SSS Posted February 11 Posted February 11 6 minutes ago, Guy Lavoie said: That's right. Looks like initially, adding devices will only be done through the phone app. I also notice that there is no mention of the Zmatter dongle in the announcement: - Matter Initial support for light bulbs and plugin modules: -- WiFi direct. -- WiFi through a Border Router such as Google Nest Hub or Apple HomePod. -- Thread through a Border Router. Not sure if that means it will only be supported a bit later. Just now, SSS said: Cannot see on the UD mobile app as well Quote
macjeff Posted February 11 Posted February 11 16 hours ago, auger66 said: Followed the directions. After upgrade, my eisy was offline on the Portal, UD mobile, locally, etc. The eisy did show up on my network at the usual reserved DHCP address. Eisy also did not show up the ISY finder, even if I typed in the local IP address. I tried run ssh in windows and putty, but it wouldn't allow me to paste or type in a password. I repowered the eisy as felt I had no choice. My eisy showed up immediately in the ISY finder, and I was able to log in without issue. I have seen this in testing. Reported it but not much they can do. I think adding a second reboot may be necessary to instructions. Quote
Goose66 Posted February 11 Posted February 11 Updated and IoX (via Admin Console) and PG3 all appear to be working correctly. However, now UD Mobile cannot connect to the controller. Just says "Attempting Connection" in the header, and if I attempt to manually synchronize I get a "Error: Could not finish Synchronization. The request timed out." error. Tried shutting down and restarting UD Mobile on my iPhone. Quote
Guy Lavoie Posted February 11 Posted February 11 1 minute ago, Goose66 said: Updated and IoX (via Admin Console) and PG3 all appear to be working correctly. However, now UD Mobile cannot connect to the controller. Just says "Attempting Connection" in the header, and if I attempt to manually synchronize I get a "Error: Could not finish Synchronization. The request timed out." error. Tried shutting down and restarting UD Mobile on my iPhone. I just updated UD mobile (android version, dated Feb 10) and it connects ok to both updated Polisy and not updated eisy. Now shows option to add Matter devices using QR codes. I haven't found anything about defining Matter routers or accesses. Quote
SSS Posted February 11 Posted February 11 2 minutes ago, Guy Lavoie said: I just updated UD mobile (android version, dated Feb 10) and it connects ok to both updated Polisy and not updated eisy. Now shows option to add Matter devices using QR codes. I haven't found anything about defining Matter routers or accesses. I am on iPhone…cannot see add Matter Quote
Goose66 Posted February 11 Posted February 11 @Guy Lavoie Do you have your local connection set to an IP address or hostname, e.g., "polisy.local?" Quote
Guy Lavoie Posted February 11 Posted February 11 (edited) 8 minutes ago, SSS said: I am on iPhone…cannot see add Matter Did you just get an updated version of UD mobile? Another user upgraded his iPhone, and can't connect to the controller. the Matter Add option appears in the settings (gear icon in the lower right corner, at least it does in the android version) 6 minutes ago, Goose66 said: @Guy Lavoie Do you have your local connection set to an IP address or hostname, e.g., "polisy.local?" No, I have the actual IP address instead. This might be the same problem as "ssh admin@polisy.local" not working, but "ssh admin@<ip address>" works. Edited February 11 by Guy Lavoie 1 Quote
Goose66 Posted February 11 Posted February 11 (edited) Yes, it appears that the updated Polisy (5.9.1) will no longer respond on the network to "polisy.local", but my non-updated Test-Polisy (5.8.4) still responds to "test-polisy.local". Are you saying they know about this problem? EDIT: non-updated eisy still responds to "eisy.local". Edited February 11 by Goose66 Quote
