ISY Cert Renewal
memphis2k
Hello all,
ISY994i v5.0.16a and my cert is up for renewal.  Realized that I don't need a cert with portal, but still, I would like this figured out.  I took notes from when I installed the cert and now I can't get Dashboard to ask me to restart the ISY (its confirmation, according to the WIKI).
  • -Clicked No to start a fresh request for the CSR.
  • -Sent the CSR to my SSL company and got the renewal Cert back.
  • Clicked on Receive Cert. in Dashboard
  • -Pasted the renewal Cert.
  • -I said yes and added the other certs too (These should be the same as before)?
  • -Then nothing, no prompt, etc.  I have restarted the ISY a couple of times, Edge/Firefox still show the HTTPS web url as expiring in a couple of months.
  • Also tried deleting the original cert, and still the same results.
  • Also, each time I try something, i say "yes" to re-use the CSR.
Can anyone assist me at all?
The 4 files I have are:
isy.DOMAINNAME.com.crt (the renewal cert)
AAA_Cert_Services.crt (not sure what this is for)
Usertrust_RSA_Cert_Auth.crt
isy.DOMAINNAME.com.ca (Cert Authority)
Submitted a ticket with GoGetSSL and they said its 2048.
I just tried it
  • Clicked Server Cert.
  • "Yes"
  • Entered PW
  • Typed my email in the Email field (it was empty)
  • Clicked Receive Cert and pasted the contents of isy.domain.crt
  • Click OK
  • Clicked No to Importing the Immediate certs
  • And then nothing happens...
I just compared the CSR that I sent GoGetSSL and its still the same.
Java Web Start 11.261.2.12
Using JRE version 1.8.0_261-b12 Java HotSpot(TM) Client VM
JRE expiration date: 11/17/20 12:00 AM
console.user.home = C:\Users\Aaron
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to <n>
https://isy.universal-devices.com/994i/5.0.16C/dashboard.jar
https://isy.universal-devices.com/994i/5.0.16C/insteon.jar
https://isy.universal-devices.com/994i/5.0.16C/jxtt.jar
https://isy.universal-devices.com/994i/5.0.16C/bc.jar
https://isy.universal-devices.com/994i/5.0.16C/ce.jar
https://isy.universal-devices.com/994i/5.0.16C/chart.jar
I just turned on Java Console via Windows Control Panel options
Can I delete all of the Certs in ISY994i, reboot?  I just don't feel like it saves it when I tried deleting the main cert in the past.
On 9/3/2020 at 9:37 AM, Michel Kohanim said:
@memphis2k,
I suspect it's due to using 5.0.16 UI which might have an expired cert. Is it possible to upgrade to 5.2.0?
If you have a good backup, it's best to restore it rather than deleting files.
Updating to v5.2.0 made no difference.  Still doesn't register.
      38.1k
      379.9k
