Administrator Posted January 5 Share Posted January 5 Support thread for issues related to IoX 5.8.0 Link to comment
johnnyt Posted January 5 Share Posted January 5 Where can I get more info on the new features below in 5.8.0? What do they do? How to enable 2nd one if I want to make use of it? I searched both forum and wiki but only results were forum posts listing these release note items. - Integration of sqlite database for recording events/property changes - Node property history database - disabled by default 1 Link to comment
vbPhil Posted January 5 Share Posted January 5 Upgraded IoX to 5.8.0 but now when I launch Polyglot V3 from AC and submit my Login I'm getting this response. I've seen this in the past but can't remember what it means or how to fix it. Also, this url isn't working either, https://192.168.1.180:8443/WEB/sysconfig.txt Any ideas? Link to comment
skunkiechris Posted January 5 Share Posted January 5 First reboot, then power cycle after reboot, both resulted in being stuck on Initializing subscription. Link to comment
Techman Posted January 5 Share Posted January 5 31 minutes ago, vbPhil said: Upgraded IoX to 5.8.0 but now when I launch Polyglot V3 from AC and submit my Login I'm getting this response. I've seen this in the past but can't remember what it means or how to fix it. Also, this url isn't working either, https://192.168.1.180:8443/WEB/sysconfig.txt Any ideas? Assuming you're on an eisy, try: eisy.local:3000/dashboard Link to comment
vbPhil Posted January 5 Share Posted January 5 1 hour ago, Techman said: Assuming you're on an eisy, try: eisy.local:3000/dashboard No I'm on Polisy. I also noticed that it wouldn't do a reboot from the AC. Knowing that @Michel Kohanim said do not unplug, I tried a "sudo shutdown -r now" from a PuTTY connection and that fixed it. I can now login to PG3 and Insteon is working from IoX at version 5.8.0. 1 Link to comment
rahnee Posted January 5 Share Posted January 5 (edited) Updated and now I cannot get to my Polyglot. Polisy. Rebooted multiple times, no resolved. Browser says "cannot connect to server". Update: @Michel Kohanim was able to resolve the issue. Edited January 5 by rahnee update 1 Link to comment
gviliunas Posted January 5 Share Posted January 5 Upgraded with no issues on Polisy. Thanks UDI Team!! 1 Link to comment
btreinders Posted January 6 Share Posted January 6 No issues on my Polisy. Thank you! Hope it fixes the random disconnect/connected messages for plugins. Link to comment
Athlon Posted January 6 Share Posted January 6 Updated my Polisy without a hitch - thank you. Link to comment
Steve L Posted January 7 Share Posted January 7 Upgraded EISY - worked fine. As usual, I had to delete and reinstall the Java admin panel. Link to comment
CGohring Posted January 8 Share Posted January 8 Upgraded EISY - No issues once I remembered to delete and reinstall the Java admin panel. Link to comment
JTsao Posted January 8 Share Posted January 8 Upgraded EISY - all appears well... not sure why, but I did not have to re-install the admin panel Link to comment
macjeff Posted January 8 Share Posted January 8 (edited) Upgrade two Polisy and one EISY. On EISY nothing came up (yes I rebooted when done) but I could SSH in so I did sudo shutdown -r now and then it rebooted again and everything came up fine Edited January 8 by macjeff Link to comment
slimypizza Posted January 8 Share Posted January 8 I just updated my system remotely from 5.7.1 to 5.8.0. Went without a hitch. I only had to clear java cache and reinstall IoX after the update and reboot. Not sure what the update afforded me but I like to stay current. Link to comment
johnnyt Posted January 8 Share Posted January 8 On 1/5/2024 at 1:06 PM, johnnyt said: Where can I get more info on the new features below in 5.8.0? What do they do? How to enable 2nd one if I want to make use of it? I searched both forum and wiki but only results were forum posts listing these release note items. - Integration of sqlite database for recording events/property changes - Node property history database - disabled by default Bump. Are these features just for developers, UDI Support, or for future use? If they're for regular users, where can one get more information on them? Trying to decide if I want to upgrade. 1 Link to comment
dbwarner5 Posted January 8 Share Posted January 8 Upgraded on Polisy w/o any issues... Thanks @Michel Kohanim Link to comment
Geddy Posted January 8 Share Posted January 8 2 hours ago, johnnyt said: Trying to decide if I want to upgrade. For me some of the "fixes" were reason enough to press that upgrade button. Seems like you're stuck on the "feature" items that probably do help developers/backend side more than stability of the platform. Quote Fixes: Release notes for: 5.8.0_1 - 01/03/2024 - Fixed reboot on polisy when using ZMatter in original mode Release notes for: 5.8.0 - 01/01/2024 - Fixed system crash (for Insteon users) - Fixed subscription causing crash when bombarded - Misc bug fixes For your specific questions you might be better off contacting UDI directly through their website (probably ticket option, but sales email might also be an option). Michel has (several times) commented that they're buried in development at this time and not reading the forums as closely as they used to. https://www.universal-devices.com/contact-us/ or https://www.universal-devices.com/my-tickets Link to comment
Mark Sanctuary Posted January 10 Share Posted January 10 Initiated update, rebooted when prompted, cleared Java cache, logged back in. Updated Polisy without issues. Link to comment
Ryan S Posted January 11 Share Posted January 11 Updated Polisy from 5.7.1 to 5.8.0_1 with no issues along side with FreeBSD 13.2p9. Just have patience as it took 16 mins to complete and receive the notification to reboot. 1 Link to comment
ddaggett1 Posted January 12 Share Posted January 12 Upgraded eisy, and the upgrade appeared to complete. But, after the upgrade, I cannot add any new devices. I'm getting the error message "cannot determine device link table address." I've tried a mini remote, an outlet linc, and a lamplinc, and none of them will add. I had no problem adding devices today, before the upgrade. Thoughts? I've tried to reset the devices, and I've tried to reboot the eisy and the powercycled the PLM. Link to comment
DennisC Posted January 12 Share Posted January 12 Try removing power from eisy for a few minutes. Link to comment
