice
  2. Tap Permissions โ†’ Notifications.
