15 hours ago15 hr Looking for ways to lower the cost if I get my own Claude developers account. Do it not work?
15 hours ago15 hr Author @photogeek54 ,There's no such a thing as Claude Developer account. You can buy API Keys, or you can use your own subscription (if you have) and then use MCP.With kind regards,Michel
15 hours ago15 hr Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?
14 hours ago14 hr Author 17 minutes ago, Guy Lavoie said:Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?Unfortunately not without making public everyone's usage. 1 minute ago, SHM said:Yes, I am using the latest version of the plugin and latest eisy firmwarePlease submit a ticketWith kind regards,Michel
14 hours ago14 hr 1 hour ago, Guy Lavoie said:Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?If you are using Claude, token usage appears to be available from the Dashboard - Token Volume.
12 hours ago12 hr Token usage is shown if you purchased your own tokens. I bought Claude tokens so I can get working but understanding how to keep it cost effective would be very important. Cost me $15 for a very simple fix of an error eisy-ai made. Seems like each time you give eisy-ai a developer command it might have to re-send every file in a plugin plus info on all your programs/devices/variables. That’s a lot. I asked eisy-ai about ways to conserve tokens but mostly it gave suggestions that would be useful to eisy-ai itself.
12 hours ago12 hr Author 16 minutes ago, photogeek54 said:Seems like each time you give eisy-ai a developer command it might have to re-send every file in a plugin plus info on all your programs/devices/variablesAbsolutely false. That's the whole purpose behind developer vs. customer modes: they have their own prompt, context and session.What eats up tokens is chatter that cannot be cached. dramatic changes from one turn to the other. And if the context window is too large (say 100K), then it might eventually run out of cache space. And, finally, "simple" for you does not mean simple if it has to review all the files and understands where the mistake is.With kind regards,Michel
12 hours ago12 hr Do we have control over the context window? Does it need to be a certain size to handle most development tasks? Is 20000 the correct number to put in the json? Any other suggestions?
11 hours ago11 hr Author Context Window is defined by the model. You have control over history_usage. So, if you use 20,000, then when the context gets to about 20K, eisy-ai will try to compact it.With kind regards,Michel
8 hours ago8 hr Jusy a quick suggestion - It would be great if the program number was displayed like the variable number in esy-ui - AI often refers to the program numbers in complex programs rather than the name of the program. This is when using AI to generate home automation programs - not plugins
8 hours ago8 hr 30 minutes ago, Panda88 said:Jusy a quick suggestion - It would be great if the program number was displayed like the variable number in esy-ui - AI often refers to the program numbers in complex programs rather than the name of the program. This is when using AI to generate home automation programs - not pluginsIs there a specific place you are suggesting?The program ID number is already displayed in eisy-ui, right after Next Scheduled Run Time when on the main Program folder line.
7 hours ago7 hr The issue is when eisy-ai is active and you are viewing a program it covers the program number - if you are reading the response from AI and it references program numbers it makes it difficult - maybe add it next to the program name when viewing a program
6 hours ago6 hr HOW TO ADD FILE UPLOAD TO A PLUGIN IN EISY-AIMy Solaredge Modbus plugin needs to read a complex json file. The version in the store had this functionalityCustom Typed Configuration ParametersZIP File UploadThis will upload the zip file and extract it to the "data" directory of the plugin.Please see plugin help for more details on file upload.and a "select file to upload" button hereI've asked eisy-ai to add this same functionality to my plugin but it doesn't seem to know how. Any suggestions how I get eisy-AI to add this?
5 hours ago5 hr Author @Panda88 ,When eisy-ai refers to a program, there's also a link that you can click.@photogeek54 ,Not implemented. For now, you can easily add it by editing your plugin.With kind regards,Michel
5 hours ago5 hr Sometimes there is a link. Other times there is not - not is when you need the number