Guy Lavoie Posted February 11 Posted February 11 2 minutes ago, Goose66 said: Yes, it appears that the updated Polisy (5.9.1) will no longer respond on the network to "polisy.local", but my non-updated Test-Polisy (5.8.4) still responds to "test-polisy.local". Are you saying they know about this problem? Several others have experiences the same problem. I'm not sure if "they" know about it. I haven't reported it as a failure, since the workaround is quite easy. I preferred letting the more experienced users and admins interact with the folks at UDI. I'm still kinda new here. Quote
Goose66 Posted February 11 Posted February 11 I will log it. I know getting mDNS to work in the first place came in fits and starts. Could just be a missed configuration setting in the updated package. Also could be something that works fine on eisy but not on Polisy. I will upgrade my eisy next. 2 Quote
bgrubb1 Posted February 11 Posted February 11 Update appears to have bricked my Polisy. Restored on to an Eisy. All good again 1 Quote
mmb Posted February 11 Posted February 11 52 minutes ago, bgrubb1 said: Update appears to have bricked my Polisy. Restored on to an Eisy. All good again Interesting, that’s the second bricked Polisy. Anyone with a Polisy that updated properly? Quote
GHenry Posted February 11 Posted February 11 In order to get the Matter menu, you can Go to Configuration/System Select "on" from the Matter pop-up menu Press the Save button in the lower right corner Restart IoX (or reboot if that doesn't do it) But bear in mind (a) Matter support is alpha software and (b) HTML browser-based interface is coming. Quote
Traditore Posted February 11 Posted February 11 23 minutes ago, mmb said: Interesting, that’s the second bricked Polisy. Anyone with a Polisy that updated properly? My Polisy upgraded to 5.9.1 just fine. Admin console works. UD mobile too. 1 Quote
Guy Lavoie Posted February 11 Posted February 11 3 minutes ago, Traditore said: My Polisy upgraded to 5.9.1 just fine. Admin console works. UD mobile too. Same here. It previously was running 5.8.4. Doesn't have much on it, but does have the development files. 1 Quote
Goose66 Posted February 11 Posted February 11 (edited) 32 minutes ago, mmb said: Interesting, that’s the second bricked Polisy. Anyone with a Polisy that updated properly? My Polisy upgraded fine except for it stopped responding to polisy.local. But everything else went smoothly. PG3x and all the plugins seem to work fine as well. Edited February 11 by Goose66 1 Quote
pjjameso Posted February 11 Posted February 11 (edited) Well count me in as to a possibly bricked Polisy. Watched the upgrade on mobile app complete to 100%. Unable to reboot via 5 button presses so pulled the plug but not no beeps only far left light is on. Any thoughts on what to try at this point? Probably the quickest fix is to buy an Eisy! Edited February 11 by pjjameso 1 Quote
Guy Lavoie Posted February 11 Posted February 11 Can you ping it? Someone else reported a similar outcome but could still ping it. If so, then it's possibly recoverable. Quote
dbwarner5 Posted February 11 Posted February 11 Just upgraded Eisy w/o any problems. Had to check Matter, Hit Save and reboot IoX for it show in AC top menu. Everything working as expected so far. Thanks @Michel Kohanim and team! Quote
pjjameso Posted February 11 Posted February 11 Router shows online, and I can ping. Ioxfinder shows it but version is blank. Quote
Techman Posted February 11 Posted February 11 @pjjameso Try clearing your java cache and reloading the IoX Launcher. Also try rebooting your eisy/polisy Quote
GTench Posted February 11 Posted February 11 Upgraded eisy without any issues. Everything is working well. I liked the status updates from UD Mobile. Good work guys. Gary Quote
Ryan S Posted February 11 Posted February 11 Updated my Polisy to 5.9.1 and OS 14.1p6 with no issues. You just have to be really patient. It took mine 32 minutes to complete. Quote
GHenry Posted February 11 Posted February 11 My eisy is on wired Ethernet, so it went lickety-split. In fact, I was surprised at how fast it updated. Quote
dwengrovitz Posted February 11 Posted February 11 Is any information available on how to setup or configure eisy to control Matter devices? I've enabled it via the Admin Console and can see "Matter" in the menubar, but I'm not quite sure how to go about adding devices. Also - does the network connection from eisy need to be WiFi to work with Matter, or can I continue to use a wired network connection? Quote
