May 2May 2 HiA new release of the Yolink node server (ver 1.8.45). There is a lot of changes below the surface to handle the Yolink API better. Node should be faster and take less resources.Added quite a few devices (Most of the newly released devices and Thermostat2) and updated a few sensor nodes (The Yolink API was updated - THsensor and LeakSensor ) . Note, the new LeakControllers behave a little different than other devices - they go to sleep. Given this one should use the YoLink specified limits to trigger events. Also, they cannot sleep when added.YoLink schedules are now in separate child nodes.As this is a major update, so devices may not work - I have tested the ones I own, but there are derivatives of the devices and a few I do not own, so please help test and let me know if something is not work correctlyNote, there is a minor issue with the Dimmer - there is an API problem YoLink is working to fix - I hope once they release the fix the issue is gone, but I have not received the fix yet (probably low priority as it only related to controlling some attributes) - nothing critical Edited May 2May 2 by Panda88 missed info
May 2May 2 The update installed fine will no errors that I saw. All devices are online in the admin panel. I did have to click update on the temperature sensor to get the current readings. The temperatures would have probably updated on their own if I waited.A schedules child node was added in the admin panel to both water valves but nothing else.Thanks for working on this.
May 2May 2 5 hours ago, Panda88 said:not all devices have schedules :-)I didn't know any of them did until last night. However, I discovered today the update removed the open and close command from any valve manipulator program, so none of the programs functioned. I added an open or close command. Works fine now.Then, I went through all water programs. The water valve variable-setting programs changed "Manipulator State" to "Manipulator State (legacy)." I changed them all to "Manipulator State." I also had to correct open vs closed in those programs. I didn't test to see if "legacy" worked. I had to fix the open/close anyway, so I changed both lines in the programs. Works fine now, too.
May 3May 3 Author Legacy has been there a while :-) (previous release had it also) - the two are the same - It is to be able to assign the ST parameter to the main function of the node - not just online - This is to show in UDImobile and also an issue with how the system handles variablesI tried to reduce the number of functions (some a doing the same) as they take u a lot of space on AC Is open/close swapped in the manipulator?
May 3May 3 I never noticed the "legacy" before, but I don't usually go poking around old programs that work. Open/close are not swapped.In this program, Open and Closed were simply removed after the update. So, run then or else did nothing until I added them back.Water valves - [ID 0037][Parent 0006]If- No Conditions - (To add one, press 'Schedule' or 'Condition')ThenSet 'Water leaks / Cold Water Valve' OpenWait 5 secondsSet 'Water leaks / Hot Water Valve' OpenElseSet 'Water leaks / Cold Water Valve' ClosedWait 5 secondsSet 'Water leaks / Hot Water Valve' ClosedI have four of these programs to set the open or close variable for two valves. I can't swear to it, but I think the two open programs changed to Manipulator State is Closed. So, the variable never changed. This is where I changed from legacy manipulator state, also.Cold valve open variable - [ID 003A][Parent 0006]If'Water leaks / Cold Water Valve' Manipulator State is OpenThen$Cold_water_valve = 1Else- No Actions - (To add one, press 'Action')Like I said, I was poking at four programs, so I can't be sure about that. Regardless, the two variables weren't changing until I fixed them. However, in the first program, I'm sure of the change that broke the program. Edited May 3May 3 by auger66
May 3May 3 I am seeing some unexpected things since updating to the latest release. My Local hub now says "Alert" under "Supply Status" in the devices View, and in the Current State when listing devices via the Admin Console. I don't recall seeing that before (but perhaps just missed it) and am not quite sure how to address that if it's a real issue.The Current State and multiple other values appearing in the Admin Console device view show as "Unknown" for several devices and device types, including my Flexswitch devices (YS5709-UC) and some but not all of my temp/humidity sensors (YS8006-UC). If I manually update the device status for those devices via the Admin Console, the values seem to get updated but many return to show "Unknown" statuses again shortly after update. When updating status manually via Admin Console, I occasionally get "TCP client read response failed" messages (NS-70-YolinkLocal).
