brians Posted July 6, 2024 Posted July 6, 2024 No it is in admin firmware and says firmware 5.8.3 is up to date. I’ll try when at home later.
maxnorth Posted July 6, 2024 Posted July 6, 2024 On 7/6/2024 at 12:26 AM, brians said: No it is in admin firmware and says firmware 5.8.3 is up to date. I’ll try when at home later. Expand I'm not seeing it either.
btreinders Posted July 7, 2024 Posted July 7, 2024 I can confirm that a backup that used to take 45 minutes now takes seconds. I do get the pop up for a split second but by that time the back up is complete. This is great! My backup size before upgrade was 845 KB, new ones are now 829KB. Seems reasonable to me. 1
johnnyt Posted July 8, 2024 Posted July 8, 2024 Smooth upgrade, although lots of stuff to upgrade so need to give it time. Thanks SO MUCH for fixing the backup process! Went from > 10 mins (with, remarkably, the Java Launcher consuming > 80% of CPU throughout) down to about a second. Will no longer be hesitant/strategic about doing them when I'm making lots of changes. Can anything be done to improve program loading speed too? Well before I reached 1000 (now at 1200), it's also been a start-and-go-grab-a-coffee kind of process. Thanks again. 1
spyfish007 Posted July 13, 2024 Posted July 13, 2024 I've updated to 5.8.4 and the local admin console has come up. I've tried to back up and I get "Could Not Parse the Configuration File." I am running IoX on Polisy. I have ISY with PLM all connected. I have an internal Zwave/Zigbee card. All communications with devices seem to be working. I was able to do a backup before upgrading from 5.7.1. Any suggestions? Thanks.
DennisC Posted July 13, 2024 Posted July 13, 2024 On 7/13/2024 at 6:12 AM, spyfish007 said: I've updated to 5.8.4 and the local admin console has come up. I've tried to back up and I get "Could Not Parse the Configuration File." I am running IoX on Polisy. I have ISY with PLM all connected. I have an internal Zwave/Zigbee card. All communications with devices seem to be working. I was able to do a backup before upgrading from 5.7.1. Any suggestions? Thanks. Expand I would suggest running the upgrade packages a second time and after it completes, including the reboot, power cycle your unit. If you still have an issue backing up afterwards then you will need to open a support ticket with UD.
rg65 Posted July 13, 2024 Posted July 13, 2024 (edited) After upgrading my Polisy to 5.8.4, my UUID has defaulted to a different UUID. It appears to have defaulted with mostly 0's. How do I fix that? EDIT: The upgrade stopped it from working at all. I restored from a previous backup and I have no Zwave comms. When I send a command, I get: "Request Failed" Under the Z-wave tab, it says "Zmatter Z-wave not responding" Edited July 13, 2024 by rg65
Michel Kohanim Posted July 14, 2024 Posted July 14, 2024 For Polisy only, Please upgrade to PG3X: https://wiki.universal-devices.com/Polisy:User_Guide#Upgrading_to_PG3x With kind regards, Michel
larryllix Posted July 14, 2024 Posted July 14, 2024 On 7/14/2024 at 3:01 PM, Michel Kohanim said: For Polisy only, Please upgrade to PG3X: https://wiki.universal-devices.com/Polisy:User_Guide#Upgrading_to_PG3x With kind regards, Michel Expand First line to enable PG3x doesn't function. https://polisy.local:8443/rest/pg3x.enable No website found.
Michel Kohanim Posted July 14, 2024 Posted July 14, 2024 Please replace polisy.local with it's ip address. With kind regards, Michel 1
CoolToys Posted July 19, 2024 Posted July 19, 2024 Recently my house has been waking up on its own. I believe it is the insteon motion sensors activating when the A/C kicks on. This is a new "feature" so I was troubleshooting and upgraded from 5.8.0 to 5.8.4 today. So far the upgrade is faster and smoother, glad I read to clear java etc first so it was easy, kudos on the back up speed changes. Other new "features" I found after the update: The email tab in configuration lost all smtp settings and returned to default. Insteon Motion II V .47 the battery level is now blank and "battery powered" is false.
