June 21Jun 21 I just downloaded latest version of UD mobile on iOS. I’m getting many errors on sync. It had been great until this version.No control even for Insteon devices I can’t select all the errors but here is a screen shot from top Edited June 21Jun 21 by hart2hart
June 21Jun 21 Update:To fix this issue synchronize over cell (not wifi) OR remove the UD Mobile Local Connection settings. Remove Local Connection Settings from Home Tab > Controller Settings. Disregard any requests to synchronize. Scroll down to Local Connection Settings then and Expand the Settings. Remove the Local IP Address and then remove any Local Networks from the System Network Relations section by pressing the trash icon next to the setting. Finally Save at the top right.The issue does not require cell service, only that the syntonization is done through Portal. So temporarily removing the local connection from UD Mobile settings will fix, UDM will still uses your home Wifi. The alternate method is to do synhronizaton on cell service which forces a remote connection as not on WiFi.The cause:There were recent changes to iOS (OS) which caused significant hanging in remote sync, part of this was due to UDM trying to catch a firmware bug during synchronization which I thought was fixed years ago but the workaround remained so was no one noticed it was not fixed. When the catch was removed to fix the remote synchronization hang, We noticed the issue was never fixed in firmware. A fix will be in the next firmware version, however because most of our users use the remote sync, it is preferred to not revert the workaround in UDM as sync would hang for most users as they use remote.
June 22Jun 22 Author On 6/21/2026 at 12:10 PM, Javi said:Try rebooting eisy. These are network errors.Reboot and same result on synchronization. I’ve also fully removed the app and added back including restore favorites. Tested both local and remote connection from app with success.
June 22Jun 22 13 minutes ago, hart2hart said:Reboot and same result on synchronization. I’ve also fully removed the app and added back including restore favorites. Tested both local and remote connection from app with success."with success" or without?If without please open a ticket, I can't replicate and no other reports.
June 22Jun 22 Author 11 minutes ago, Javi said:"with success" or without?If without please open a ticket, I can't replicate and no other reports.With success. I’ll open a ticket.
June 22Jun 22 We had another report, I could not replicate on the remote connection, but did replicate on my controller using the local connection. Looking into the issue now.Temporary solution is to remove the local connection settings or synchronize on cell connection.
June 22Jun 22 3 hours ago, Javi said:Temporary solution is to remove the local connection settings or synchronize on cell connection.This is great! This worked and resolved the problem. I didn't open a ticket, but sent feedback through ios beta process. It had screen shots attached, but had same issues as @hart2hart. What's odd is even on cell the sync "finds" over 200 values to clear or backup. I don't have anywhere near that many devices or variables for it to consider removing. It's "funky" (yes...that's about as technical as I can get). Thanks for looking into it.
June 23Jun 23 Same kind of problems here syncing. UDM 4.45.24, isy-6.0.5_10Think I'll wait for the permanent solution before syncing via cell service. Edited June 24Jun 24 by wrj0
June 23Jun 23 Will be fixed in next firmware update 966b1b.This is a networking error/bug when requesting Node Server Profiles. Portal Server is catching the issue, app was also caching the issue in the past but this caused slow synchronizations due to iOS not allowing connection-close header.
June 23Jun 23 Author 27 minutes ago, Javi said:Will be fixed in next firmware update 966b1b.This is a networking error/bug when requesting Node Server Profiles. Portal Server is catching the issue, app was also caching the issue in the past but this caused slow synchronizations due to iOS not allowing connection-close header.Thank you. So sorry I’m clear, the fix will be in eISY update — correct?I have great cell service and sync goes very quickly.
June 24Jun 24 On 6/23/2026 at 4:33 PM, hart2hart said:Thank you. So sorry I’m clear, the fix will be in eISY update — correct?I have great cell service and sync goes very quickly.Yes
July 20Jul 20 Have been having hte same problem. Have tried everything from new app, older backups etc. Have >50 errors, favorites not syncing etc. Unfortunately I dont have good cell service here to sync with but will try that next time I do. When will the EISY update occur?
July 20Jul 20 2 minutes ago, dbwarner5 said:Have been having hte same problem. Have tried everything from new app, older backups etc. Have >50 errors, favorites not syncing etc.Unfortunately I dont have good cell service here to sync with but will try that next time I do.When will the EISY update occur?No need for cell service, it just needs to go through portal. Delete the local IP Address until the next firmware update.
July 23Jul 23 On 7/20/2026 at 6:52 PM, Javi said:No need for cell service, it just needs to go through portal. Delete the local IP Address until the next firmware update.Was able to get cell service, and did a sync, so am up and running again. Local connection is working fine. thanks.
