Trying to use the YoLink NS.  I installed it (I know its "non-production") but under the github instructions it says
Credentials needs to be added to configuration. Goto Settings->Account->Advanced Settings -> User Access Credentials
Enter both UAID and SecretKey under configuration - then restart - some times it seems to require 2 restarts to fully get all devices synchronized (I have looked but cannot find pattern"
I don't understand where they are referring too, any ideas?
With the Tesla node server the only way I was able to get Panda88's assistance was through Github.
To get the credential go to app ( 3 vertical bar in upper left corner)
click profile ->Advanced Settings ->User Access Credentials
Copy UAID and Secret Key and insert to config in the Yolink node server - and then restart node server
Hope this helps
It worked!  Thanks...is there a way to change from Celsius to Fahrenheit on the temp sensor?  Not a big deal, but happy to have it working, playing with it now!
Edited by jkraus
BTW both my temp sensor and motion sensor work great!! way toooo cool!!
one other issue I am having with the YoLink  motion sensor in programs it only shows up for "status" and not "control"  so tougher to write programs that use it.
also, where in "configuration" is the temp unit setting, do I need to uninstall and reinstall first?
Edited by jkraus
I restarted NS from dashboard and restarted polyglot. The temp config was then present. Just changed to “F” and restarted AC. Boom.
53 minutes ago, drprm1 said:
Would also like a control setting in garage door to be able to open/close.
It is there already as garage controller - I am using it - it is called toggle - you cannot specify open/close - only toggle
Unfortunately it is not easy to combine in same node, as the GarageDoorSensor is a generic door sensor in the API - I do not know if it is an open/closed door or a garage door when I get the info from the cloud.
What is this node called? I have no “toggle” anywhere.
I’m also using the “finger” to control the garage door. Don’t know how that affects things.
Should toggle be on this page??
On the motion sensor - How would  you use a control? - I can only see it react to a motion event
You cannot really query a motion event - it does not check the sensor - only checks what is cached in the cloud
When I use the insteon motion detection if I use control then it activates my program when it switches on as opposed to a status when it’s on. I’m not an expert in this but The old programs that had it as a control work very well
I need to implement finger - it is not supported yet - I only use the other garage controller - if you are willing to help test it I can add the code for finger
My understanding is the program will execute on a change of state - meaning it will only run once the state change
I'll see if I can figure out how to make it control - it does make sense but I am not 100% how to make it a control vs state
