Zigbee - Device Support Requests
On 8/9/2023 at 12:28 PM, brians said:
FYI, Those both are not Zigbee, they are WiFi. The older FP1 is Zigbee but only was available direct from China. I have both: two FP2 and an FP1.
But regarding the ES1 - I have it.  It’s Zigbee.  I was able to connect it over Zigbee with the ZMatter dongle (but the only thing it did was print an error log that it’s not compatible yet).
Installed new Third Reality Zigbee motion on eisy.  One node and installed no problem.  Works great and cheap too ($16.99 on Amazon)  Ordered two more. https://a.co/d/f6I7sMb
The Zwave motions are an arm and a leg mainly as they put other features in them like Temp, Lux, etc.  These cheap just motion detector zigbee devices are the way to go if you dont need all the other stuff.
I am trying to add a HIMOSO wireless 4 button scene switch to my EISY zmatter.
I am IoX version 5.6.4
Model RSH-Zigbee-SC04
At amazon: HIMOJO Wireless Scene Switch,Zigbee Smart Light Switch,Free installation Remote Control Switch,Zigbee Tuya Connection,4Way Sticky Panel, Smart Wall Switch, Wireless Button for Smart Home Devices - Amazon.com
EISY sees all 4 buttons but it doesn't finish as it stops on interviewing with no progress.  Then times out.  Buttons do not work.
Edited by Paulywog57
More Info
GLEDOPTO 12W & 7W Led Garden Lamp
Model No: GL-G-101P
Gledopto
https://www.amazon.com/dp/B07T96FZBX?ref=ppx_yo2ov_dt_b_product_details&th=1
It was able to add it to the ISY but it says Unavailable.
Need Color Hue-Sat device   &    On / Off Switch device, the usual stuff for a color changing bulb
UPDATE:  This is working as of update 5.7.0 on 09/11/2023
Edited by BoydG
  • 3 weeks later...
Roller Shades
Manufacturer : Graywind
Model: Roller Shades with Zigbee Motor
Support Page https://www.graywindblinds.com/pages/contact
Commands requested "up", "down". "Favorite",
Status requested "battery low".
Sold on Amazon, Alexa Compliant, Alexa discovered and operated as soon as powered up in programming mode.
Amazon shows as yooksmart smart device, manufacturer says same as "IKEA" also.
eisy 5.7.0 w USB Zmatter finds them and lists them as "unavailable".
https://www.amazon.com/stores/page/FCD06F74-9BD9-470A-B117-07AF4C4218E4?ingress=2&visitId=4356e004-e963-4dfb-a403-c8724130777d&ref_=ast_bln
11/1/24 Update, IoX 5.8.4 sees all of them, and lists them as "Main". but when selected the options are identify and query, and nothing happens.
Edited by CoolToys
added yooksmart or IKEA and corrected "down"
Sinope TH1300ZB, TH1124ZB, TH1123ZB would be a good addon here!
https://sinopetech.com/en
These are: 1) floor heat thermostat, 2) 4000 and 3000 watt electric baseboard heat thermostats respectively
eisy 5.7.0 w USB Zmatter finds them and lists them as "unsupported work queue request 6 ignored"
Sinope also offers dimmers, switches, load controllers, water detectors and other elements in either Zigbee or Wi-Fi
Edited by glarsen
Any Zigbee human presence sensor, preferably Tuya device as there a lots of them available!  I've got a HAOZEE Sensor from Ali Express
https://www.aliexpress.us/item/3256805765649725.html?spm=a2g0o.order_list.order_list_main.23.19fd1802hrsD37&gatewayAdapt=glo2usa
Loginovo sensor
https://www.aliexpress.us/item/3256805291297545.html?pdp_npi=4%40pre!!US %2428.74!US %2413.22!US %2413.22!!207.96!102.02!%40210313e916994709671554017e092d!12000033255721585!sh!US!4313580587!&spm=a2g0o.store_pc_aeChoiceSimplified.allitems_choice_2005294756320.0&gatewayAdapt=glo2usa
Wenzhi sensor
https://www.aliexpress.us/item/3256804518651916.html?spm=a2g0o.order_list.order_list_main.11.19fd1802hrsD37&gatewayAdapt=glo2usa
I think a lot of these you can find on Amazon as well.  These are available in both wireless and Zigbee.  I'd be ok with another brand as long as it is Zigbee and a human presence sensor.  I'd like for the Zmatter dongle act as the hub so I can eliminate the cloud connection and another hub running in my house!
