October 8, 20251 yr Third reality zigbee smart plug power monitoring not showing upThird Reality, IncModel # 3RSP02028BZhttps://www.amazon.com/THIRDREALITY-Zigbee-Smart-Plug/dp/B0BPY2KRHHIoX v.5.9.1 The device has no problem pairing, and is functional with on / off capabilities, but the power monitoring feature is not available.Note: under Xray: Device channel database object: ELECTRICAL_MEASUREMENT is listed Edited November 4, 2025Nov 4 by evilpete
October 22, 20251 yr NeoWater Sensor 11Shenzhen NEO Electronic CO.,LTDWater level alarm, reset, battery statusThanks, Tim
October 24, 2025Oct 24 Manufacturer Name: InovelliModel #: VZM35 -Blue Series (Zigbee) FAN SWITCHLink to sales/availability site(s) Blue Series Fan Switch • Manual | Inovelli Help CenterKey/desired function support: In a program's device list, include a drop-down option for "Set Configuration" (Along with the On, Off, Fast On, etc.)Set ConfigurationParameter NumberParameter ValueThese switches have 74 configuration parameters but there's no way to set any of them using an EISY.
October 27, 2025Oct 27 I cant find a zwave rgbw controller anywhere. I saw this on Amazon: Amazon.com: GLEDOPTO ZigBee 3.0 Pro Mini LED Strip Controller 5 Modes in 1 RGBCCT RGBW RGB CCT WWCW Dimmer DC12-24V APP Voice Control Work with Hu/e ZigBee2mqtt Conbee II Home Assistant Alexa (Hub Required) : Tools & Home ImprovementAnyone got it to work with EISY?Or, @Michel Kohanim can you get this added as a supported zigbee device?Thanks
October 28, 2025Oct 28 I have many of these GLEDOPTO LED controllers. They make a handful of zigbee models. They work fine out of the box.
November 3, 2025Nov 3 On 10/28/2025 at 6:09 AM, SJK said:I have many of these GLEDOPTO LED controllers. They make a handful of zigbee models. They work fine out of the box.Can you give a pros/cons review?This is something I've been thinking about recently
November 4, 2025Nov 4 THIRDREALITY ZigBee Smart ButtonModel # 3RSB22BZhttps://www.amazon.com/dp/B0BJDWR3BC?th=1Receive process button event.IoX v6.0.0I am willing send capture log and/or buy/donate a unit if it will help Edited November 4, 2025Nov 4 by evilpete
November 4, 2025Nov 4 Q: should we put together a list on the wiki of functional and nonfunctional zig devices?
November 5, 2025Nov 5 On 11/3/2025 at 6:28 PM, evilpete said:Can you give a pros/cons review?This is something I've been thinking about recentlySure- they are a basic Zigbee3.0 device. They are nothing fancy but work pretty much identically to Philips Hue bulbs. You get an on/off node, an x/y/temp node, and a color/sat node. All work exactly like any other ZB3.0 device.My only con is that if they are reset (or powered off for months, like happened with my exterior flood lights) you end up with a new ID (think this is typical of these kind of devices) which makes reprogramming a pain if they are in multiple scenes. Always remove from network first of course.I recommend these for LED strip drivers. They have few models with varying configs. They are inexpensive- no reason not to get the 5 in 1 version that can do RGBWW+CW for strips. They can be configured to whatever strip type you need- RGB, + WW, +CW, etc. They even have constant voltage modes and single color dimming modes or CW/WW modes. Pretty flexible- cannot go wrong here. Just pick the device that meets your needs. Edited November 5, 2025Nov 5 by SJK model detail
November 15, 2025Nov 15 Please include:Manufacturer Name : ONENUO / IHSENOModel # : 22WYZLink to sales/availability site(s): https://www.amazon.com/IHSENO-ZigBee3-0-Remote-Button-Zigbee/dp/B0CCCKKH27/?th=1 https://www.aliexpress.com/i/3256809496235355.htmlKey/desired function support Report DON/OFF events described in NodeDef but missing in NodeInfoNodeInfo:<nodeInfo> <node flag="128" nodeDefId="ZB05836_001_1"> <address>ZB05836_001_1</address> <name>ZB 5836.1 On-Off W Button</name> <family>14</family> <hint>39.0.0.13</hint> <parent type="3">26264</parent> <type>255.1.255.255</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZB05836_001_1</pnode> <rpnode>ZB05836_001_1</rpnode> <sgid>1</sgid> <typeInfo> <t val="103" id="ioxType"/> <t val="4742" id="mfgCode"/> <t val="SNZB-01" id="model"/> </typeInfo> </node> <properties/> </nodeInfo>NodeDef<nodeDefs> <nodedef nls="103" id="ZB05836_001_1"> <sts> <st hide="T" editor="ZB_ERR" id="ERR"/> </sts> <cmds> <sends> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="IDENTIFY"> <p optional="T" editor="ZB_IDENTIFY" id=""/> </cmd> <cmd id="QUERY"/> </accepts> </cmds> </nodedef> </nodeDefs>
