New release out today.....Does this work on Polisy?
Solved by Guy Lavoie
It does work, but the update must be done manually, by accessing the Polisy by ssh. Then you do:
sudo pkg upgrade udx isy eisyui pg3x
This method was suggested by Michel at UDI. I've successfully upgraded two Polisys this way.
Remember the release announcement warning:
If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system.
Edited by Guy Lavoie
Do you know if this will be enabled/allowed from the Jave console in the future. I'm not that familiar with ssh control of Policy. I get this error when trying that upgrade command. No repositories are enabled. (My OS is 14.3)
Edited by EJones01
Just now, brians said:
This contradicts this statement. Do not use SSH to perform the upgrade; this will brick your system.
That's for the Polisy only.
Ok so I have a polisy do I use ssh to upgrade or not. The instructions are kinda ambiguous I think I see now that is a warning for older kernels
Edited by brians
Yes, heed the warning about the freebsd version. This upgrade method was suggested by Michel at UDI. I've personally upgraded all three of my Polisys successfully this way. Page 4 on the following thread has discussion, including instructions on enabling the repositories if needed.
I ran the command, been a while but I get this when connecting to the web...
Should I just be patient now?
Uploading Attachment...
That might be normal, I saw something similar during the command line update, probably because the Polisy cannot be fully upgraded to freebsd 14.4. I'd reboot it and then check out that everything is ok.
ok so that system busy went away.. I removed java cache and reinstalled and IoX seems to be on lastest version..
Gonna restart now hoping for the best ;)
Ok well that was nerve-wracking.. reboot didn't work from gui, so I did from ssh but was running a continous ping and didnt see drop so presumed crashed.. after a while I hard rebooted Polisy by removing power and it eventually all came back up.
I did not have to use the command to set the repo when I upgraded unlike others.
I got the impression that we will have to ssh upgrade polisy each time and possibly require to run command to set repo in future ?
Very likely. I updated 3 Polisys this way and didn't need to set the repository on any of them. Not sure why it happens for some cases.
Hiya Guy,
I tried that url a couple of times, but it does not work for me. (Server Not Found.) https://eisy.local:8443/WEB/sysconfig.txt
Do you know of another way to check the FreeBSD version?
EDIT: I think I just woke up - that link is for Eisy's only? (eisy.local)
Edited by Athlon
Update my post
8 minutes ago, Athlon said:
Hiya Guy,
Yes, hardcode the ip address of your controller instead. For example:
https://192.168.0.123:8443/WEB/sysconfig.txt
I just ran https://polisy.local:8443/WEB/
and got this - looks like I'm good to go?
FreeBSD polisy 14.3-RELEASE-p3 FreeBSD 14.3-RELEASE-p3 releng/14.3-n271444-30ad842dd970 POLISY amd64
Yes. So go ahead and do the update, from the comnand line as explained earlier.
Thank you!
I'm trying to find my user name and password - been using my portal login for so long I may have forgotten it....
2 minutes ago, Athlon said:
Thank you!
You only really need the admin password.
That did it - thank you again!
were you meaning admin for ssh? Mine is admin and password is admin so not the same as the IoX password.. not sure if that is normal or not... I don't remember ever changing it.. sure not the most secure LOL
Yes, for ssh.