Another power plug device. I bought these in 2022 but I think they're "current," FWIW. I had a couple unused in the drawer and had to replace a failed Z-wave plug today.
Brand Name: Seedan
Model # YT-m010 (some discussion that this is the same as "eWeLink SA-003-Zigbee" but I'm uncertain).
https://www.amazon.com/gp/product/B08LD7Q81J
Edited by Riggins44
  • 3 weeks later...
What can help the @Administrator group? I have it paired, it just doesn't have any updates / data.
X-ray details from IoX available if helpful.
Edited by residualimages
  • 3 weeks later...
  • 4 weeks later...
Does anyone know if this thermometer works with Polisy/EISY?
SONOFF LCD Zigbee Temperature and Humidity Sensor SNZB-02D, Requires SONOFF ZigBee 3.0 Hub, for Remote Monitoring and Home Automation, Works with Alexa/Google Home
@Michel Kohanim is there a supported device list so we can check first before asking?
Also if a device isn't supported is there any expectation that it will be?
http://tinyurl.com/557sdxxa
Edited by mmb
Question for Michel
I'll answer my own question - No.
Going back to Amazon.
Edited by mmb
MonaLisa Arduino Shield and Battery Powered Standalone for remote/probe-based temperature sensing (among other things)
He sells on Ebay; use "MonaLisa Zigbee" as a search term.
Arduino Shield-based:
https://www.ebay.com/itm/285029073913
Standalone Battery Powered:
https://www.ebay.com/itm/284992778034
Google Doc Manual:
https://docs.google.com/document/d/1YbGH5Dl3OhkTz4v1ul0Xy4Tzc7oBAwip61Rvk_t6WTA/edit#heading=h.w5x22opo2rza
Thread about its creation/drivers here:
https://community.hubitat.com/t/battery-powered-monalisa-firmware-for-makers-and-custom-devices/69674
Edited by chadm
Added images
  • 4 weeks later...
Working to get the BTF-Lighting Zigbee controller running.  It's working for on/off and Hue/Saturation (RGB), but there seems to be no way to get the CCT (CW/WW) white colors working. Maybe an easy addition?
https://www.amazon.com/dp/B0B2JR1DXZ
(Let me know if this should be posted elsewhere!)
-Mike
Yolink has 1 that works with EISY. You need a Yolink hub and the Yolink PG3 Plugin.  I am using the thermometer and 6 water sensors.  All work great and have problems with developing programs to interface with the devices.  Many other devices are also available.
Please include support for Somfy Zigbee Shade Motors.
MOES
ZS-B-US2-WH-MS
https://www.amazon.com/gp/product/B0C4XWW87F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
On/Off for each switch.
EISY does add but as a single node.  Toggling only one of the 2 switches is seen in Admin Console.  Nothing for the second switch.  Toggling the on and off from the AC causes both switches to toggle.  The device is available as 1, 2, 3 or 4 switches.
Sengled Zigbee BR30/E26 Bulbs
Model: E12-N1E
2700K - 6500K
While I can control RGB colors, I haven't been able to figure out how to control the white 2700K - 6500K?
Bulbs first turned on with a nice warm white, but since adding into eisy, I haven't been able to duplicate that warm white color? The description indicates temperature of light bulb is changeable 2700K - 6500K. Is there something I'm missing or is the feature not available? Thanks!!!
https://www.amazon.com/gp/product/B08R5FWMCW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
https://us.sengled.com/products/zigbee-color-br30-e26-2-packs-hub-required?_pos=3&_psq=br30&_ss=e&_v=1.0
Edited by jpoje
added model number
