Isy and elkrp 2
Hi
i am very new to this isy99 and elk m1 gold setup. I have had it for a while with no issues but lately I can not set up properly . After doing some changes on the elkrp setup I eventually connect but my alarm and lighting do not work. It seems like the IP address that the elk rp setup finds , changes . Would like to know if any Elk/ isy experts out there ,wouldn’t mind remotely logging in to my computer ( maybe via team viewer ) to check out my parameters . I know it is probably something small as it all was working a short time ago.
thank you
john
3 minutes ago, Jnacc said:
Hi
thank you
john
Are you using anELK-M1XEP? Do you have DHCP checked on the ethernet setup screen and have you made a reserved DHCP in your router to assign the same IP address to your Elk each time?
      378.7k
