6 hours ago6 hr If anyone is having issues with eisy-ui not working & eisy being offline, there was an issue with the initial release. The problem was that eisy-ui would not start if there was exactly one plugin installed.To recover from this, eisy-ui needs to be updated to 1.2.1.There are 2 ways; With the admin console, or through ssh.To update using the admin console:Start the IoX launcher, click add, enter https://eisy.local:8443/descAt the login prompt, use the user admin (default password is admin)Then go to configuration and click on "Upgrade packages"To update using ssh:Open a command prompt and enter these commands;ssh admin@eisy.local (Password is admin)sudo pkg install eisyuisudo service eisyui restartWorkaround:It is possible to fix this problem without updating.Go to PG3x at https://eisy.local:3000Login using admin/adminYou should have exactly one plugin. Just install any free plugin. eisy-ui should start and within one minute.
5 hours ago5 hr Upgrade went well, took about 10 min. Admin console comes up ok (after clearing cache and data). I have the same issue in EISY UI "Nearly every program in eisy-ui displayed “Error loading data, mostly in the "Then" lines”, although the same programs worked correctly in Admin Console."Thanks,John
5 hours ago5 hr Upgrade to 6.1.1 and 14.4 went smoothly and quickly. Thank you, @Michel Kohanim and company.
2 hours ago2 hr 3 hours ago, JSchumann said:Upgrade went well, took about 10 min. Admin console comes up ok (after clearing cache and data). I have the same issue in EISY UI "Nearly every program in eisy-ui displayed “Error loading data, mostly in the "Then" lines”, although the same programs worked correctly in Admin Console."Thanks,John