Techman Posted July 19, 2024 Posted July 19, 2024 The status of battery powered devices won't show up in the admin console until a specific device node updates, i.e. battery level. Email configuration won't arbitarily change to default unless the default box was checked. 1
Beaker Posted July 20, 2024 Posted July 20, 2024 (edited) Greetings, Post my upgrade to v5.8.4, I came across an issue with programs that I use to automate my irrigation setup. I have two SmarTENiT model # 5010A, 8 zone controllers. I am able to manually turn on any of the zones via highlighting the device and turning it on, watering starts as expected. But my program will not run through the zones even though the program shows as running. I have tried writing a new programs several times, simple one-liner in the Then statement that turns on one of the zones. I rune the Then statement but same results, no irrigation. All other programs that do not reference the irrigation controllers appear to work fine. Has anyone seen similar issues with programming or is it that my controllers are no longer supported? Any suggestions/help you can provide would be great. Cheers, Ken. Edited July 20, 2024 by Beaker
Techman Posted July 20, 2024 Posted July 20, 2024 @Beaker Can you post a copy the program that's not working.
Beaker Posted July 20, 2024 Posted July 20, 2024 OK. Here is a fresh three line program to turn an irrigation zone on, wait 2 minutes and shut it off. I tested it and the program shows as running but no irrigation. <?xml version="1.0" ?><triggers><d2d><trigger><id>62</id><name>New Program-TEST</name><parent>8</parent><if></if><then><cmd id="DON" node="23 8D E8 1"></cmd><wait><minutes>2</minutes></wait><cmd id="DOF" node="23 8D E8 1"></cmd></then><else></else><comment></comment></trigger></d2d></triggers> Cheers, Ken.
Techman Posted July 20, 2024 Posted July 20, 2024 @Beaker Use "copy to clipboard" then paste it in the forum 1
copperstar Posted July 21, 2024 Posted July 21, 2024 EISY BRICKED: Conducted update from counsel. Waited for reboot required. Selected reboot. Eisy does not complete startup and no entries in finder. Unplugged for several minutes several times and no change. Plugged in HDMI to monitor boot process. Several lines of WARNING: failed to start isy. Tried factory reset, no help. Unable to access isy now Any suggestions??
DennisC Posted July 21, 2024 Posted July 21, 2024 On 7/21/2024 at 1:11 PM, copperstar said: EISY BRICKED: Conducted update from counsel. Waited for reboot required. Selected reboot. Eisy does not complete startup and no entries in finder. Unplugged for several minutes several times and no change. Plugged in HDMI to monitor boot process. Several lines of WARNING: failed to start isy. Tried factory reset, no help. Unable to access isy now Any suggestions?? Expand I would suggest you open a support ticket with UD. If you want, you could try removing power for several minutes and then try to power eisy back up. Also, try using a new power supply. 1
copperstar Posted July 21, 2024 Posted July 21, 2024 (edited) Thanks. Opened a ticket so waiting for help there. Tried several different supplies, all high amp, no help. I can watch the boot process on HDMI, boot stops at command line, can log in as admin. Several lines during boot of WARNING: failed to start isy. Trying to search for command line update commands and process but no luck. Edited July 21, 2024 by copperstar
Beaker Posted July 21, 2024 Posted July 21, 2024 Thanks Techman for reviewing. Here is the test program in clipboard format. New Program-TEST - [ID 003E][Parent 0008][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Irrigation / Irrigration-1 - Z1 Front Lawn' On Wait 2 minutes Set 'Irrigation / Irrigration-1 - Z1 Front Lawn' Off Else - No Actions - (To add one, press 'Action') Cheers, Ken.
Techman Posted July 21, 2024 Posted July 21, 2024 @Beaker There's no logical reason why the above program shouldn't work. If you can turn on the sprinklers by turning on the device in the device tree, then the Sprinkler Controller is compatible with your eisy/polisy and firmware. When you run the then clause does the device tree show it running (solid green)?
hart2hart Posted July 21, 2024 Posted July 21, 2024 Can you turn on the device “Irrigation / Irrigration-1 - Z1 Front Lawn” from device tree in the AC and confirm it actually turns on in the yard?
maxnorth Posted July 22, 2024 Posted July 22, 2024 I'd be sure to right click on the device in the AC and "update" it
