Everything posted by Andy P
No Scenes in eisy-ui!
I used to always navigate the all nodes view by going through the tree and expanding and collapsing folders, and so when I moved to the new UI I naturally wanted to do the same thing and got super frustrated. But then I discovered that just putting in a few characters of the device in the search was a lot faster. And my groups/scenes start with "@" so finding all of them is as easy as just entering @. Takes a while to adopt to the new workflow, but actually it is a lot faster! Thanks (Although I really with the search field was open by default to save me a click!)
Change background and colors on eisy-ui
If you do not see a tab under Settings called Display, then you need to upgrade packages because it was a recent addition.
Compare last device update to variable timestamp
Ah yes, I see. Apparently there are two possible values but the eisy-ui does not allow you to choose the second one and defaults to the first So, I was able to use the AC to create the program: This one runs every hour. It doesn't really need to use the intermediate variables, but I used them to make sure it was working right.: Elapsed Time Check - [ID 00AB][Parent 00AA] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then $System_Unix_Time = [Unix Date/Time (seconds)] $Last_Update_Time = 'YoLink / Motion Crossroad' Last device update Unix Timestamp $Last_Update_State = $System_Unix_Time $Last_Update_State -= $Last_Update_Time And I have another program that triggers when the $Last_Update_State is > the timeout value. I will be fixing the logic so it doesn't trigger on the first assignment. Thanks!
OK, so I was able to store the system unit time into an integer variable, but no matter what YOLINK device I select, it does not store a value for the last update into the variable - always zero. Is that a bug or am I doing something wrong..
Admin Console
Thanks, Guy, that got me access to the directory and I was able to confirm the location./var/isy/FILES/USER/WEB. Now I want to be able to upload the files directly from sftp in VSCODE, so I believe I have two options. 1. change the permissions on that directory using CHMOD so that I can access it without elevated credentials, or 2. remove the password for access using admin ALL=(ALL) NOPASSWD: /usr/libexec/sftp-server Any recommendation or anything I am missing?
Admin Console
I tried to access the files by SSH which I think are in the /var/isy/files/user/web directory but I got stopped with permission errors at the /isy directory level. So if there is not going to be an option to manage the user/web files in eisy-ui, how are they accessed using ssh?
Admin Console
I have a whole dashboard that is hosted on the web server. I needed to host it there to avoid cross domain scripting errors. I don't mind if it moves to another port, but I would really like it to remain viable. http://192.168.3.14:8080/USER/WEB/HV2.htm#
eisy-ui line spacing
OK Thanks, no problem. I can continue to use Stylus to get the compact version I like. For anyone else who is interested, this is my override css. But please don't complain if it breaks anything /* Override row height and CSS variables */ .MuiDataGrid-row { max-height: 24px !important; min-height: 24px !important; height: 24px !important; --height: 24px !important; } /* Adjust cell height and alignment to match */ .MuiDataGrid-cell { max-height: 24px !important; min-height: 24px !important; line-height: 24px !important; }
EISY column ajdustment
When you manually adjust the column width that way, another column resizes in the opposite direction in order to keep the entire grid 100% of the screen width. So this is probably not quite the ideal design, although it works well for the initial release. Ideally, you could have an option that sets each column to the largest item width plus some variable gutter width.
I am getting more comfortable with the new UI - thanks for moving in this direction - I can see it is a lot of work! Under your work in process, I can see you mentioned customizing light and dark themes, etc. Are you also going to give the ability to adjust the line spacing? Right now the 36px spacing is way more than I need. I am currently overriding it using Stylus to 24px. Thanks, Andy
Admin Console
I saw the comment about Network Resources coming soon, thanks. But what is the plan for Web Server file transfers. Thanks
OK, I was trying to figure out how to tell if the last device update for a certain device was older than a certain amount of time. I know I could accomplish something like that by having each event start a program that waited some amount of time but I got to thinking, why can't I just check the device last update and compare it to either the system time or for example a variable unix timestamp. I don't think this works even though you can create an if statement in a program that looks like it should work: LastUpdate - [ID 00AF][Parent 0010] If 'YoLink / Motion Crossroad' Last device update < '$On_Minutes Unix Timestamp' Any ideas? I want for example to run a program at 8 am that will tell me if a device has not had an update in the last 24 hours.
insteon motion sensor
OK, so I assume you have a yolink hub and the yolink app. Go into the app, Settings - Profile - Account - Advanced Settings - User Access Credentials. Hit the + and create a new one, You will need the UAID and Secret Ket that it generates. Then go into the polyglot console and config the yolink plugin using those credentials.
