POLISY = EISY?
Go to solution Solved by Geddy,
I know I asked this before, and was told if I have a polisy there really is no reason for me to upgrade to the EISY
its been a while, but i wanted to confirm with the brain trust here. any reason I'd want to use EISY instead?
also I am noting that my POLISY /ISY has a newer firmware avaiable: 5.8.3
i am on 5.7.1 pg3-3.1.23_1
when I try to update, it goes through the process and then nothing happens. its the same.
Ive tried through the UD app, my.isy.io page and the IOX java app. nada.
THoughts?
Alex
On 7/20/2024 at 9:07 PM, Techman said:
If the Polisy is working there's really no advantage in upgarding to the eisy at this time.
There is a looming EOL for Polisy.
I seem to remember support was suppose to be 5 years which started several years or more ago.
I really don't feel like buying another ISY.
11 hours ago, alphapenguin said:
something doesnt seem to be working right.
https://polisy.local:8443/rest/pg3x.enable
it returns:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
I believe this is normal. You can find other conversion comments in the forums that seem to indicate this is expected. Make sure you follow the rest of the steps that @Techman linked to in the wiki. Pay attention that the user/pass will now be the same as admin console access.
Once you confirm you have PG3x then run the upgrade process again and you should update to IoX 5.8.4 (the current release)
If you did not get upgraded to PG3x in the process then please open a support ticket to get specific help for this issue.
https://www.universal-devices.com/my-tickets/
If I was running a Polisy I wouldn’t worry about upgrading to eisy until UD made an official announcement that they would end Polisy support/development. No need to worry about it at this moment. Also no major need (from why I can tell) to rush an upgrade to the eisy if you have a working Polisy doing what you need it to do.
2 reasons I moved from Polisy to eisy
1. Smaller package.  Space is at a premium in my SMC and I can get the eisy in it with a half width bracket instead of a full width bracket.
2. You can put VMs on it like Home Assistant.  Can't do this with Polisy.
54 minutes ago, Guy Lavoie said:
Quick question: do Polisy and Eisy run the same version of unix? Would the plugin development environment, paths, etc be the same?
Yes
15 hours ago, larryllix said:
Are they both still freeBSD O/S?
Yes.  They should be running the same version of all OS components.
However, the eisy does run a Linux VM specifically to control the wireless network card in the eisy. I believe that is because that specific network card is not supported by FreeBSD.
  • Thanks 1
      377k
