Ecobee not communicating
Starting a couple days ago my Ecobee thermostats stopped following the programs I have had for a few years. I ended up deleting and reinstalling the PG3 plugin a few times and setting that up. Orriginally it would find the 3 thermostats and other nodes related to the Ecobee but now I can't even get the nodes to populate. When I was able to get the nodes to populate I couldn't get the thermostats to update based on changes made in eisy and eisy would not update based on physical thermostat changes. Any one else having this issue or have advice?
Having the same problem. Started last night. Nodes not updating on IOX, cannot change node values. Restarted plug-in in PG3, had no effect. Restarted Eisy, and this cleared nodes in IOX to no values but not updating from PG3 plug-in. cold see teh node values in ecobee PG3 but could not get them to showup in IOX. Deleted, reinstalled, added key. See one node but thermostats not adding to PG3 now.
Added debug vebose log file with errors
Looks like ecobee changed something
Ecobee_4-17-2026_11623_PM.zip
Hi @Jimbo.Automates , Same problem here. After reinstalling the plug-in, the plugin acts like it never gets authorized even though ecobee web site indicates success. I just get the controller node. See attached, is the first entry connection status to the thermostats?
Thank you
4 hours ago, tazman said:
Same problem here also.
And here. Is Jimbo still listening??
