Wednesday at 10:08 PM4 days Based on the release notes, no, this would not apply to the Polisy. I believe I read others saying they tried to update their Polisy and nothing changed for them. https://forum.universal-devices.com/topic/46914-os-144-release-is-now-available/
Wednesday at 10:43 PM4 days Solution It does work, but the update must be done manually, by accessing the Polisy by ssh. Then you do:sudo pkg upgrade udx isy eisyui pg3xThis method was suggested by Michel at UDI. I've successfully upgraded two Polisys this way. Remember the release announcement warning:If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Edited Thursday at 01:16 AM4 days by Guy Lavoie
Thursday at 05:10 PM3 days Author Do you know if this will be enabled/allowed from the Jave console in the future. I'm not that familiar with ssh control of Policy. I get this error when trying that upgrade command. No repositories are enabled. (My OS is 14.3) Edited Thursday at 05:14 PM3 days by EJones01
Thursday at 05:24 PM3 days Have a look here, on the 4th page of the thread. there is a command to do first:
Saturday at 01:15 AM2 days This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.
Saturday at 01:16 AM2 days Just now, brians said:This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.That's for the Polisy only.
Saturday at 01:21 AM2 days 3 minutes ago, Guy Lavoie said:for the Polisy only.4 minutes ago, Guy Lavoie said:That's for the Polisy only.Ok so I have a polisy do I use ssh to upgrade or not. The instructions are kinda ambiguous I think I see now that is a warning for older kernels Edited Saturday at 01:24 AM2 days by brians
Saturday at 01:42 AM2 days Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.
Saturday at 09:20 PM1 day 19 hours ago, Guy Lavoie said:Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.I ran the command, been a while but I get this when connecting to the web...Should I just be patient now?Uploading Attachment...
Saturday at 09:32 PM1 day That might be normal, I saw something similar during the command line update, probably because the Polisy cannot be fully upgraded to freebsd 14.4. I'd reboot it and then check out that everything is ok.
Saturday at 09:33 PM1 day ok so that system busy went away.. I removed java cache and reinstalled and IoX seems to be on lastest version..Gonna restart now hoping for the best ;)
Saturday at 09:55 PM1 day Ok well that was nerve-wracking.. reboot didn't work from gui, so I did from ssh but was running a continous ping and didnt see drop so presumed crashed.. after a while I hard rebooted Polisy by removing power and it eventually all came back up.I did not have to use the command to set the repo when I upgraded unlike others.I got the impression that we will have to ssh upgrade polisy each time and possibly require to run command to set repo in future ?
Saturday at 10:29 PM1 day 31 minutes ago, brians said:I got the impression that we will have to ssh upgrade polisy each time and possibly require to run command to set repo in future ?Very likely. I updated 3 Polisys this way and didn't need to set the repository on any of them. Not sure why it happens for some cases.
