New release out today.....Does this work on Polisy?
Solved by Guy Lavoie
It does work, but the update must be done manually, by accessing the Polisy by ssh. Then you do:
sudo pkg upgrade udx isy eisyui pg3x
This method was suggested by Michel at UDI. I've successfully upgraded two Polisys this way.
Remember the release announcement warning:
If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system.
Edited by Guy Lavoie
Do you know if this will be enabled/allowed from the Jave console in the future. I'm not that familiar with ssh control of Policy. I get this error when trying that upgrade command. No repositories are enabled. (My OS is 14.3)
Edited by EJones01
Just now, brians said:
This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.
That's for the Polisy only.
Ok so I have a polisy do I use ssh to upgrade or not. The instructions are kinda ambiguous I think I see now that is a warning for older kernels
Edited by brians
Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.
