TJF1960
Members-
Posts
1808 -
Joined
Last visited
Everything posted by TJF1960
Where are the instructions? The More Info link on the store page is inop. and there are no instructions in the plugin config page.
TSTYolinkLocal is in the beta store now. Sadly it will not install in the production version slot.
YoLinkTest is still the only title in non-production and it wont let me install over production Yolink slot. I do recall I had my fair share of issues getting some of my plugins to stick in both non and production stores too. I never did figure out the rhyme or reason. _Tim
I am only seeing Yolink test in non-production. Will the new local plugin install in the same slot as yolink production is in or will this require pointing all programs to the new node?
I received an email this morning, the Local hub is back in stock. $199. Mine will be here by the weekend.
I have experienced the same problem as @sjenkins with saving programs when using anything but port 8443. I have also experienced a couple of random, reboots. As well as random plugins failing and restarting and notices about the portal being offline. I have also had Alexa complain that the "hub" is offline when asking her to turn on ISY devices and programs. These things are not frequent and unfortunately by the time I get to log in to download logs they have already refreshed. I was hoping others were having the same issue but it looks like my experience may be a one-off.
I am experiencing similar but a bit different results. I cannot log into into AC with finder on 8080 LAN, it wont even try I can log into AC with finder on 80 LAN I get the XML Parse errors. I can log into 8443 LAN with no parse errors. I have rebooted numerous times. Other than that, the install went beautifully. Thanks UDI team! -Tim
That is just it, Where do I find the logs? I do not see anywhere in UD Mobile anything that indicates access to logs.
I have a new Samsung android phone with the latest software/fw. Installed UD mobile. Works fine. Set up geofence and enabled both buttons (UD Mobile Location Services and Experimental). Set permissions etc. but it will not send notification to ISY (eISY). It worked fine on my old phones... I need help with capturing the logs that you may need to help. I cannot figure out how to get or copy them. Any help would be appreciated. -Tim
+1 once the hubs are available.
v1.0.6 Fixed renaming nodes on the fly on 03/09/2025
Fixed renaming nodes on the fly in v1.0.6
@EricBarish, Are you running non production or production? What version? Please copy and paste your json exactly as it appears in PG3x. Are those the only two that do not change or are there others that do change but just these two do not? Edit: Also, please PM me your log from WebControl832 from PG3x. -Tim
@Panda88, logs PM'ed to you. Thanks in advance! -Tim
v1.0.5 Fixed UoM ending subset 02/18/2025
My apologies. 832 was my third plugin, 8 was the second. Since 832 operates completely different than 8 I didn't want to publish over 8 and force anyone that was happy with 8 to redo their whole setup. I am glad you got both instances up and running. -Tim
Hi @dbwarner5, Are you running WebControl8 or WEbControl832 from the beta store. I just installed 1.0.4 from beta (webcontrol832) then went to production, the slot with the beta was available to install from production. If you verify and you still don't have the option, try installing the beta upgrade then go to production and see if its an option. Right now beta and production are at the same level 1.0.4
Same here. But it still wont, at least as of last weekend Thanks for adding.
Thank you for the help. I will not have time until this coming weekend. But I will post results. Thanks again! -Tim
I can't believe I did not include that info, my apologies. I am on 5.9.1, You are correct, Yolink v1.4.15 Sorry, -Tim
I will look at it tonight. My apologies. -Tim
I had a notification that v1.0.15 was available, Clicked upgrade on node page. When Yolink restarted it displayed 1.0.15 for a second then reverted back to 1.0.4 which was the version I was on before updating. Let me know if you need logs. -Tim
Fixed mapped values for OP nodes in v1.0.4
AudioPlayer will not start after Big Updates 5.9.1
TJF1960 replied to TJF1960's topic in AudioPlayer
No, I run two instances of AudioPlayer, both are stopped along with YouTube. All other plugins are running fine. I need to get home and look at the logs. Thank you for letting me know yours is working! -Tim -
Has anyone else had an issue with AudioPlayer and YouTube plugins not restarting after the big update? I am away so I don't have access to the logs. Tried restarting and also reinstalling but still is stopped. -Tim
