Everything posted by TJF1960
Scene Controller Behavior in eisy-ui / UD Mobile
My memory is the same as @oberkc There were times I had forgotten this and was a real headscratcher back when I was using the ISY99i
WebControl rule to remind me when the Dyson V11 Orig
I am sorry but this is not what Webcontrol832 does. Perhaps you have mistaken something else you are running with this plugin. If you are running WebControl 8 or 832 plugin, how are you triggering what you want to happen, thru one of the inputs or analog inputs? Or are you controlling the charger thru one of the ouptuts? -Tim
Solid State Relay
I to have used these inexpensive boards for a long time as well, longer than 10 years in service. Some have opto couplers others used a transistor to switch each relay on either are fine..
500 error on backup attempt
Thank you, not sure if this is the bug they are working on, but maybe it is. Once I deleted the last plugin I installed, both of my eisy's will now perform a backup from the stock system page in eisy.
Sorry to Post here but it appeared issue for others has bee resolved. Mine just started throwing error 500 after starting a backup in eisy. pg3 appears in place, ai is 2.2.3 and on the latest staging. I do however vaguely remember deleting pg3, then brought it back into ui. Any suggestions? Thanks! -Tim
How to copy the program txt from web ui ?
Bump to all 3 requests please.
Webinar Time Poll
Looking forward to it! Thanks Guy!
Webinar Time Poll
Dang it. I completely forgot. Dang, I was really looking forward to it. hopefully the recording will be released soon? Tim
New and Improved eisy-ai Version 2.1.0
@Michel Kohanim ai created a plugin but when I reboot, /tmp is wiped. How do I get the plugin to persist boots? When trying to install the plugin I get Path /tmp/eisy-ai/generated_plugins/thinq_dynamic not found. Let me tell you though, ai created a working plugin, which is fairing complex one in less than an hour. Took me a month for a similar plugin...I feel I am becoming obsolete, lol.
Super excited to be playing with eisy-ai. Yesterday was my first attempt, and for my first plugin, I decided that I wanted to have AI redo a plugin that I did recently that I've Not been completely happy with. Using Claude and on the latest staging versions. It was very cool watching as AI started implementing all of my requests and its thinking process and performance. Once done it installed it into the local and it fired right up and worked right out of the gate. I had it do five revisions. Each time got better and better. But then most of you already know this as you've already been experimenting. I absolutely love it and I can see where this will be life-changing for people to be able to describe what they want and have AI build it for them and work the first time, pretty freaking amazing! I wish, and it may be on the roadmap, that AI would take notes that it can refer back to once the session ends. Maybe the notes could be placed inside the folder of the plugin so that it could read the notes and pick up where it left off or analyze what's wrong with it. I had to reboot a number of times, thru no fault of eisy, And each time it would tell me that it had no recollection of a previous conversation. Other than that, I have no complaints. Of course, yesterday was my first day, but I was highly impressed. Michel, you and your team did an amazing job! And thank you for the opportunity to test drive it! -Tim
what happend to local installation option
I found the same in pg3x in the last 6 or so months. I would have to load into beta store and install from there to test the install procedure.
2876DB Icon turns it's self on.
Awesome! I'm glad you were able to find it. -Tim
This might be a long shot but I'm wondering if you have the 1:00 AM query program enabled?
New Beta Plugin for LG Thin Q appliances
New version 0.5.19 fixed the refrigerator and a/c reporting. This plugin now supports Fridge, microwave, oven, washer, dryer and a/c. Thanks to @bgrubb1 and @DNewkirk for their help and support, appreciate you guys, thank you. If anyone has the LG ThinQ dishwasher and wants to try this plugin, it is in the beta store under LG_ThinQ -Tim
Webcontrol8 temp needs calibrated
Hi Gary! That is Awesome news! Thank you for letting me know. And thank you to @EricBarish for the excellent suggestion. Is that the DS18B20 sensor? Thanks! -Tim
Hi Gary, No, sorry. No temp calibration in Webcontrol8 or 832 is available. I never thought I would have a need to add that function I may look at it one day, but I am working 2 other plugins that are consuming my time right now. Out of curiosity, are you using Webcontrol8 plugin or Webcontrol832? -Tim
Update to v0.5.5 Please test and let me know. Thanks! -Tim
I am having issues installing local plugins to my test bed eISY. Not sure what happened, it was fine a couple of days ago but now not. I can install beta plugins no problem. So in the middle of troubleshooting guys, sorry for the delay... -Tim
Thanks Barry! Appreciate it. Will look over the logs soon. -Tim
Received logs and thank you for the notes above. I will return. -Tim
Good report! Thank you. If you could PM me the log files from pg3x I will check to see what info can be had. After the discovery, the plugin gets what info it can from the LG API and builds what it can from that info., not a lot for controls sadly. But having the logs may provide some more detail. Thank you! -Tim Edit: Also, I need the logs from the initial install, and input of the PAT key to reboot to discovery etc., hopefully all of the is contained in the current log? Along with some of the settings you changed on the unit might be helpful as well. Lol, basically everything from install to now.
LG ThinQ Dynamic for eISY / PG3x — Beta Testers Wanted!I've released LG_ThinQ v0.5.4 Beta in the PG3x Beta Store and am looking for a few people willing to test it. The plugin automatically discovers compatible LG ThinQ appliances and adds them to IoX, providing real-time status updates and supported controls for use in your home automation programs. So far, I've tested it with an LG washer, dryer, microwave, and dual oven. I'd especially like feedback from users with other LG appliances. You will need the Thin Q app and your registered PAT key. IMPORTANT: This is BETA software. BACKUP, BACKUP, BACKUP your eISY before installing! Please understand that I have a full-time job and develop this plugin in my spare time. I may not always respond immediately to questions or problems, but I'll do my best to get back to everyone as quickly as I can. If you give it a try, please let me know what appliances you have, what works, and what doesn't. Feedback and bug reports are always appreciated. Please remember: Backup, Backup, Backup before installation of the plug in. Thanks to everyone willing to help test!
Request for Back Button in web ui
I second that request please.
Trying to add an analog node.
@garybixler Yes, doggone it. I forgot about the parenthesis, I am sorry. You were persistent and got it going. If you wouldn't mind, after you play with it for a while, let me know what you think of the plugin. Thanks! Tim
@garybixler also I wanted to mention if you have a lot of nodes you want to add, use chat get, feed it all of your nodes and ask it to format for Json single line. That way you can copy it and paste it into web control plug in.