May 3May 3 The upgrade installed without issue but some of my T\H Sensors are showing humidity is not supported, and the value always shows as 98. It appears the UOM is being set to 25 on the ones that don't work and is 51 on the ones reporting humidity.I have leak sensors, door open\close, and motion sensors and so far these seem to be working.TS_Garage is not working below but TS_CrawSpace is working like before the upgrade. All my sensors worked properly on the old plug-in. Edited May 3May 3 by JRissmiller Added screenshots
May 3May 3 Author 11 hours ago, auger66 said:I never noticed the "legacy" before, but I don't usually go poking around old programs that work. Open/close are not swapped.In this program, Open and Closed were simply removed after the update. So, run then or else did nothing until I added them back.Water valves - [ID 0037][Parent 0006]If- No Conditions - (To add one, press 'Schedule' or 'Condition')ThenSet 'Water leaks / Cold Water Valve' OpenWait 5 secondsSet 'Water leaks / Hot Water Valve' OpenElseSet 'Water leaks / Cold Water Valve' ClosedWait 5 secondsSet 'Water leaks / Hot Water Valve' ClosedI have four of these programs to set the open or close variable for two valves. I can't swear to it, but I think the two open programs changed to Manipulator State is Closed. So, the variable never changed. This is where I changed from legacy manipulator state, also.Cold valve open variable - [ID 003A][Parent 0006]If'Water leaks / Cold Water Valve' Manipulator State is OpenThen$Cold_water_valve = 1Else- No Actions - (To add one, press 'Action')Like I said, I was poking at four programs, so I can't be sure about that. Regardless, the two variables weren't changing until I fixed them. However, in the first program, I'm sure of the change that broke the program.Do you need anything changed? I do not 100% follow - if yes, can you send a log with debug enabled (just PM me)1 hour ago, JRissmiller said:The upgrade installed without issue but some of my T\H Sensors are showing humidity is not supported, and the value always shows as 98. It appears the UOM is being set to 25 on the ones that don't work and is 51 on the ones reporting humidity.I have leak sensors, door open\close, and motion sensors and so far these seem to be working.TS_Garage is not working below but TS_CrawSpace is working like before the upgrade. All my sensors worked properly on the old plug-in.Can you send me a log with debug enabled - There were changes to THsensor and LeakSensor as new functionality we enabled in the API (and I wanted to include those) - There is likely a return from the API I do not know of that may cause the unknow state to appear (if the device is not reporting its value in this return _ I just need to ignore it missing)Can you validate the device types you have - the node sees the garage sensor as T only - look at the name - They must have different types YSXXXX-UC in the app ... area Edited May 3May 3 by Panda88 Need more info on the device types
May 3May 3 Author 2 hours ago, dwengrovitz said:I am seeing some unexpected things since updating to the latest release.My Local hub now says "Alert" under "Supply Status" in the devices View, and in the Current State when listing devices via the Admin Console. I don't recall seeing that before (but perhaps just missed it) and am not quite sure how to address that if it's a real issue.The Current State and multiple other values appearing in the Admin Console device view show as "Unknown" for several devices and device types, including my Flexswitch devices (YS5709-UC) and some but not all of my temp/humidity sensors (YS8006-UC). If I manually update the device status for those devices via the Admin Console, the values seem to get updated but many return to show "Unknown" statuses again shortly after update.When updating status manually via Admin Console, I occasionally get "TCP client read response failed" messages (NS-70-YolinkLocal).Can you send me a log with debug enabled. It may be I mapped alert wrong - it is likely charging. I did add new functionality in the localHub to allow it to detect if it is operating of its own battery or by power from outlet, but it seems Alert is not the correct message. I do not own a flex switch - I should be able to identify the issue from the log I think the last NS-70 message is beyond the node server layer but I'll check Edited May 3May 3 by Panda88
May 3May 3 34 minutes ago, Panda88 said:Do you need anything changed? I do not 100% follow - if yes, can you send a log with debug enabled (just PM me)No, everything is fine. I just wanted to give feedback let and others know the update altered my programs. After I "unaltered" them, it's all good.My temperature sensor doesn't update the temperature, among other values, unless I hit update on the admin console, so that's a bit of problem. Edited May 3May 3 by auger66
May 3May 3 Here are a couple of screen shots of before and after I press the update button on the admin console. Something weird is going on with the last status update time.After pressing the update status button, the time moves a few hours into the future. The status update time before pressing update status is correct. Edited May 3May 3 by auger66
May 3May 3 Author can you send me a log with debug enabled. there must be a bug somewhere but i need to know what the device reported you can pm it to me. enable debug under logging. update sensor —set log back to info and download log - just the pg3 logi did find a bug but nit related to this
May 4May 4 @Panda88 - I tried sending you a debug log with some screenshots, but the UD message system just said "Panda88 cannot receive messages."
