November 4Nov 4 Author @Guy Lavoie ,The new version 2.2.2 was released today. It has session management + automatic notification after the first you have use 50% of your context (you can ignore them). Regarding revert, if you connect to github, then it will read the commit comments and can revert.Using the session management, it's best to name your sessions so that you can go back, load them, and start from where you left off (different plugins).With kind regards,Michel
November 4Nov 4 25 minutes ago, Michel Kohanim said:Using the session management, it's best to name your sessions so that you can go back, load them, and start from where you left off (different plugins).So far I've only worked on one plugin, and when I start a new session, I simply ask it to work on the Ocelot plugin. I followed some instruntions wchich allowed me to create a local .git subdirectory, which is a start. I've never worked with github so setting that up is something I'll have to look into. Lots to learn.. So how do we update the eisy-ai plugin to 2.2.2? I see no update button. Click on Reinstall?
November 4Nov 4 Author @Guy Lavoie ,Make sure you upgrade everything else first because I am not sure at what level you areClick on Plugin, click on eisy-ai, then click on Reinstall (or Update if available)With kind regards,Michel
November 4Nov 4 48 minutes ago, Guy Lavoie said:So far I've only worked on one plugin, and when I start a new session, I simply ask it to work on the Ocelot plugin. I followed some instruntions wchich allowed me to create a local .git subdirectory, which is a start. I've never worked with github so setting that up is something I'll have to look into. Lots to learn.. So how do we update the eisy-ai plugin to 2.2.2? I see no update button. Click on Reinstall?GitHub is a bit roundabout, but basically, here's how to set up your eisy plugin to upload to GitHub. I wrote my own summary, then asked chat gpt what it thought of it, and it did a wonderful job of making it better, with nice code boxes and bold text and filling in details I skipped. So I posted it instead of mine. Hope this saves you time.1) Create your GitHub repository.On GitHub, click the + button near the upper-right corner and select New repository.Give it a name, usually the name of your plugin. Make it Public if you intend to share the plugin.For an existing plugin you're uploading from eisy, leave the README, .gitignore, and license initialization options unchecked. You can add those files later.Copy the repository URL. It will look something like:https://github.com/USERNAME/REPOSITORY.git2) Create a GitHub personal access token.Click your avatar in the upper-right corner, then:Settings → Developer settings → Personal access tokens → Fine-grained tokens → Generate new tokenGive the token a name, such as eisy.You can select All repositories if you want the token to work with all repositories you own, rather than selecting them individually.Under Repository permissions, set Contents to Read and write.Choose an expiration date. I used no expiration so I wouldn't have to renew it, although an expiring token is more secure.Generate the token and copy it somewhere secure. GitHub will only show it once. If you lose it, you'll have to generate another.3) Connect your eisy plugin directory to GitHub.SSH into eisy and navigate to your plugin directory:cd ~/your-plugin-directoryIf this directory isn't already a Git repository, initialize it:git init git branch -M mainNow connect it to the GitHub repository you created:git remote add origin https://github.com/USERNAME/REPOSITORY.gitIf origin already exists and you need to change it, use this instead:git remote set-url origin https://github.com/USERNAME/REPOSITORY.gitYou can verify the destination with:git remote -v4) Configure eisy to remember your GitHub token.Run:git config --global credential.helper storeThis tells Git to save your credentials so you don't need to enter the token every time you push.Be aware that Git stores the token in plaintext in your home directory, so this is convenient but not the most secure option.5) Commit and upload your plugin.git status git add . git diff --cached --check git commit -m "Initial plugin upload" git push -u origin mainThe first time you push, GitHub will ask for your username and password.Username: Your GitHub usernamePassword: The personal access token you generated earlier, NOT your normal GitHub passwordAfter a successful push, Git will remember the token.Before using git add ., make sure your plugin directory has a suitable .gitignore so you don't accidentally upload credentials, configuration files containing passwords, or logs.6) Future updates are much easier.Whenever you make changes to your plugin, just run:git status git add . git diff --cached --check git commit -m "Describe your changes" git pushThat's pretty much it. Once you've set up the repository and token, updating GitHub from eisy is very straightforward.
November 5Nov 5 Here's some more feedback on eisy-ai:when setting a variable to a state variable value in eisy-ui the state variables are not sorted alphabetically so they are hard to findMany times when eiasy-ai describes a program in the chat it calls it somethiung like "program 360" rather than its friendly name, also may do this with variable names some times Ai still puts text in white on white boxesIn one case ai asked me "I need to know whether the host has the Python modules for an offline test, and what the plugin's small docs files say". don't have a clue what that meansAi doesnt seem to like eisy programs that don't do meaningful work in the then or else parts. Since I can use the state of a program in other if statements I sometimes leave them blankI asked ai to review some of my eisy programs for issues. It is cool that AI reads the comments also and tries to check if my program logic matches the intent described in the commentsI haven't figured out how to multiple lines in a chat window before sending the whole thing to aiYesterday solaredge shut down the v1 API my plugin uses so I'm using ai to convert it to the v2 API, no results yet.
