Everything posted by JimTurner
ratgdo discovery with EISY Plugin
Here is the link that has the version reported to work: https://github.com/ratgdo/esphome-ratgdo/releases/tag/v1428
Ratgdo 4.0.8 discovery fails â firmware endpoint ret
đ
There is a lot of discussion here Bottom line, you have to downgrade the firmware on the Ratgdo device for the plugin to work from github
Any more updates on this? I was about to take the ratgdo plunge until I saw this... đ
eisy-ai simple steps to get going
OK, I did my first plugin as well! Like others have said, this is slick. I have an Alula alarm panel, and while there is no published API for that, someone created one that eisy-ai was able to use. My plugin is up and running... Here is a condensed step list for what I did (Note: I used Claude): Prep Claude: 1. Create a Claude Account and seed that with some $ (I burned through my initial $5 seed quickly, and with my trial and error, spent just under $20. I ended up turning on auto-reload of $15 below $5). 2. On the platform.claude.com/dashboard page click on Keys & access link (API is selected automatically) 3. Click on Create key button in upper right corner 4. I selected "Somewhere else" in the popup 5. Name the key and select Expires option, then "Create key" button 6. They key pops up in a dialog box, so COPY FROM THERE to your clipboard and save! Prep EISY: 1. Select Staging repo on the Systems Page 2. Upgrade to the latest there (mine took about 20 minutes and blew up my UDM alert page...đ ) 3. Install the eisy-ai plugin by clicking on the "Add Plugin" button on the eisy plugins page. 4. On the configuration tab of the eisy-ai plugin, add the below (from @Michel Kohanim readme notes) to the Value Box next to the word "Configuration" and replace the key generated above in the 2 places. ```json { "max_tool_set_switches_per_turn": 1, "search_engine": null, "search_engine_api_key": null, "mcp_server": false, "nucore_runtime": { "unified": { "enabled": true, "provider": "claude", "model": "claude-haiku-5-5", "api_key": "Replace_with_your_Anthropic_API_Key", "stream": true, "url": null, "max_turns": 20, "max_tokens": 64000, "cache_ttl": "5m", "max_iterations": 20, "history_token_budget": 20000, "fabrication_guard_mode": "log", "max_fabrication_retries": 1 }, "plugin_authoring": { "enabled": true, "provider": "claude", "model": "claude-sonnet-5-5", "api_key": "Replace_with_your_Anthropic_API_Key", "stream": true, "url": null, "max_turns": 20, "max_tokens": 64000, "cache_ttl": "5m", "max_iterations": 50, "history_token_budget": 20000, "fabrication_guard_mode": "log", "max_fabrication_retries": 1 } } } ``` 5. I think I had to reboot after this or at least restart the eisy-ai plugin. 6. Select the star icon (to the right of the ? mark and left of the green dot in the upper right corner). 7. Start talking to the AI like Scotty did in Star Trek. đ¤ 8. I did switch to developer mode as noted elsewhere Push to GitHub: My GitHub experience is lacking so I employed ChatGPT to assist in the push. The EISY-AI asked me about the repository so I created an empty one on GitHub in my account From SSH in EISY, you can push your finished code directly to your repo on GitHub but you need a token (not your account PW). On GitHub, click on your profile icon upper right Click on Settings Scroll to <> Developer Settings (lower left menu) Click on Personal access tokens and select Find-grained tokens / Generates new token ChatGPT asked me to verify lots of things that I won't recap here but I used git push -u origin main to push the code using your GitHub ID and the token just reated Hope this condensed list helps... What I will do with this plugin: I will couple this with geofencing from UDM for both my wife and myself. If we both leave, the alarm will automatically set. If one of us comes home it will disarm. I already have a guest switch in my setup that controls other items, so I will use that to control the auto arm/disarm. I will auto arm the "Armed Stay" function with my good night programing, and "Disarm" in my good morning programing... ~jim (others chime in if I missed something)
August Lock Zwave eisy Working for Anyone?
FWIW, I gave up on the August Z-Wave lock long ago, and I missed this thread until today. âšī¸ I went with a Kwikset z-wave lock (https://www.amazon.com/dp/B0C5GD4MWT?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4&th=1) Even with Z-wave devices RIGHT NEXT TO THIS LOCK to act as repeaters, and my z-wave dongle 25 ft away, it will still go unresponsive forcing me to remove the battery and reset it. I use this lock multiple times / day. ~jim
Webinar Time Poll
I had registered to attend, had it on my calendar but I am on the road traveling and missed this. Was it recorded?
Plugins Fail After Reboot of Eisy
I have an Acurite Plugin (for weather data - production) that has a similar issue. After a system restart, the nodes don't seem to reflect what they actually are, just the system names. Restarting the plugin cleared the issue. I have a program that shuts down some key devices in my house when lightning strikes are close. Before the restart the program rendered "undefined <= 4 miles" and after restart it said "Lightning Last Strike Distance <= 4 miles". The program logic still worked, but I went to check on this and noticed the node name issue.
UDM Plugin Disconnect to PG3x....????