May 4May 4 @Panda88 I tried to send my logs but I'm not sure they went. I'll try one more time. UD system might be having issues.
May 4May 4 Author I found a few of the bugs - I still need to figure out the time jump issue - I'll try to release a patch release once I have the last bug ironed out
May 4May 4 Author I think I can receive messages again - hit a limit On 5/3/2026 at 9:05 AM, dwengrovitz said:I am seeing some unexpected things since updating to the latest release.My Local hub now says "Alert" under "Supply Status" in the devices View, and in the Current State when listing devices via the Admin Console. I don't recall seeing that before (but perhaps just missed it) and am not quite sure how to address that if it's a real issue.The Current State and multiple other values appearing in the Admin Console device view show as "Unknown" for several devices and device types, including my Flexswitch devices (YS5709-UC) and some but not all of my temp/humidity sensors (YS8006-UC). If I manually update the device status for those devices via the Admin Console, the values seem to get updated but many return to show "Unknown" statuses again shortly after update.When updating status manually via Admin Console, I occasionally get "TCP client read response failed" messages (NS-70-YolinkLocal).Can you send me a log with debug enabled - and let me know when you pressed the update (roughly in time)Also if you can turn the switch on and off in the log Found a bug for Alert
May 7May 7 Prior to the new update I had 39 nodes listed under PG3 Yolink. Post update I have only 18 nodes recognized but all are on line in the Yolink app. I have two hubs, missing are several temp sensors while some are present, also door lock, wall plug, and one motion sensor with one motion sensor listed. So a mixed bag of some present and some missing.Any insight and advise would be appreciated. Attached is the PG3 error log if that will be of value.ThanksStan pg3_5-7-2026_33140_PM.zip
Thursday at 10:38 PM5 days Author 3 hours ago, Stan said:Prior to the new update I had 39 nodes listed under PG3 Yolink. Post update I have only 18 nodes recognized but all are on line in the Yolink app. I have two hubs, missing are several temp sensors while some are present, also door lock, wall plug, and one motion sensor with one motion sensor listed. So a mixed bag of some present and some missing.Any insight and advise would be appreciated. Attached is the PG3 error log if that will be of value.ThanksStanpg3_5-7-2026_33140_PM.zipCan you enable debug and send me the node log (not the PG3 log) - that will help me understand the issue
Friday at 04:15 PM5 days Author Sorry - no - click download log - make sure debug is enabledBest if you can restart after enabling debug, wait a little, and then click Download Log
Friday at 07:31 PM5 days Sorry for my lacking skill set, little out my element here.I hope this is the info you need. Again thank you.SS YoLink_5-8-2026_32713_PM.zip
Saturday at 02:34 AM4 days Author thanks - that works - I had a bug in the old Lock code (I no longer have that device) - I'll fix, and release a new updated version - hopefully you can help test
Saturday at 06:43 PM4 days Author released version 1.8.50 - minor bug fixesI believe I have addressed reported issues - Only known issues is Dimmers and Switches report an ERROR in Log - Yolink is working to fix this - it is an docmented but non-functional API to control attributes - should not matter (should allow controlling the LEDs on the devices) Online reporting has been updated - there was a bug it would report offline if a state did not change for 4 hours (It should only be if reporting did not update for 4 hours)I now ignore historyReports from some newer sensors (it was the root cause for reporting offline/Unknown) - Data is not used anywayI have updated the Fob behavior a little to make sure it identifies remotes with one press type and remotes with 2 press types (LONG and SHORT press)I do not have the old lock anymore so I cannot test it - let me know if okI do not have a flex switch so I cannot test it - let me know if ok Edited Saturday at 06:51 PM4 days by Panda88
