EISY 6.0.5
Update from 6.0.4 to 6.0.5 went smoothly. No issues for me
I just upgraded and I'm stuck ... Window opens then closes IoX launcher when you select OK ...
I do not understand what this means ... where do I get a different Admin Console ?
If the suggestion from @larryllix does not work, make sure you have rebooted your EISY.
16 hours ago, jim_ said:
Thanks larryllix,
I've never had to clear Java before for the EISY
I don't know of anything else that uses java anymore except maybe a few vehicle O/Ses.
Things did not go well. 6.0.4 to 6.0.5. Seemed to go well at first glance. But opening java ac takes forever. None of my insteon nodes populate. programs aren't running. Can't open java ac programs page, it times out and gives error. Can't open programs page from ud mobile, gives an error. Can't open eisy ui. It gets a response from eisy as evidenced by the non-secure icon showing open in the browser, then it just spins forever. I tried a reboot from an ssh session. That didn't fix anything. I also did a java update and deleted the cache and all which did not work (as expected since problems all around, not just java).
Let us know where you end up - I also had problems and Michel remotely fixed my eisy, but I am now on version 6.0.4 - he also asked me for my Z-wave device count and briefly mentioned a z-wave issue (but I don't know specifically what that was) - so I'm wondering when it will be safe to attempt a future update - I am not going to try until I hear that the issues, whatever they are, are fixed
So it seems everything went okay except PG3 still say 6.0. Have rebooted, closed the browser and relaunched using eisy.local. Still same result. Thoughts?
@pjjameso what do you see if you go to the PG dashboard via eisy_ui? https://eisy.local then click the top left and seelct "dashboard". The best way to get to the PG3 dashboard now is considered via eisy_ui. There have been some changes with how plugins are connecting and using eisy_ui keeps things connecting "correctly" for some plugins. If you're going to the PG3 via the port 3000 connection it could show some plugins disconnected or stopped when viewing.
Have you forced a refresh on the web page? Could be a cache value being displayed.
  • 3 weeks later...
I upgraded from 6.03 to 6.05. All went well except my 1 matter device (a motion sensor) is not working. Michel’s initial post says if this happens to do a restore. If I restore, won’t I be back on 6.03? Do I restore iOS, pg3 or both? Please advise.
I was not s sure that “restre” was in reference to going back to an earlier version. I thought it might be in reference to reatoring the individual device. If on right-clicks on it, there is some type of option to re*interview the matter device.
I would be inclined to try that.
Recently got the 6.0.5 update. My Z-Wave no longer works. "I get !ZMatter Z-Wave not responding"
Under the configuration tab, is the zwave box set to ON
Edited by Techman
Have you tried removing power from your eisy for 30 seconds, then reconnect the power and turn it back on?
