USB PLM
I have the Polisy configured, and the 2413U PLM connected; but in the administrative console, Tools, Diagnostics, PLM Info/Status section, it reads  0.0.0 v0 Not connected
and the Policy will not discover any Insteon devices.   Have I missed something?    (BTW - Insteon IS enabled in the configuration)
I have the same issue where the PLM shows not connected. All updates and upgrades are up to date. The PLM that I have is a smartlabs dual band 2413u version 1.0. It can be seen by an app that runs on the PC. 'Simplehomenet Utility Suite'
Gary
9 hours ago, Michel Kohanim said:
@mmb, have you done:
- Admin Console | Configuration | System
- Check INSTEON Support checkbox
- Click on the Save button and then Reboot button (restarts the ISY service)
Tried that and other as well, no luck.  I believe the OS sees it but the ISY isn't picking it up.
2 hours ago, Michel Kohanim said:
Hi guys,
If anyone has access to ssh, can you please plug the PLM in, unplug it, plug it back in and then send me the output of:
dmesg
Are you referring to dmesg.today in /var/log?
I checked messages and unplug/plug events are recorded there.
Jul 21 12:25:23 polisy kernel: ugen0.2: <FTDI FT232R USB UART> at usbus0 (disconnected)
Jul 21 12:25:31 polisy kernel: ugen0.2: <FTDI FT232R USB UART> at usbus0
Jul 21 12:28:43 polisy kernel: ugen0.2: <FTDI 232R USB UART> at usbus0 (disconnected)FT
Jul 21 12:28:53 polisy kernel: ugen0.2: <FTDI FT232R USB UART> at usbus0
Edited by mmb
igb2: netmap queues/slots: TX 4/1024, RX 4/1024
pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
xhci0: <AMD FCH USB 3.0 controller> mem 0xf7fa2000-0xf7fa3fff irq 18 at device 16.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
ahci0: <AMD Hudson-2 AHCI SATA controller> port 0x4010-0x4017,0x4020-0x4023,0x4018-0x401f,0x4024-0x4027,0x4000-0x400f mem 0xf7fa5000-0xf7fa53ff at device 17.0 on pci0
ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ehci0: <AMD FCH USB 2.0 controller> mem 0xf7fa6000-0xf7fa60ff irq 18 at device 19.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
intsmb0: <AMD FCH SMBus Controller> at device 20.0 on pci0
smbus0: <System Management Bus> on intsmb0
smb0: <SMBus generic I/O> on smbus0
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
sdhci_pci0: <Generic SD HCI> mem 0xf7fa7000-0xf7fa70ff at device 20.7 on pci0
sdhci_pci0: 1 slot(s) allocated
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb5
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: console (115200,n,8,1)
tpm0: <Trusted Platform Module> port 0xc31-0xc32 iomem 0xfed40000-0xfed44fff on acpi0
tpm: device 0x001a15d1 rev 0x10
WARNING: Device "tpm" is Giant locked and may be deleted before FreeBSD 14.0.
orm0: <ISA Option ROM> at iomem 0xee800-0xeffff pnpid ORM0000 on isa0
superio0: <Nuvoton NCT5104D/NCT6102D/NCT6106D (rev. B+)> at port 0x2e-0x2f on isa0
gpio0: <Nuvoton GPIO controller> at GPIO ldn 0x07 on superio0
gpiobus0: <GPIO bus> on gpio0
gpioc0: <GPIO controller> on gpio0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Trying to mount root from zfs:zudi/ROOT/default []...
Root mount waiting for:ugen1.1: <AMD EHCI root HUB> at usbus1
ugen0.1: <0x1022 XHCI root HUB> at usbus0
 usbus0 CAM usbus1
uhub0 on usbus1
uhub0: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1 on usbus0
uhub1: <0x1022 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
uhub1: 4 ports with 4 removable, self powered
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <SATA SSD SBFM61.3> ACS-4 ATA SATA 3.x device
ada0: Serial Number 218807050F8D00029175
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 30533MB (62533296 512 byte sectors)
Root mount waiting for: usbus1
uhub0: 2 ports with 2 removable, self powered
ugen1.2: <vendor 0x0438 product 0x7900> at usbus1
uhub2 on uhub0
uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
ugen1.3: <vendor 0x0cf3 product 0xe003> at usbus1
Dual Console: Serial Primary, Video Secondary
apuled0: <APU2> at iomem 0xfed81610-0xfed8161b,0xfed81664-0xfed81667 on isa0
resetsw0: <UDXRSW-2> at iomem 0xfed81664-0xfed81667 on isa0
lo0: link state changed to UP
igb0: link state changed to UP
ubt0 on uhub2
ubt0: <vendor 0x0cf3 product 0xe003, class 224/1, rev 1.10/0.01, addr 3> on usbus1
WARNING: attempt to domain_add(bluetooth) after domainfinalize()
WARNING: attempt to domain_add(netgraph) after domainfinalize()
Security policy loaded: MAC/ntpd (mac_ntpd)
@Michel Kohanim
I rebooted the Polisy then plugged in the USB PLM  (after fully booted)
now I get
Now the AC is in a loop and displaying
1 hour ago, Michel Kohanim said:
@bgrubb1, thank you very much. It does not even show up.
