Friday at 07:07 PM1 day 1 hour ago, Michel Kohanim said:5.1.0 is 5.0.0_7 + the bug fix for Polisy.With kind regards,MichelOk I have 5.1.0. What is the current procedure to upgrade to the Eisy html i/F now?UPDATE: The last update UDX took me to v6.1.2 ?? Edited Friday at 07:12 PM1 day by larryllix
Friday at 07:11 PM1 day 1 minute ago, larryllix said:Ok I have 5.1.0. What is the current procedure to upgrade to the Eisy html i/F now?You mean upgrading by using eisy-ui? Go in eisy-ui and scroll down to System, and then after selecting the repository you're using, just click on "Upgrade Packages". This will now work the same for eisy or Polisy.
Friday at 07:13 PM1 day 1 minute ago, Guy Lavoie said:You mean upgrading by using eisy-ui? Go in eisy-ui and scroll down to System, and then after selecting the repository you're using, just click on "Upgrade Packages". This will now work the same for eisy or Polisy.OK...where is eisy-ui? does that mean browser access? If so, what port etc..?UPDATE: I have got an old link but only get "Unable to connect" fromhttp://192.168.0.xxx:3000/eisy-ui/redirect?redirect=http%3A%2F%2F192.168.0.165%2Ffavorites%2F1 Edited Friday at 07:16 PM1 day by larryllix
Friday at 08:12 PM1 day No need to specify a port, it's just the standard port for http.http://eisy.localOr hard-code the ip address
Friday at 08:16 PM1 day 2 minutes ago, Guy Lavoie said:No need to specify a port, it's just the standard port for http.http://eisy.localOr hard-code the ip addressThanks...after all the combinations I have tried...LOLNow to see if I can stop the alternations of login names....geesh.
Friday at 08:48 PM1 day @javi @Michel Kohanim Eisy-ui on polisy needs backup file location. Backup files have no spec for location and end up on my desktop in Win 11General vertical spacing is too large and I only see about 5 lines on any webpage (4K monitor, Win 11)AWESOME so far!
Friday at 09:14 PM1 day 23 minutes ago, larryllix said:@javi @Michel Kohanim Eisy-ui on polisy needs backup file location. Backup files have no spec for location and end up on my desktop in Win 11This is a browser's global setting, different depending on the browser. While some browsers support "Save As" not all so would be inconsistent. 25 minutes ago, larryllix said:General vertical spacing is too large and I only see about 5 lines on any webpage (4K monitor, Win 11)Vertical spacing of what?
Friday at 09:27 PM1 day 11 minutes ago, Javi said:This is a browser's global setting, different depending on the browser. While some browsers support "Save As" not all so would be inconsistent. Vertical spacing of what?Vertical spacing of most text in every webpage. Lists mostly only show about 5 lines of text with spacing about 4-5 times the vertical height of the fonts.While I have got your attention....how do you move a device from one folder to another? Edited Friday at 09:28 PM1 day by larryllix
Friday at 09:29 PM1 day 1 minute ago, larryllix said:Vertical spacing of most text in every webpage. Lists mostly only show about 5 lines of text with spacing about 4-5 times the vertical height of the fonts.With Chrome? Post a screenshot.
Friday at 09:33 PM1 day 2 minutes ago, Guy Lavoie said:With Chrome? Post a screenshot.I avoid most google products.Firefox. Here is a few lines from a single device. Most text lines on all pages are double spaced....so much blank space.
Friday at 09:46 PM1 day 12 minutes ago, larryllix said:Vertical spacing of most text in every webpage. Lists mostly only show about 5 lines of text with spacing about 4-5 times the vertical height of the fonts.While I have got your attention....how do you move a device from one folder to another?First it looks like eisy-ui is not up do date, please check for an update from within eisy-ui or if remote verify the url has the correct eisy-ui version. This may answer some of you other questions.The items per page are controlled by browser zoom. I have ~19 lines at 100%. The breadcrumbs are removed in newer versions of eisy-ui so it adds more space.
Friday at 10:26 PM1 day 38 minutes ago, Javi said:First it looks like eisy-ui is not up do date, please check for an update from within eisy-ui or if remote verify the url has the correct eisy-ui version. This may answer some of you other questions.The items per page are controlled by browser zoom. I have ~19 lines at 100%. The breadcrumbs are removed in newer versions of eisy-ui so it adds more space.Browser zoom does not control the font / spacing ratio, only the overall size of fonts and spacing together. HTML code controls the ratios.I have used the upgrade several times but two items never change. Does that require a reboot?
Friday at 10:37 PM1 day 1 hour ago, Guy Lavoie said:Others have reported issues with Firefox. Try Chrome.No thanks. Had too many problems with that thing.
