Support Thread: IoX v5.8.0 (January 5, 2024)
Where can I get more info on the new features below in 5.8.0? What do they do? How to enable 2nd one if I want to make use of it? I searched both forum and wiki but only results were forum posts listing these release note items.
- Integration of sqlite database for recording events/property changes
- Node property history database - disabled by default
Link to comment
Upgraded IoX to 5.8.0 but now when I launch Polyglot V3 from AC and submit my Login I'm getting this response.
I've seen this in the past but can't remember what it means or how to fix it. Also, this url isn't working either,
https://192.168.1.180:8443/WEB/sysconfig.txt
Any ideas?
Link to comment
Any ideas?
Assuming you're on an eisy, try:  eisy.local:3000/dashboard
Link to comment
No I'm on Polisy.
I also noticed that it wouldn't do a reboot from the AC. Knowing that @Michel Kohanim said do not unplug, I tried a "sudo shutdown -r now" from a PuTTY connection and that fixed it. I can now login to PG3 and Insteon is working from IoX at version 5.8.0.
Link to comment
Upgrade two Polisy and one EISY.  On EISY nothing came up (yes I rebooted when done)
but I could SSH in so I did
and then it rebooted again and everything came up fine
Edited by macjeff
Link to comment
I just updated my system remotely from 5.7.1 to 5.8.0.  Went without a hitch.  I only had to clear java cache and reinstall IoX after the update and reboot.  Not sure what the update afforded me but I like to stay current.
Link to comment
Bump. Are these features just for developers, UDI Support, or for future use? If they're for regular users, where can one get more information on them?
Trying to decide if I want to upgrade.
  • Thanks 1
Link to comment
For me some of the "fixes" were reason enough to press that upgrade button. Seems like you're stuck on the "feature" items that probably do help developers/backend side more than stability of the platform.
Quote
Fixes:
Release notes for: 5.8.0_1 - 01/03/2024
- Fixed reboot on polisy when using ZMatter in original mode
Release notes for: 5.8.0 - 01/01/2024
- Fixed system crash (for Insteon users)
- Fixed subscription causing crash when bombarded
- Misc bug fixes
For your specific questions you might be better off contacting UDI directly through their website (probably ticket option, but sales email might also be an option). Michel has (several times) commented that they're buried in development at this time and not reading the forums as closely as they used to.
https://www.universal-devices.com/contact-us/
or
Link to comment
Upgraded eisy, and the upgrade appeared to complete. But, after the upgrade, I cannot add any new devices. I'm getting the error message "cannot determine device link table address." I've tried a mini remote, an outlet linc, and a lamplinc, and none of them will add. I had no problem adding devices today, before the upgrade. Thoughts? I've tried to reset the devices, and I've tried to reboot the eisy and the powercycled the PLM.
Link to comment
