Logging variables on demand
hart2hart
I’m writing an irrigation program that:
1. Store Flume Node server Today Gallons in variable Flume_Start
2. Turns on and off each zone
3. Store Flume Node server Today Gallons in variable Flume_End
4. Calculate difference _Start between _End into variable Water_Used
At this point, how can I log
DateTime, Start variable, End variable, Water_Used
Network resource to send it to a service?
Setup variables for each and write them at the start / end of a cycle. You probably want to use state variables.
s.start.date=${sys.date}
s.start.time=${sys.time}
s.start.variable=
etc
I'm not sure what you mean about a network resource to send to a service.
A long time ago, I started writing a node server to log data to Google Sheets... I lost.  ☹️     This is an area that's really lacking, it would be outstanding if we had a method to collect data for external analysis.
I might be missing something, but why would you want to use state variables?  If the variable needs to trigger an IF statement, i would understand the use of state variables, if its a just a counter/data collector why would a state variable be used?   I'm sure it's less important on speedier Polisy but back in the day that I was using state variables for everything and had 200+, I ran into problems on the 994. State variables do use more processing power than integer variables due to the fact they are triggers.
I think if the purpose is to log data in some way there are a number of ways to get there which might be tweaked depending on the task at hand.  saying this I do agree it would be really nice now that we have Polisy to just right click on a node or variable and 'turn on logging' which is put to some rolling text file.  This would be very cool.
  1. @MrBill a network push to IFTT, where they have a 'few' micro-aps to add to google sheets.
  2. a network push to an RPi (or any computer, just easy with linux and cheap with RPi) which would store a text file with a date stamp.
  3. if your use case is pretty stable then a node server which takes your data and sends to an MQTT and is pulled from there using one of the tools out there, or write your own with python.
I use NodeLink for logging.  You can log devices, programs and variables.  The log is written to every time there is a change.  I was tracking my heating system run time and use the log data in an excel file to do the calculations.  NodeLink is a node server but is not available on Polyglot.  I run in on a RPi.  It's also a great aid in debugging when programs are not doing what you want them to.
5 minutes ago, kzboray said:
@simplextech If you're feeling like migrating another NS. seems like there is a home for NodeLink Logging on PG3.
Interesting.  This gives me a thought that perhaps there should be a forum for Node Server requests?  @Geddy any thoughts on this?
@simplextech would you see this as a different place than the current "Product Requests" forum? I mean, it is "way down" in the Site Comments area of the forums, but I'd see that as the best place to post specific requests.
I know others have been posting in the PG2 node server section asking if developers are going to be releasing a PG3 version if there isn't already one.
But I'm thinking the existing "Product Request" forum would be where I'd suggest posting NS requests.
Sounds good to me.
  • Thanks 1
I'm not currently using this technique, but it worked well in the past.
https://wiki.universal-devices.com/index.php?title=ISY-994i_Series_INSTEON:Networking#Dynamic.2FCustom_Page_Creation
I created a csv file and appended data to it as necessary, making it more useful than a simple log file.  I haven't tried this on Polisy, however.
Perfect!  As a temporary solution, I had setup an email notification and was collecting data in an email account so just had to add text to subject for file name and to append.
It took me a few minutes to figure out how to add newline.  Given it's unix/linux , I assumed it was some combo of \n\r.  Turned out to be a simple hitting return in the body of the message. LOL
@MrBill's idea of having a node server log to Google Sheets is something I've been hoping would happen for a while (I requested it a couple of years ago).  I was successful in logging to GS with Network Resources and IFTTT, but it was cumbersome.  While at it, it would be nice to go the other way - type a number in Google Sheets and have it write to a variable (I can do this with Rest; however, it then takes me to another webpage and I'd rather it stay right there.
I've looked at @Bumbershoot's CSV.  However, I couldn't figure out a way to "automatically" get the CSV to a Google Sheet so I can see it when I'm away from home.  Maybe there's a simple step that I'm missing.
I will make my requests under Product Requests per @Geddy's advice.
Edited by Ross
Fixed some grammar errors - I'm sure there's some I missed...
Hands down, this is the best way to do it.  It would only be better if it ran on polyglot.  I run it on a 24/7 pc and it works perfectly, but it could be run on rpi, if you can find one as they seem to be in short supply.  I use it to track temperature and humidity from Inteon thermostats as well as outside temp/humidity at my church.  I use that data to figure out algorithms for running the hvac system.  It saves the data as a csv file which open in excel or whatever spread sheet you want.  You can set it up to follow whichever variables you want.
      377.1k