July 23Jul 23 I think I just ran into the same problem - at home on wifi, did a sync. Half of my favorites disappeared and if I go to devices under the Home tab it will show the devices but I can't control them.Do I need to drop wifi and re-sync using cellular?UD Mobile 4.4.25, IoX 5.9.1Update...Rebooted controller, turned off wifi, and synchronized. Favorites are still missing but I regained control over my devices. Edited July 23Jul 23 by peterathans
July 23Jul 23 The app should have prompted to backup before removal, if you did restore the backup.The issue does not require cell service, only that the syntonization is done through Portal. So temporarily removing the local connection from UD Mobile settings will fix, UDM will still uses your home Wifi. The alternate method is to do on cell service which forces a remote connection as not on WiFi.The cause:There were recent changes to iOS (OS) which caused significant hanging in remote sync, part of this was due to UDM trying to catch a firmware bug during synchronization which I thought was fixed years ago but the workaround remained so was no one noticed it was not fixed. When the catch was removed to fix the remote synchonization hang, We noticed the issue was never fixed in firmware. A fix will be in the next firmware version, however because most of our users use the remote sync, it is preferred to not revert the workaround in UDM as sync would hang for most users as they use remote.
July 23Jul 23 Author 28 minutes ago, Javi said:The app should have prompted to backup before removal, if you did restore the backup.The issue does not require cell service, only that the syntonization is done through Portal. So temporarily removing the local connection from UD Mobile settings will fix, UDM will still uses your home Wifi. The alternate method is to do on cell service which forces a remote connection as not on WiFi.The cause:There were recent changes to iOS (OS) which caused significant hanging in remote sync, part of this was due to UDM trying to catch a firmware bug during synchronization which I thought was fixed years ago but the workaround remained so was no one noticed it was not fixed. When the catch was removed to fix the remote synchonization hang, We noticed the issue was never fixed in firmware. A fix will be in the next firmware version, however because most of our users use the remote sync, it is preferred to not revert the workaround in UDM as sync would hang for most users as they use remote. So I’m clear, what do you need to remove from local settings so it will only use portal? Edited July 23Jul 23 by hart2hart
July 26Jul 26 My EISY totally crashed and I can't seem to restore from a backup to my iPhone.I seem to have lost all devices and programs. I'm totally confused!
July 26Jul 26 On 6/23/2026 at 6:03 PM, Javi said:Will be fixed in next firmware update 966b1b.This is a networking error/bug when requesting Node Server Profiles. Portal Server is catching the issue, app was also caching the issue in the past but this caused slow synchronizations due to iOS not allowing connection-close header.Is this an iThingie problem only? That is, is there an issue with the android UD app?Orest Edited July 26Jul 26 by oskrypuch
July 26Jul 26 2 hours ago, SteveBL said:My EISY totally crashed and I can't seem to restore from a backup to my iPhone.I seem to have lost all devices and programs. I'm totally confused!UD Mobile cannot restore eisy, this can only be done from admin or eisyui (web).1 hour ago, oskrypuch said:Is this an iThingie problem only? That is, is there an issue with the android UD app?OrestThis is an issue with Local synchronization on iOS only. iOS doesn't allow a http header that prevents a firmware bug. So other non-iOS clients are not affected. iOS devices synchronizing through portal are not affected.
July 27Jul 27 12 hours ago, SteveBL said:My EISY totally crashed and I can't seem to restore from a backup to my iPhone.I seem to have lost all devices and programs. I'm totally confused!My apologies, I didn't completely explain the problem. I didn't attempt to restore from or on my iPhone but on my PC. I can't even see or find the uuid in the lox anymore. It's dead in the water. Any help would be very much appreciated.
July 27Jul 27 @SteveBL please open a support ticket with UD (https://www.universal-devices.com/my-tickets/). Otherwise, please start a new thread in the IoX Support area since your issue is not related to this topic.
Yesterday at 01:07 AM1 day I have this same issue. I have been able to resolve for an EISY deployment, but I have not been able to resolve using Javi's workaround for an ISY. For the ISY (running 5.3.4), no Portal tab ever presents, so the portal communications based workaround is unavailable. Help please.
Yesterday at 03:49 PM1 day Bug Investigation & Technical SummaryiOS / ISY994 Synchronization IssueWe are providing this technical summary because this is an unusual situation where a small number of users are affected by an interaction between legacy firmware, HTTP connection handling, and changes in Apple's iOS networking behavior.Polisy and eisy users should upgrade to the latest firmware to resolve the underlying issue. Firmware upgrades will also be required to obtain the latest Admin Console features as Apple's removal of Rosetta from macOS affects our ability to continue supporting the existing Admin Console development environment.For ISY994 users running firmware 5.x, upgrading is not possible because the latest firmware is not supported by this hardware. ISY994 users who are already connected through a portal/proxy should synchronize through the proxy, as the proxy uses Connection: close and avoids this HTTP synchronization issue.For ISY994 users who connect directly from iOS, we are investigating whether an additional iOS-side workaround is possible.Our goal is to explain what we currently know about the issue, why it occurs, who may be affected, and what options are available. iOS_ISY994_Sync_issue.md
