Support Thread: IoX v5.9.1 (2/10/25)
UD mobile only on Android correct no iOS?
upgraded wired polisy here..no problems.. alll working as advertised.
it did go through all my plugins and re-install them all...so it took a while for all that to work again.
Its also iOS.  On the App Store.
eisy upgrade from 5.8.4 to 5.9.1 went smoothly; took 20 minutes.
After the upgrade PG3x initially showed ver 3.3.18 and Frontend 3.2.27.  A power cycle of the eisy brought both to 3.3.18.
Everything seems to working fine, including 14 Plugins.
Well done UDI!
My Polisy update went fine.
I'm trying to decode Michel's wifi notice.
Polisy does not support Matter when connected using WiFi.
So does wifi enabled Matter devices direct connect to Polisy, therefore the wifi can't be used to connect Polisy to the network. Have I got that right?
How is the eisy different?
Sounds about right. If you read the other part of the notice, you'll also see that the wifi performance of the eisy had to be degraded to 802.11a/g to achieve Matter functionality. Since the main difference between the eisy and the Polisy is the hardware platform, it seems that getting Matter to work over wifi was difficult on the eisy and impossible on the Polisy. It seems that when you want Matter over wifi, avoid problems by connecting your controller with a wired connection. I don't know how then using your own wifi router for Matter connectivity might be difficult or not.
Edited by Guy Lavoie
I have not seen the new version in the Apple App Store.  What is the version shown.  I'm on Version 1.1.88.
Edited by TUhl01
That's the latest on the App Store, and AFAICT it lacks the ability to add Matter devices.
Wired Polisy, installation took about 15 minutes to complete. All items for upgrade visible and system working same as before. Now waiting for Iphone UT mobile upgrade to check out matter.
Upgrade completed with no problem.  Only issue I encountered is the eisy got a different dhcp IP assignment after upgrade.  Entire process took about 15  minutes.
-Xathros
Edited by Xathros
Did you have a reservation in your router prior to the upgrade?  If so, that's unexpected, and something I'll want to look out for when I upgrade soon.
-Tom
There's a beta version of UD Mobile that was released today through TestFlight. That version (1.2.1 (224)) does appear to have some level of Matter enabled. I have no idea what the formal release plans or timing look like for general updates through the iOS App Store, but I'm sure the UD Team will push it out when it's ready.
Followed the instructions, all went well,  it does take a bit to update & re-boot, I had to re-boot again.  Clear Java cache so you get the updated admin console and that's about it.  All seems well so far.   -Grant
I just downloaded the beta version in TestFlight that is ready to install. Will the current functionality be impacted?  All is working great and don’t want to get into trouble.  I just did a backup.  Did you have any issues upon installing the beta version with the current functionality?
Unfortunately, I really can't say - other than installing the software (which seemed uneventful), I haven't tested the UD Mobile beta or the new Matter functionality at all yet.  But I got the sense that some folks were waiting on an iOS update to do some testing, and they may not have been aware of this option to get started.
-Tom
I did. Seems my Unifi controller sees it as a new device after the upgrade. Had to reset the reservation. No big deal, just unexpected.
-Xath
So migrated to Eisy after bricking my Polisy with the upgrade.  All seems to be working except for one program which I cant figure out why.  The program shows green which means the If statement is true but the ERV doesnt turn off after the 15 min wait period.  Any thoughts?
Airthings AQ Normal - [ID 006D][Parent 0001]
        'Airthings Controller / Main Level' CO₂ Level <= 775.0 PPM
    And 'Airthings Controller / Main Level' VOC <= 225.0
        Repeat Every  1 hour
           Set 'ERV' On
           Wait  15 minutes
           Set 'ERV' Off
        Set 'ERV' On
Edited by pjjameso
        Repeat Every  1 hour
           Set 'ERV' On
           Wait  15 minutes
           Set 'ERV' Off
        Set 'ERV' On
That program should never work.  Every time the co2 level or voc level update, the program will terminate and start over.
I would use two Programs, one that sets up the Repeat every hour and calls another Program that tests and sets the ERV on or off.
I use a similar approach for my house humidity control. My humidity test is rather complex as it uses forecast temperatures and internal humidity levels to dry out the house if needed for extreme cold temperatures to avoid window fogging/freezing. Welcome to Canada!
I have updated my Eisy to 5.9.1 . Email notifications are no longer working, other features seem to be working ok.  In the AC, if I go to Configuration > Emails/Notifications > Settings/Groups and click on Test, several seconds go by and then a window pops up with "Mail server failure" and "[[SMTP_ERRORS--1]]". I am using SMTP server smtp.gmail.com, and my Google App password. I have verified the Google App password is working to send emails with other applications.
I have opened a ticket.
I'd check and perhaps extend your timeout to 2000, worked for me.
-Tom
I had the same issue - see my post earlier about DHCP changes with the OS update.
1 hour ago, pjjameso said:
Airthings AQ Normal - [ID 006D][Parent 0001]  DISABLED
           Set 'ERV' On
           Wait  15 minutes
           Set 'ERV' Off
        Set 'ERV' On
Program 2  Run at Startup
       blank
        Repeat Every  1 hour
           Run if Program Airthings AQ Normal
And you will need to manually run the second program "run then" to get it started.  Unless you reboot ISY, then it will run automatically.  A "run at startup" program with a blank "if" will execute "then" at startup.
Edited by apostolakisl
Thanks. I had to increase the timeout to 20,000 (I tried a curl at Michael's suggestion, and that was taking 12 seconds, so I increased to 20 to be on the safe side.).
