Zigbee - Device Support Requests
To keep the posts for "requests" out of the IoX 5.6.3 support thread please put all "requests" here to expand support for Zigbee devices.
Please include:
  • Manufacturer Name
  • Model #
  • Link to sales/availability site(s)
  • Key/desired function support
This is only to begin targeting expansion for supported devices. This is not expected to be a long-term request thread, but certainly to target expansion and support for what the Universal Devices community has in service. In order to get an idea of what devices should be supported as this rolls out.
Please like (press the heart reaction) a suggestion/request rather than duplicating an already suggested device.
On 7/14/2023 at 3:11 PM, Michel Kohanim said:
@vbPhil,
Yes, internal ZMatter is supported.
@TheA2Z,
Currently, light bulbs and plugin modules. But, since all the plumbing is done, support for additional device types is going to be very fast.
@brians,
Switches and sensors are next.
Everyone else, what Zigbee devices do you use?
Shades, such as the one here.
https://www.amazon.com/gp/product/B0BTPQ2VBB/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I would love to see these devices added as I can curently only control them with Hubitat (which I would like to get rid of):
(1)  Sparkleiot Zigbee Smart Plug Outlet
Need On/Off control
https://www.amazon.com/gp/product/B09K5BMTKX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
(2)
Seedan Smart Plug, Zigbee Smart Outlet
Need On/Off control (I have this one added to eisy but it only currently supports "Query." No control)
https://www.amazon.com/gp/product/B08LD7Q81J/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
(3)  Xenon Smart Power Strip, ZigBee Surge Protector with 4 Individually Controlled Smart Outlets and 2 USB Ports
Need On/Off control
https://www.amazon.com/gp/product/B09YPR1W53/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Thank you!
IKEA FYRTUR and TREDANSEN blinds (I believe these are functionally identical):
https://www.ikea.com/us/en/p/fyrtur-black-out-roller-blind-smart-wireless-battery-operated-gray-50417464/
https://www.ikea.com/us/en/p/tredansen-black-out-cellular-blind-smart-wireless-battery-operated-white-50512437/
Controls of full up, full down, and set percent up/down; feedback of blind level when adjusted manually at the blind, and battery level.  Basically: control like a dimmer.
Edited by jec6613
  • Like 4
5 hours ago, MWoods329 said:
FYI, Those both are not Zigbee, they are WiFi. The older FP1 is Zigbee but only was available direct from China. I have both: two FP2 and an FP1.
Zigbee Sprinkler Timer - Tuya Compatible (Garden Hose shutoff)
Name: Giexperience ZIGBEE sprinkler timer
Key Requested Features:
- Turn on Water
- Turn off Water
- Schedule watering sessions including (multiple times, day of week, and duration)
- Measure/report volume of water flow (liters and gallons)
- Tie to weather enabling automatic rain delay
- Manual delay of schedule
Amazon.com: ZIGBEE Sprinkler Timer with Gateway Work for Tuya/Smart Life,Smart Water Timer for Garden Hose,Up to 20 Separate Watering Schedules,Water Flow Meter : Patio, Lawn & Garden
If this is similar to the "@RRoyceus" Shutoff Valve Control request, happy to colapse.
Edited by MMotion
Additional requirements info appended
Michel,
I upgraded to 5.6.4 a few days ago and I just tried the switch again now but not sure if I did it correctly...
I right clicked the device and chose the option to remove it from the zigbee network. The icon then got a red line through it for a while, but returned with the light bulb icon.... so I right clicked it again and chose the Delete option, which did get it out of the UI.
I then did a factory reset on the switch, and re-added it by clicking on Zigbee at the top of the UI and choosing 'Add Zigbee Device" It went through the interview process and added it again with the bulb icon. The device name was "ZB xxxxx.1 Unavailable" (the x's are numbers). In the UI it simply shows a 'Query' button but nothing else. I tried right clicking, choosing zigbee then 'Update' but it made no difference.
At this point i unplugged the power cable and completely rebooted my eisy.
After rebooting and logging back in, now when i select the Zigbee button, at the top are 'water alarm' and 'battery level' boxes but both are empty. Below is a 'set configuration' button, and to the right parameter number & value boxes. At the bottom there are now two buttons 'Query' and 'Write Changes'. In programs I created a test program, but the Zigbee device doesn't show in the list when I try to create an IF based on either status or control.
Oh damn.  I didn’t realized they made that change in version 2.