The plugin affected is my Acurite weather station. Yes, the nodes where there before in UDM as I had one of them on my favorites. Plus, I use the values in those nodes to control programs and have for sometime. The eisy-ui presentation of the nodes initially said "internal server error" until I restarted the eisy-ui service using the services tab. After that, resyncing the UDM restored the node values there. I should add that this started with a sync request on UDM that resulted in an error saying "Can't start node server" (paraphrasing). Checking now, I see the nodes on that tab that all show "stopped" (guessing that's the old PG3 handling).
I am running this: I migrated my plugins to the new plugins page in eisy-ui. There APPEARS to be a disconnect from UDM for the Plugin section of the mobile app. I think since the plugins were moved to Plugins (Beta) the UDM doesn't know what that is. If I tap plugins on the UDM settings page, says it can't start the node server, and clears the nodes on one of my plugins in UDM. I resolved it by restarting the eisy-ui service from the eisy.local page, the resynchronizing the UDM.
Admin Console Issue with phased rollout
I am running this from the Beta Repository: SOME programs that use Z-wave switches cannot be edited in the AC. The z-wave on-off node is MIA from the AC dropdown lists but are available in the eisy-ui web interface - so I can still get to where I need to be. However, if the goal was to keep the AC completely functional until it goes away at some point, this bug prevents that.
Access to web ui when internet is down
The my.isy.io.... routes through the web to get to your eisy. Hitting eisy.local from your browser stays within your network. I have 2 options in my "ISYFinder" - one that uses port 8443. I use that one as I know it won't route through the internet; plus, since I never opened the AC to the internet, I have a simple admin pw that makes launching the AC faster for me. I also found this: https://wiki.universal-devices.com/Eisy:User_Guide#Using_eisy_without_connectivity
Doesn't eisy.local/nodes work for you without internet?
Upgraded to Beta packages as of 2026-09-24 (Issue)
Couple of MINOR issues: The Protocol Submenu reported "No API installed" when I clicked on the Z-Wave until I rebooted the system. The rest showed up. The Protocol Submenus for each protocol should have the enable/disable switch in the same location for each. <-- MINOR!!! The Display setting for "Light" still uses yellow text on the white background to let you know that the system is rebooting. (VERY difficult to see...) The Insteon Protocol page "Show PLM Links Table" shows "No Records Found" while the System Busy orange banner is up at the bottom right. No link dump is returned. What I like that is now added: Node details like X-Ray, restore, etc. The configuration tab in the System Submenu has the same settings as the AC config page except the protocol switches (new sub menu) What I did NOT find: The AC has the Event Viewer - Level 3. Device communications events. (It would be nice to have a rolling log like the rest for this. I have a non reproducible error so I don't want to keep the AC log running waiting for the error to occur). This strikes me as REALLY close to the AC feature list... I may edit this post with more findings... NICE WORK ALL!! EDIT 1: The scene control options in the AC have been whacked and only show "Write Changes" without the ability to make edits there e.g. On or Off, etc. The eisy-ui seems to allow proper edits. I have lots of lights that come on at sunset and off late in the evening. The turn on event failed from the scheduled program, but running the "then" of the program worked from UDM. Will monitor this evening and see what happens... EDIT 2: OK, this is weird: I edited ONE program in eisy-ui to test and the AC now has all the scene options under "Your Devices"... SMH
FYI : Google Home is beta testing MCP
This link works: https://support.google.com/googlehome/thread/467705013/introducing-home-mcp-enabling-your-agent-to-interact-with
Will eisy-ui have pop-up notifications for updates
Not sure. I havenât played with the beta yet (currently painting the entire inside of the house to keep the Mrs a Mrs. đ) Click on the beta repository and see what it shows. I did that a week ago and it flipped the switch in the ac saying I have updates. I will install the beta versions soon.
eisy-ui reports MUI X Missing License Key
Thansk! I did the straight upgrade from the AC when I did the move to 6.1, then added the 6.1.1 release on top of that. i will attempt again shortly.
IoX 6.1.1 let's discuss it!
I think you have to rebuild it...
This is a super imposed water mark over the web page display. What do I need to do?
Some here may not like this, but I bought one of these https://a.co/d/048nO7yN from Amazon. I can do a power off / on remotely if absolutely necessary. $23
One other oddity I have noticed is trying to view the error log from the AC. It seemingly hangs and never returns (log file too big??). I can download the error log from the eisy.local and it has nearly 200k lines in it. I am assuming this is the same log???? (Trying to chase down an issue unrelated to this thread, but the error log not loading started with this upgrade...) ~jim
That's what I saw, but I didn't hit the go button...
My UD Mobile and AC are both reporting a new version as of this morning (8/22). I upgraded a few days ago. @Javi Is this for the fixes you mentioned above? ~jim
I3 set LED to off when switch is off
My test has 2 simple programs: 1 for backlight off and 1 for backlight on (based on switch status). They work flawlessly. My device is actually a dimmer (2477D), but I just tested the same thing in a switch (2477S). TestSwitch - [ID 0063][Parent 0001][Enabled] If 'Office Light' Status is Off Then Set 'Office Light' Backlight 0% Else - No Actions - (To add one, press 'Action')
An observation: While I was patient waiting for the upgrade to occur, it did not appear that a reboot request was pushed to the user (me). I had to find it... (Not a big deal but something I noticed).
