August 19Aug 19 Hi @Javi , I see these errors on sync after installing the major update today.They don’t seem to be causing any functionality issues.Can you help me understand what they are?Thanks!
August 19Aug 19 Solution It is a benign error, invalid parameter name mapping for i3Keypad. Will need to be fixed in the next firmware update.
August 19Aug 19 I'm not terribly technical, but my update went fine, took about 20 minutes to get the reboot dialog. Slick and quick!
August 20Aug 20 I have the same type of error with insteon devices upon sync. Other than that have not had any issues with the upgrade with the exception of not being able to use the java app. I retrieved the newest app from the site but get the error "this version of the admin console is not compatible etc.". The admin console I downloaded is 6.0.5. Has the java been deprecated already? Edited August 20Aug 20 by CRaube Disregard on the java app. went into the java console and deleted the apps. Thought I had checked the box earlier. All good with that.
August 20Aug 20 28 minutes ago, CRaube said:I retrieved the newest app from the site but get the error "this version of the admin console is not compatible etc.". The admin console I downloaded is 6.0.5. Has the java been deprecated already?You need to clear the java cache before getting back into it. The error you're getting is indication of that. Be sure you select all 3 boxes in the process. If on Windows look for "Configure Java" -> "Settings" -> "Delete Files"
August 20Aug 20 You need to clear your java cache, be sure to check all 3 boxes, then download the IoX Launcher from here:https://isy.universal-devices.com/start.jnlp
Sunday at 08:44 PM1 day I noticed that my State Variables in UDM are not updating in real time. Not sure if it's a UDM or eisy-ui issue
13 hours ago13 hr To be sure, this happens when changing a variable from UD Mobile, at startup, or some other expected trigger?
11 hours ago11 hr When a state variable changes value in eisy-ui UDM doesn't see the change in real time. If I open the program in UDM that effects the state variable then it updates. Sometimes it will update but with a lag time.
10 hours ago10 hr Ok, I can't replicate and have no other reports so likely isolated to you controller. How long is the delay, a second, a few seconds, more than 10 seconds?Does the same happen in eisy-ui, when updated from UD Mobile?Does this happen for node status also?Does reboot correct the issue?
9 hours ago9 hr I was able to narrow it down:The favorites in UDM that show state variables aren't updatingIf I open the the device dashboard for the favorite in UDM, which shows the correct state value, then the favorite will update to the correct state variableThe node status show correctlyI'm using Android Edited 9 hours ago9 hr by Techman
1 hour ago1 hr @Javi I did a UDM restore from a previous backup and that appears to have resolved the issue. I'll keep an eye on it for the next few days