Friday at 10:47 PM1 day 19 minutes ago, larryllix said:Browser zoom does not control the font / spacing ratio, only the overall size of fonts and spacing together. HTML code controls the ratios.I have used the upgrade several times but two items never change. Does that require a reboot?Being Polisy I'm not sure. Might require a reboot, or ssh to update. I believe the ssh commands are on the first page of this topic.
22 hours ago22 hr On 9/3/2026 at 4:23 PM, jrainey said:Thanks Michel, but I was really wondering if I will be able to abandon admin console and still administer my Polisy. Or, will i have to keep a working version of admin console that will no longer be advanced?On 9/3/2026 at 6:10 PM, Michel Kohanim said:@jrainey , yes, you should be able to.With kind regards,MichelThe impact on the Polisy is not very clear. I have the same concerns. There were two options in @jrainey inquiry:#1. abandon admin console and still administer my Polisy#2. or, have to keep a working version of admin console. Which option are you saying "yes, you should be able to"?Is there any way I be able to use the new UI with full functionality to admiistor my Polisy?
22 hours ago22 hr 13 minutes ago, david-4 said:The impact on the Polisy is not very clear. I have the same concerns.There were two options in @jrainey inquiry:#1. abandon admin console and still administer my Polisy#2. or, have to keep a working version of admin console.Which option are you saying "yes, you should be able to"?Is there any way I be able to use the new UI with full functionality to admiistor my Polisy?Essentially, the Polisy will be following the same path as the eisy for now: no new updates to admin console and gradually switching over to eisy-ui, which is gaining in functionality steadily every few days. Initially UDI had wanted to reduce support for the Polisy and any updates would have been done manually through ssh. Instead, they relented and brought back updates through eisy-ui, just like for the eisy. The main constraint is that it is limited in the version of FreeBSD it can run, so there might come a time when something new might not work. Support for Matter might also be affected, something to do with IPv6 functionality being problematic.
22 hours ago22 hr I can testify that the Polisy is now upgradable via Eisy-UI. Last night I did yet another upgrade via ssh, and it got me udx 5.1.0. Then there was another upgrade available in the production repo (mDNSResponder), and I was able to upgrade it just by pushing the "Upgrade Packages" button.My working Polisy is still on an older version and is controlled by the AC, but I will upgrade it soon.Finally, I read another thread about Hue lights in scenes where Javi said that some type of configuration is only possible in Eisy-UI, and never will be in the AC, so the divergence is happening already.-Tom
16 hours ago16 hr Overlooked this one. No wonder I am finding so many troubles on eisy-ui. LOL Program folders keep closing on me, no editing can be done etc...etc.Turns out I am running v0.10.1.Updates have not been happening so I went into SSH and this is what I got back (Short of memory)--------------------------------------------------------------------------------------------------------Number of packages to be upgraded: 1The process will require 41 MiB more space.124 MiB to be downloaded.Proceed with this action? [y/N]: ypkg: Not enough space in /var/cache/pkg, needed 124 MiB available 9405 KiB------------------------------------------------------------------------------------------Now what I do with my Polisy Pro?
16 hours ago16 hr 13 minutes ago, larryllix said:Overlooked this one. No wonder I am finding so many troubles on eisy-ui. LOL Program folders keep closing on me, no editing can be done etc...etc.Turns out I am running v0.10.1.pkg: Not enough space in /var/cache/pkg, needed 124 MiB available 9405 KiB------------------------------------------------------------------------------------------Now what I do with my Polisy Pro?eisy-ui from the middle ages, when knights were bold!Do you have one of those reimaged Polisys that end up with a small filesystem? There was a problem with that a while back, requiring some unix commands to reallocate disk space properly.
15 hours ago15 hr Just now, Guy Lavoie said:eisy-ui from the middle ages, when knights were bold!Do you have one of those reimaged Polisys that end up with a small filesystem? There was a problem with that a while back, requiring some unix commands to reallocate disk space properly.Possibly. How would I tell? I did have my SSD crap out and it had to be replaced at one time.
15 hours ago15 hr 27 minutes ago, larryllix said: I did have my SSD crap out and it had to be replaced at one time.Bingo, telltale sign.You can ssh into it and then do:dfThis will show the disk space. It should look like this:Let me find the forum thread about this and I'll post it.
15 hours ago15 hr 10 minutes ago, Guy Lavoie said:Thread here:Thanks so much Guy.I found the amazon order for 64GB. Seems I bought two? I have a spare polisy though,The df command shows about 25 MByte x 1K sectors SSD and it is about 98% full. I hope this is easily re-allocated to one drive....ewww,Is there an easy way?Perhaps there is some clean-up on isle two that can be done?ie: is there multiple images of old polyglots or ISYs just taking up unemployed space? Edited 15 hours ago15 hr by larryllix