@mmb, it's best if unplug and plug it back in and use
dmesg > dmesg.out
And then use scp to copy it to your computer and paste here.
Thank you all.
---<<BOOT>>---
Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.0-RELEASE-p3 #11 releng/13.0-n244752-b368bb75bad: Tue Jul 13 23:39:11 UTC 2021
    ec2-user@bsdev.isy.io:/usr/obj/usr/src/amd64.amd64/sys/POLISY amd64
FreeBSD clang version 11.0.1 (git@github.com:llvm/llvm-project.git llvmorg-11.0.1-0-g43ff75f2c3fe)
CPU: AMD GX-412TC SOC                                (998.15-MHz K8-class CPU)
  Origin="AuthenticAMD"  Id=0x730f01  Family=0x16  Model=0x30  Stepping=1
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
  AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
  AMD Features2=0x1d4037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PTSC,PL2I>
  Structured Extended Features=0x8<BMI1>
  XSAVE Features=0x1<XSAVEOPT>
  SVM: NP,NRIP,AFlush,DAssist,NAsids=8
  TSC: P-state invariant, performance statistics
real memory  = 4294967296 (4096 MB)
avail memory = 4100575232 (3910 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <COREv4 COREBOOT>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
random: unblocking device.
ioapic1: MADT APIC ID 5 != hw id 0
ioapic0 <Version 2.1> irqs 0-23
ioapic1 <Version 2.1> irqs 24-55
Launching APs: 1 2 3
Timecounter "TSC" frequency 998148777 Hz quality 1000
KTLS: Initialized 4 threads
random: entropy device external interface
[ath_hal] loaded
000.000041 [4354] netmap_init               netmap: loaded module
WARNING: Device "spkr" is Giant locked and may be deleted before FreeBSD 14.0.
nexus0
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS>
cryptosoft0: <software crypto>
acpi0: <COREv4 COREBOOT>
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x818-0x81b on acpi0
apei0: <ACPI Platform Error Interface> on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> irq 24 at device 2.1 on pci0
pci1: <ACPI PCI bus> on pcib1
ath0: <Atheros AR946x/AR948x> mem 0xf7900000-0xf797ffff irq 24 at device 0.0 on pci1
ar9300_flash_map: unimplemented for now
Restoring Cal data from DRAM
Restoring Cal data from EEPROM
Restoring Cal data from Flash
Restoring Cal data from OTP
ar9300_hw_attach: ar9300_eeprom_attach returned 0
ath0: [HT] enabling HT modes
ath0: [HT] enabling short-GI in 20MHz mode
ath0: [HT] 1 stream STBC receive enabled
ath0: [HT] 1 stream STBC transmit enabled
ath0: [HT] LDPC transmit/receive enabled
ath0: [HT] 2 RX streams; 2 TX streams
ath0: AR9460 mac 640.2 RF5110 phy 1638.7
ath0: 2GHz radio: 0x0000; 5GHz radio: 0x0000
pcib2: <ACPI PCI-PCI bridge> irq 25 at device 2.2 on pci0
pcib2: failed to allocate initial I/O port window: 0x1000-0x1fff
pci2: <ACPI PCI bus> on pcib2
igb0: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x2000-0x201f mem 0xf7a00000-0xf7a1ffff,0xf7a20000-0xf7a23fff irq 28 at device 0.0 on pci2
igb0: Using 1024 TX descriptors and 1024 RX descriptors
igb0: Using 4 RX queues 4 TX queues
igb0: Using MSI-X interrupts with 5 vectors
igb0: Ethernet address: 00:0d:b9:53:c7:90
igb0: netmap queues/slots: TX 4/1024, RX 4/1024
pcib3: <ACPI PCI-PCI bridge> irq 26 at device 2.3 on pci0
pcib3: failed to allocate initial I/O port window: 0x2000-0x2fff
pci3: <ACPI PCI bus> on pcib3
igb1: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x3000-0x301f mem 0xf7b00000-0xf7b1ffff,0xf7b20000-0xf7b23fff irq 32 at device 0.0 on pci3
igb1: Using 1024 TX descriptors and 1024 RX descriptors
igb1: Using 4 RX queues 4 TX queues
igb1: Using MSI-X interrupts with 5 vectors
igb1: Ethernet address: 00:0d:b9:53:c7:91
igb1: netmap queues/slots: TX 4/1024, RX 4/1024
pcib4: <ACPI PCI-PCI bridge> irq 27 at device 2.4 on pci0
pcib4: failed to allocate initial I/O port window: 0x3000-0x3fff
pci4: <ACPI PCI bus> on pcib4
igb2: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x5000-0x501f mem 0xf7c00000-0xf7c1ffff,0xf7c20000-0xf7c23fff irq 36 at device 0.0 on pci4
igb2: Using 1024 TX descriptors and 1024 RX descriptors
igb2: Using 4 RX queues 4 TX queues
igb2: Using MSI-X interrupts with 5 vectors
igb2: Ethernet address: 00:0d:b9:53:c7:92
usbus0 on xhci0
usbus1 on ehci0
 usbus0 CAM usbus1
uhub0 on usbus1
uhub1 on usbus0
ada0: <SATA SSD SBFM61.2> ACS-4 ATA SATA 3.x device
ada0: Serial Number 1197079712BF01412851
Root mount waiting for: usbus0 usbus1
uhub2 on uhub0
wlan0: Ethernet address: 74:29:af:01:c2:e3
ubt0 on uhub2
ath0: ath_edma_recv_tasklet: sc_inreset_cnt > 0; skipping
  • 3 weeks later...