November 5Nov 5 Author @photogeek54 ,Thank you for the feedback. I suspect you are reaching the max context window. Can you upgrade to the latest. It will give you notifications before compacting. With kind regards,Michel
November 5Nov 5 More Observations > General User-ModeWhat is isy-ai doing ???At times, after a command has been submitted to eisy-ai, you could at times … wait and wait ... and wait some more for eisy-ai to reply ... eventually it does, but there was a moment when your not sure if you actually pressed ENTER> can a spinning wheel be added into the production release so the user knows processing is underway ? Adding KPL's and assigning a switch label / name> I have added both a 6 button and 8 button KPL several times via eisy-ai e.g. ADD KPL aa.bb.cc name = test 6 kpl ..... the creation is perfect, the NEW node appears with labels: Test KPL 6, Test KPL 6 - A, - B, - C, - D> Now, if you try to add "TEST KPL 6", the primary On/Off switch into a scene, eisy-ai starts the argument, which TEST KPL 6 - A B C or D do you want to include .... To end the fight, you have use very strong instruction to specifically use "TEST KPL 6" NOT A, B,C or D in the new scene> Yes, the fix to rename all elements of the node to exact names, but why ??? The name [TEST KPL 6] is a valid name vs [TEST KPL 6 - A] > The same problem also occurs with KPL 8, the default name assignments start at "B" VS "A" on the KPL 6's eisy-ai forgets it created Scenes> In my testing, I will assign a combination of 3 or 4 switches / KPL's into a “use case”.> On multiple occurrences, I provided instruction to create a scene name ABC and include 3 or 4 valid switch names which already exist in the Nodes list. This normally always works properly (unless its the primary KPL 6 or 8 buttons - see above)> Then I request eisy-ai create a solution where a trigger turns on/off scene ABC. What eisy-ai actually creates in most programs, it assigns the individual switch names into the program’s vs the scene nameI query why : ME> why are you not using scene control vs individually sending cmds to each switch ... In this Program > "sams room - countdown expires lights off"eisy-ai > I didn't consider the scene. I wrote each routine to command the three devices one at a time, and I should have checked the scene first. eisy-ai always assigns the wrong variable type round one> Where I ask eisy-ai to create a program with a timer to turn off light after X seconds, 90% of the time it creates the timer as an Integer.> When the program fails to work properly, eisy-ai always determines it used the wrong variable type and fixes the program to use StateBONUS PROBLEM, when eisy-ai determines it used the wrong variable, it then creates the NEW State variable, BUT it ALWAYS forgets to remove the Integer ME> Question, when you requested to change the variable, and it was approved, why did you not delete the integereisy-ai > I didn't delete it because deleting a variable needs your explicit confirmation, and I never asked you for it.
November 5Nov 5 Author Please upgrade to the latest. Spinning wheel and context management should solve some of your problems.Finally, I like plugin authoring, customer uses the cheapest and least capable model. That definitely explains integer vs. State variable confusion.With kind regards,Michel
Friday at 09:58 PM5 days I just installed the latest UDX, 5.3.0. Now the eisy plugins (eisy-ai 2.2.3 and my development plugin) are stuck at "starting". PG3x are also showing all as disconnected.Tried two reboots. Boot Environment is still showing OS version 14.14 Release p6. No previous environment listedUpgrade screen is showing the latest versions (IoX 6.1.2_14, UDX 5.3.0 eisy-ui 1.4.9, PG3x 3.4.28).If I try to run the upgrade through ssh pkg upgrade, tells me everything is up to date.Hints? Edited Friday at 10:06 PM5 days by Guy Lavoie
Friday at 10:20 PM5 days Stuck in a loop of trying to restart plugins. Insteon, etc seems to work./var/udx/logs/log shows:Fri Nov 6 17:17:34 EST 2026|/usr/local/etc/udx.d/static/udx_startup.sh: restarting pg3x because it didn't start 0 ...Fri Nov 6 17:17:35 EST 2026|/usr/local/etc/periodic/daily/udx_tasks: no packages need upgrading ...Fri Nov 6 17:17:35 EST 2026|/usr/local/etc/periodic/daily/udx_tasks: fetching Matter PAA files ...Fri Nov 6 17:17:38 EST 2026|/usr/local/etc/udx.d/static/udx_startup.sh: pg3x started successfully ...Fri Nov 6 17:17:39 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_4 failed ... restarting now!Fri Nov 6 17:17:39 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_2 failed ... restarting now!Fri Nov 6 17:17:40 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_1 failed ... restarting now!Fri Nov 6 17:17:40 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_8 failed ... restarting now!Fri Nov 6 17:17:40 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_12 failed ... restarting now! Fri Nov 6 17:17:40 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_7 failed ... restarting now!Fri Nov 6 17:17:40 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_5 failed ... restarting now!Fri Nov 6 17:17:41 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_6 failed ... restarting now!Fri Nov 6 17:17:41 EST 2026|/usr/local/etc/udx.d/static/udx_svc_supervisor: 0021b902618f_11 failed ... restarting now!
Friday at 10:32 PM5 days Author It's a bug (migration to python 312). give me a few minutes.With kind regards,Michel
Friday at 10:49 PM5 days Got the new UDX version, but same situation, even after 2 reboots. I saw some messages go by about plugins getting reinstalled.
Friday at 10:55 PM5 days Author Please submit a ticket, let's do a remote session.With kind regards,Michel
Friday at 11:54 PM5 days For those following the drama...Michel ended up rolling back the python update. I guess there a bit of work to be done there.A BIG thanks to @Michel Kohanim
Sunday at 02:32 AM4 days @Michel Kohanim is it expected that eisy-ai in customer mode can not create network resources and could not add them to a program?In developer mode after a plugin is made the AI loses write access to the files so changes are difficult.I don't know if I'm the only one but I'm still experiencing session resets where I lose the session. Also while creating or troubleshooting a plugin it has to compact the session which I assume is expected to save on tokens.I'm getting great use out of eisy-ai in developer mode not so much in customer mode. While in customer mode it just feels easier to do it myself except for checking logs and seeing history.I was the one who asked about the occupancy node server during the webinar so "we" created one today. It was difficult to get the AI to understand how to do it but after finding and linking the proper UDI wiki information it got it done. I have only done limited testing sending the URL's with MacroDroid and don't have the skills to support it so if someone would like to take ownership and put it on the store I would not mind. https://github.com/taz-man/eisy-occupancy-webhook
