IoX 6.1.1 let's discuss it!
If anyone is having issues with eisy-ui not working & eisy being offline, there was an issue with the initial release. The problem was that eisy-ui would not start if there was exactly one plugin installed.
To recover from this, eisy-ui needs to be updated to 1.2.1.
There are 2 ways; With the admin console, or through ssh.
To update using the admin console:
Start the IoX launcher, click add, enter https://eisy.local:8443/desc
At the login prompt, use the user admin (default password is admin)
Then go to configuration and click on "Upgrade packages"
To update using ssh:
Open a command prompt and enter these commands;
ssh admin@eisy.local
(Password is admin)
sudo pkg install eisyui
sudo service eisyui restart
Workaround:
It is possible to fix this problem without updating.
Go to PG3x at https://eisy.local:3000
Login using admin/admin
You should have exactly one plugin. Just install any free plugin. eisy-ui should start and within one minute.
Upgrade went well, took about 10 min. Admin console comes up ok (after clearing cache and data). I have the same issue in EISY UI "Nearly every program in eisy-ui displayed “Error loading data, mostly in the "Then" lines”, although the same programs worked correctly in Admin Console."
John
John