36 minutes ago, JBoettcher said:
It appears that a new USB driver for the PLM has been added.
Yes and it seems to be rock solid....
So is it recommended to move to USB PLM for ISY on Polisy? My current PLMs are likely near end of life so was going to buy new ones with current sale so could just get USB ones in preparation for the move?
Sent from my Pixel 3 XL using Tapatalk
That is my crystal ball guess. I doubt we will ever see a production run of Serial PLMs again. Too many clues have been dropped, including UDI's support of the USB unit. Too much hush-hush there.
Right, what I really meant is should I move my current PLM over and use with Polisy or get a new USB one? I guess either way I need them eventually so may as well get them.
Yeah, I have w working one I depend on, and two that likely need cap replacements, but I have the same thoughts.
It doesn't sound like the pol/ISY is dependable enough yet to commit to the jump. A further factor, for me, has been a raft of LAN/WAN/Router problems for the last year or two that I may have (hopefully) spent my way out of (yeah about $1K, new router, new bad mesh routers with more problems that still didn't point to my original router problems **SIGH** ) .
I didn't want to mix more complications into that batch. :( and not be able to zoom in on bugs etc..
I guess we need to get more information about the PLM modem. Is there options? Different models? New USB PLM on the horizon?  IMHO there is a new USB model being worked on, not a serial PLM.
The USB PLM seems like the way to go, as we likely need to support two ISYs simultaneously. hmmm... maybe the soldering iron needs to come out in order to buy some time as SmartLabs will never announce/leak anything.
This brings me to anybody managed to make some cross talk connections between pol/ISY and ISY994 so items can be moved over slowly?
For those considering a new USB PLM in Canada.
aartech.ca has the USB PLM for about $104 CAD.
With Smarthome's current YESTHIRTY, 30% off coupon and cheapest very slow shipping at $38 USD, the aartech.ca version is about the same price after Canadian HST taxes.
This price comparison is also considering no taxes to be paid coming from US Smarthome (if you are lucky) and warranty will be very hard to claim with about $40 (your cost)  for return shipping. Exchange was calculated in comparison also.
The Canadian deal is much more economical and sensible. aartech.ca has always been top-notch for complaint and warranty handling. Only basic questions were asked on items in the past.
Anyone know a minimum revision level for the USB PLM to work with ISY on Polisy?  I have a 2414U V2.1 lying around I thought I'd try.
I'm not getting a connection despite the PLM appearing to be powered up. All my other PLMs are serial so I cannot do a hardware test by swapping it out.  However I'm not seeing any UART entries in the domes log- just vendor/product codes corresponding to polisy devices.
Most likely I need to get a new 2413U USB PLM? I have a few spare 2413S ones but that's not going to help me without a DP9-RJ45 cable. (Also I think one of them has bad caps and the the other is needed for an ISY going to another property)
IIRC Michel posted a software switch that had to be enabled to use a PLM with pol/ISY, recently (about a week ago) . It seems pol/ISY installs with the PLM disabled so people can get it going without a PLM.
The 2414U is actually a PLC vs PLM.  Not the same.  You could make a cable.
Unless the Pollsy can accept a 2414U PLC it will not work. It is not the same as a 2412U/S or 2413U/S PLM.
Completely different commands and message speed.  2414U/S PLC 4800,8,N,1. 2412U/S and 2413U/S  19200,8.N,1
It has a Real Time Clock with battery backup.  Large memory to store programs we assembled with the Smarthome  SALadIDE  assembler. That could have the assembled program downloaded into it. Then run alone with no computer equipment connected.
If you still had the boxes for the 2413S PLMs you have. It was in the box. Probably in one of the side pieces. Not marked so some didn't even know it was there.
Edited by Brian H
Add information
      378.6k