December 11, 2025Dec 11 Manufacturer Name AqaraModel # FP300Link to sales/availability site(s) Aqara Presence Multi-Sensor FP300: 5-in-1 DetectionKey/desired function support Occupancy (must), Illumination (very important), Temp and Humidity (nice to have)This is one of those cool new mmWave occupancy/presence multisensors. It's battery powered and is said to have a multiyear battery life! I have one, bound to my Hubitat hub, but I'd love to see it supported on ISY. Here's a thread where we've been talking about it: Aqara FP300 Thread & Zigbee Motion Sensor - ZMatter - Universal Devices Forum-Tom
December 22, 2025Dec 22 I'd like have the Shelly Flood Gen4 fully recognized completely as a matter device (now it just appears like here)Manufacturer Name ShellyModel # S4SN-0071ALink to sales/availability site(s) https://www.amazon.com/gp/product/B0FPG9SGLJ/ref=ewc_pr_img_1?smid=A33RI86K4PO1EO&psc=1Key/desired function support: Leak detectionAfter facing a major water leakage at home, this is now a must have.Shelly knowledge base, just for information: https://kb.shelly.cloud/knowledge-base/shelly-flood-gen4#ShellyFloodGen4-Installationguides
January 7Jan 7 LevitonDG6HD-1BWhttps://leviton.com/products/dg6hd-1bwOn/Off/Dim/BrightenJust updated to IoX 6.0.4. This switch is setup and working with my system (added under 5.X.X) but there are 2x "extra" nodes on the device tree. Is this correct? Should I delete and re-add???? I'm considering adding more of these to my system but, before I buy, I want to make sure they are fully/correctly supported. I've been linking EISY to Home Assistant and HA is having trouble controlling the dimming.ZB XXXXX.1 On-Off SwitchZB XXXXX.2 UnavailableZB XXXXX.3 Unavailable Edited January 7Jan 7 by kartman_canada
January 10Jan 10 Hello! (Let me know if this device should work, meaning this should be a support ticket)SONOFF S31 Lite zbSONOFFSONOFF S31 Lite zb Smart Plug US Type Zigbee VersionS31 Lite zb is a smart Plug adopting ZigBee wireless communication protocol that accesses to internet via ZigBee Bridge. You can remotely turn on or off the device via your smartphone, schedule it on/on, off, status. the normal functions. I have (2) of these devices and have have tried adding each of them to my EISY. When I click 'Add a Zigbee Device', the freshly factory reset Sonoff plug is seen immediately and the interview process begins. But the "(timeout XXs)" eventually reaches zero, the interview window closes, and I get a device in IoX called "ZB 17211.1 On-Off Switch". The device does not react when attempting to control the device in IoX. After a few minutes and IoX shows the error that it has lost communication with the device. The lack of control and loss of connection are not surprising because momentarily after the interview begins, the device itself goes into an error mode (turning on and off rapidly and continuously) which I have not been able to find referenced in any documentation. Both of these units, after another factory reset, can be added to my Home Assistant zb network and function normally. long story. but hoping this can get me starting in knowing if its Z-Matter/EISY, the plugs, or me.
January 13Jan 13 Could this Zigbee device be added?ZigBee Tuya SPI Pixel LED Strip Light Controller Smart Life APP Control RGB IC Dynamic Lighting Static Mode Music Sound ZigBee2mqtt Home Assistant WS2811 SK6812 WS2805https://www.amazon.com/dp/B0FNR6TB1R?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1I was able to add it to the EISY, but there are no controls, options, configuration or anything.The comments on Amazon inform that it works with Home Assistant without a Tuya hub.Thanks!
January 15Jan 15 On 11/3/2025 at 6:59 PM, evilpete said:THIRDREALITY ZigBee Smart ButtonModel # 3RSB22BZhttps://www.amazon.com/dp/B0BJDWR3BC?th=1Receive process button event.IoX v6.0.0I am willing send capture log and/or buy/donate a unit if it will helpI will second this request. My use is I have a hot water recirculation pump, it would be nice to have a button by the sinks that need it to run to bring hot water up. Today I use "Alexa turn on hot water". But guest don't always understand that, so having a button to press makes it even simpler. I haven't found any other buttons. I have 2 of these, they somewhat connect but the button pressed events don't show up.
