AT&T to end email-to-text ×
MatterZ? ZMatter?
ZMatter or MatterZ or something else?
43 members have voted
  1. 1. What should we call our Z-Wave/Matter module?
    • MatterZ
      14
    • ZMatter
      26
    • Zomezing elze!
      3
Hello everyone,
Exciting news ... our samples are ready! They will come in two forms: mPCIe (internal to Polisy) and USB (external). In both cases, external antennas are used. Unlike its predecessors, Z-Wave 700 series has exceptional range with external antenna.  So, what should we call it?
  • Like 10
Posted (edited)
Based on the label on the module, it supports Z-Wave and Zigbee. Your suggested name has Matter in it. I suggest Z-MatterZ
Edited by jca001
Hit enter too soon.
Posted (edited)
34 minutes ago, Michel Kohanim said:
Hello everyone,
Matter Z2- I'll take the internal board. Thank you. ?
Edited by lilyoyo1
  • Like 1
4 hours ago, Michel Kohanim said:
Yes.
Thank you all for your input!
Please take my order :-)
DubZ for short.
Several Urban Dictionary entries say it's used to refer to a certain size for wheels (rims) on automobiles, but there are also some other meanings listed that might give one pause.
-Tom
I don’t have a Policy yet; I haven’t decided if I need it. But if you have a Policy Pro, that already has two antennas, is there a place on the Policy Pro’s case for the two other antennas from this device?
I'm wondering a bit about that as well.  If the Z-Wave range is improved, then I might not need antenna for WiFi, as I won't have to move the Polisy to get into close range of older Z-Wave devices (I've already done that, and it sounds like I can restore my current Z-Wave setup to the new Z-Wave/Matter board, so I shouldn't have to do it again).  I'm only going to buy 700 series devices going forward, and presumably some Matter devices when they arrive -- both of which support some version of Network Wide Inclusion.
Posted (edited)
4 hours ago, jfai said:
izy
or
ezy
I had not seen your suggestion, but it is very close to mine.
Edited by asbril
@asbril,
Yes, it will be available at the same time. It might not be as robust as migration from Zooz since we will need to parse binary files from 500 series.
  • Like 1
  • Thanks 1
