Everything posted by danncas
Zooz Zwave 800LR dongle - Review
everything is work as I want. I had these pop screen it was hard to see the one behind the other. I did get it to move and it said " package update. So I did the package updates and that popup went away. Alos the one that wanted me to vaildate Zwave device is going to. But now the Nodes look like this again. But all works
zooz motion sensor
I want to try on more thing he is the screenshot. It seem to work like this tested it several time. I will test it tonight several times. We Will SEE
zooz motion sensor
ZAC38 I dont know why the light doesnt go off after the status shows off on the sensor.
zooz motion sensor
Techman Here where I stand as of now. I bought a range exstender and it added to my Eisy. The sensor see me and turn on and the light. That status of the sensor goes off. BUT the light never goes off.
zooz motion sensor
well I had test it in a dark bathroom last night worked fine. No let see how it works out side. Ps I asked Insteon when wil the have a motion sencor. The sad late Oct out door and indoor
zooz motion sensor
Thchman I did some experimenting after I did another factory reset. I found out that after it goes to the OFF status after no motion it takes 30second before it changes the true output. So It seem I got it to woork now so far in my test . I put a time frame in where it will only work and the told it to turn on the light if it sees motion. So I test the it and it stay off even when it say me. Sofar so good . Im going to try the sunset to sun raise tonight. Fingure crossed thanks again
zooz motion sensor
- zooz motion sensor
It didnt work either . The sensor send an on code. I cant tell if it send an off code. You cant read the parmeters that it is factory coded to. I have no way of reading and bit transfers in this programing either. So in this program if it see On it more to the next step and then the next, EVEN if the sensor still on beacuse of movement. It would of been so much easier if it had a dusk to dawn like the old sensor did. I would not have to program. Ideaa??? The now way of having a While statement- zooz motion sensor
Here you go Techman It a should be simple. The second picture is how it looked before I reset the sendsor to factory setting. The last picture is how it looks now, but it soon or later will go back to what you see in thr 2nd picture . I apprecite all your help working with me.- Zigbee Devices Not Working after IoX 6.1.1 Upgrade
SADLY THE IT IS NOT RESLOVED- zooz motion sensor
Im not sure. Im going to do a factory reset tomarrow . It seem to work earlier . But tonight it shows on and never shows off. I sent you a DM If tied it directly to a insteon light it will work as long as it see motion. But It will also turn the light on doing the day. So I wanted to have it work with the same type problem I had befor on an insteon.- zooz motion sensor
thanks my question is Motion Sensor right click has parameters Powe alarm has Parameters Which on to you use- zooz motion sensor
guy so when speaking of node Each one of these is a node Yes/ No. Im not a netwok programer. I programer PLC and robots in the past. Im old lol 72- zooz motion sensor
I have a list of the parameters, I gather I have to go get the Sensor and manuly click the button. I have a option on that but I wil lkeep it. LOL Then I upgade any of the parameters.. Is there a way of read the parameters setting that are already set?- zooz motion sensor
I still dont Understand. Link NODE.? Insteon I get Link mode. Are you saying that I have go get the sensor and figure out how to put it manully in a link mood. And the term node. I konw what this means when I would progam a PLC, or a robots program. But not in a EISY- zooz motion sensor
Hello folks , New to this Zmatter. I have been able to add it to my Eisy. Now Im nott sure what I'm looking at. !. Is there any way to adjust the sensitivity? What does these setting all mean I did this simple program to test and it works. It different then the inteon there is no dusk to dawn setting, or sensitivity setting or sensing time/period ANY HELP OR IDEAS ARE APPRECIATED THANK YOU- compatible zwave zigbee dongles
guy have you tried any of them out yourself. If so which one has the esayest setup. Since the maunfacture think we app are software programers or.- IoX 6.1.1 let's discuss it!
I like to know more about this. I read about Java going away. Sadly I dont understand any of this ioo upgarde and not afraid to admit it. Any one will to shed some light in non engineer terms- compatible zwave zigbee dongles
I beeb told that I can use a doggle from a different source since UD does not ofer one. Can any one shead some light on this for me.- timeline of restocking of ZMATTER dongle
so the big question since Im not a devopler and more over an old novice anymore it how can I use my ESIY with zebee and zwave. My motin sensor are going and I need to find Outdoor ones. I dont want to have a some kind of extra hub- timeline of restocking of ZMATTER dongle
sadly it is no more at universal devices. So I will never have it,- timeline of restocking of ZMATTER dongle
what good is the esy if you can only us it for insteon and not matter devicecs- insteon motion sensor
I dont have yolink hub iyet. I was told to wait till the end of the month and the Zwave usb world be out $452.00 wow - zooz motion sensor