Disabled Folders - Please explain
I have a folder called Away Random Lights. It has a condition based on a variable that I set with a keypad button. So when that button is on, the variable is set to 1 and all the programs in the folder are enabled. When I turn that button off, the variable goes to zero and all the programs are disabled. Makes it easy to set random lights as I go out the door and turn them back off when I come back in. Away Random Lights - [ID 0023][Parent 0001] Folder Conditions for 'Away Random Lights' If $State_Random is 1 Then Allow the programs in this folder to run. AND, in direct response to your other question, it is true that if you create a new folder with nothing in it, the right click will show you options for enable and disabled, but when you add a program to the folder, those options disappear. I consider this a bug, frankly. I can't think of any reason an empty folder would be enabled or disabled. Folder status should always be set by the folder conditions.
i3 Keypad Programming
I have several of those i3 keypads and went through multiple attempts at doing something logical. Similar I have scenes called bright, normal, cozy and off. In the end, I decided that trying to keep the keypad in sync with which scene was active would never work in a way that would make me happy. So I started over and decided to make the buttons momentary on. Which means when you press the button it sends and on, But then inside the scene, I turn that button off. So it turns on, sets the scene and then turns off. This means I end up with essentially no buttons on except during the moment I am setting the scene, except the load button will always reflect that load if it is controlled by that keypad, so I normally just use the top button to turn that individual light on and off. I know this isn't quite what you asked but maybe spark some idea.
After update, device types now end in "F"
OK< thanks, I adjusted the code to strip off the F and everything is working again! Appreciate the response. Thanks, Andy
My downstream programming broke and I found the reason is that the device names now have a 'F' after their name, like this - used to be yomotionsens and now it is yomotionsensF for some reason? <node flag="128" nodeDefId="yomotionsensF"> <address>n008_8b4c020013c921</address> <name>Motion Kitchen</name> <family instance="8">10</family> <hint>0.0.0.0</hint> <parent type="3">32793</parent> <type>0.0.0.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>n008_8b4c020013c921</pnode> </node> Also true for <node flag="128" nodeDefId="yovibrasensF"> and <node flag="128" nodeDefId="yoleaksensF"> and <node flag="128" nodeDefId="yothsensF"> But not for <node flag="128" nodeDefId="yodoorsens"> It is not just in the admin console, it is also in the polyglot console Node Name 3 Address NodeDef Primary Node Hint Enabled Is Primary Delete Fan HVAC 1 8b4c0100097447 yovibrasensF 8b4c0100097447 0x00000000 true true
Programs - Control vs State?
I used to do that, too, but my other house occupants couldn't get their heads around the idea that pressing off would turn on the light! However, I do make use of it to turn other lights off. For example, if you turn off the over sink light and then press off again it turns off the under counter lights which have a separate switch farther away.
How much longer until the portal reconnects?
Yup, I am back connected. Thanks!
ok, i did submit a ticket as you asked
Rebooted two of them. Still not connected
The portal maintenance was reported as finished 40 minutes ago. All of my EISY still show offline. How much longer should I expect it to be?
Replacing an EISY R1 with an EISY R2
This is not something I would normally expect to do, but I had a perfectly running EISY R1 with a ton of devices in my house and I want to set up a small EISY/Insteon setup in a different property. It seemed like a waste to put the new more powerful R2 at the small property, so I decided to swap out the R1 with the R2 and then factory reset the R1 to use at the new property. in doing this, my first thought was, I am going to preserve all the devices by moving the PLM and zwave dongle from the R1 to R2. That is exactly what I did and it made the change very simple. Run a backup of the R1 both the admin console and the PG3 console. Shut it down Move the PLM and dongle to the R2 and power it up. Open the admin console on the R2 and make sure it is running nicely (with no devices). Run restore on the R2 and wait many hours. In fact I waited over night and then finally just rebooted it because it never really told me it was done with the restore. After the reboot, everything is already working! Except the Polyglot stuff. Go into Polyglot console and do a restore. Oops, I dont have any licenses. Buy all new licenses for the node servers. Restart everything. All the nodes are now alive. Buy a portal license for the R2. Activate it and rename the R1 to old house - oops, can't do that unless I power it back up again, Ok, now everything is looking good on the R2. Well, except Alexa is tied to the R1. Delete all the commands from the R1 in the portal from Alexa Add all the commands from the R2 in the portal to Alexa Give it a day to make sure everything is working. Ok, factory reset the R1 by pressing the front button 10 times. So, this all ran smoothly and now I have the R1 to install at the new location, It already has the portal license and node server license, so I just need to plug in my spare PLM and should be ready to go. Just sharing my experience. Anything I could/should have done differently? Take care., Andy
Verify I have an Eisy R2
Yes, exactly. The original EISY had a usb-c port next to the ethernet jack for power input and then a blue usb A port next to the hdmi ports. The new R2 still has the usb-c port for power input next to the ethernet jack, but the blue usb A port on the back was replaced with a usb c port. There are still 3 usb A ports on the side.
Should I migrate from Hubitat to Eisy?
When Insteon was on the ropes I started down the path of installing zooz switches controlled with habitat. I was disappointed by the primitive programming method of the habitat but I could see why it might appeal to non programmers. I really missed the scene support and multiway flexibility of the ISY plus Insteon. So when Insteon was resurrected I got a couple EISY hubs and some new i3 stuff and pretty much removed the habitat and zooz, but the few items I have remaining there have been rock solid with no real motivation to change. I never had more than 10% of my devices on hubitat so the decision to move back was easy for me. For a simple set up with few complex automations I think hubitat is fine. Some of the stuff I do with multiple dimming levels, motion triggered temporary lighting and timed automations would be difficult on the hubitat and are pretty easy on the EISY. Also love the REST interface for custom dashboards and the polyglot integration of Lutron, Yolink, etc. So my advice is only move if you have a compelling reason that the current setup does not support for you.
