January 14, 20251 yr It's been a while since I've programmed an ISY ad we moved and were in a rental for a while. Now trying to setup new house. Am I just missing it or did they remove the scene Copy function to copy between controllers within a scene? I'm stumped and setting up scenes is God awful without it. And don't get me started but I tried programming in the app. That was beyond miserable. I hope something better is planned once the AC is deprecated.
January 14, 20251 yr Not sure exactly what you're looking to do. You can right click on the scene name and see the options. You can also "click and drag" devices in to scenes as well as scene members.
January 14, 20251 yr 4 hours ago, BamBamF16 said: Am I just missing it or did they remove the scene Copy function to copy between controllers within a scene? Yes, scene copy was removed in the 5.x update years ago. Due to the advanced options of including z-wave into IoX configuring I believe that was an option removed at the time. Now scenes need to be setup a little different, but I think that’s been outlined in updated wiki. I’m not a bit user of scenes so can’t give exact differences, but think there is updated info in the wiki or certainly elsewhere on the forums….maybe try Google site search for more information and help
January 16, 20251 yr On 1/13/2025 at 7:34 PM, BamBamF16 said: It's been a while since I've programmed an ISY ad we moved and were in a rental for a while. Now trying to setup new house. Am I just missing it or did they remove the scene Copy function to copy between controllers within a scene? I'm stumped and setting up scenes is God awful without it. And don't get me started but I tried programming in the app. That was beyond miserable. I hope something better is planned once the AC is deprecated. Since you're setting up a new home, you could add all responders to the scene first, configure the scene with the attributes you want. Then add your controllers after you're done. This will automatically configure the controllers for the scene