January 26Jan 26 On 1/9/2026 at 6:58 PM, OverDale said:Hello!(Let me know if this device should work, meaning this should be a support ticket)SONOFF S31 Lite zbSONOFFSONOFF S31 Lite zb Smart Plug US Type Zigbee VersionS31 Lite zb is a smart Plug adopting ZigBee wireless communication protocol that accesses to internet via ZigBee Bridge. You can remotely turn on or off the device via your smartphone, schedule it on/on, off, status. the normal functions.I have (2) of these devices and have have tried adding each of them to my EISY.When I click 'Add a Zigbee Device', the freshly factory reset Sonoff plug is seen immediately and the interview process begins. But the "(timeout XXs)" eventually reaches zero, the interview window closes, and I get a device in IoX called "ZB 17211.1 On-Off Switch". The device does not react when attempting to control the device in IoX. After a few minutes and IoX shows the error that it has lost communication with the device.The lack of control and loss of connection are not surprising because momentarily after the interview begins, the device itself goes into an error mode (turning on and off rapidly and continuously) which I have not been able to find referenced in any documentation.Both of these units, after another factory reset, can be added to my Home Assistant zb network and function normally.long story. but hoping this can get me starting in knowing if its Z-Matter/EISY, the plugs, or me.I have one of these I've been trying to add. I can get eisy to pair and it shows up with a valid on/off state, however eisy cannot appear to control it. I know it can see the state, because i am turning it on or off at the plug and disconnecting it from the outlet and eisy see all those changes immediately. Was really hoping it would work so I could use for higher current devices as it appears to be one of the few if not only zigbee outlet capable of 15 amps inductive and resistive loads.
January 27Jan 27 7 hours ago, Hunter Aviator said:I have one of these I've been trying to add. I can get eisy to pair and it shows up with a valid on/off state, however eisy cannot appear to control it. I know it can see the state, because i am turning it on or off at the plug and disconnecting it from the outlet and eisy see all those changes immediately. Was really hoping it would work so I could use for higher current devices as it appears to be one of the few if not only zigbee outlet capable of 15 amps inductive and resistive loads.Thank you for this data point @Hunter Aviator . Its great to know its not just me even though it sounds like your broken state is slightly different than mine.
March 12Mar 12 Hi,I would like to request Zigbee support for the Thirdparty smart plug. Uses Zigbee 3.0 standard. It works now but only as an on/off switch. I would like to see and use the real time power monitoring.ThanksGaey
March 12Mar 12 1 hour ago, garybixler said:Hi,I would like to request Zigbee support for the Thirdparty smart plug. Uses Zigbee 3.0 standard. It works now but only as an on/off switch. I would like to see and use the real time power monitoring.ThanksGaeyInteresting: Today I just tried the Zigbee functionality on my test Polisy and I added a Jasco Enbrighten on/off plug in module, which also lists power monitoring as a feature. IoX only shows it as an on/off device. Sounds like it might be based on the same chipset.
March 13Mar 13 43 minutes ago, Michel Kohanim said:@Guy Lavoie , can you please send me a link to this device?With kind regards,Michel@Michel KohanimI found this, The model number is 43095. This item was promoted as part of an energy saving program by Hydro Quebec, which has the possibility to turn down thermostats and reduce loads remotely, somewhat like the ADR you have elsewhere.JascoEnbrighten Zigbee Plug-In Smart Switch with Dual Controll...Plug into home automation with the Enbrighten Zigbee Dual-Outlet Plug-in Smart Switch. Enjoy extensive control of floor and table lamps, fans, and other fixtures when paired with a compatible gateway.I also find this, which seems a more helpful:https://www.zigbee2mqtt.io/devices/43095.html Edited March 13Mar 13 by Guy Lavoie
March 13Mar 13 Thank you. Please right mouse click | X-Ray, then copy/paste the contents of DH Cluster.With kind regards,Michel
March 13Mar 13 Ok, I get this on the main node:Zigbee Clusters for device 59391.1 []:(Input clusters accept commands/events/data from other devices)(Output clusters send commands/events/data to other devices) Cluster 0 0x00 BASICZigbee Cluster data for device 59391 endpoint 1 cluster 0 (0x0000)Empty DATA devices.59391.endpoints.1.clusters.0.data = EmptyBoolean DATA devices.59391.endpoints.1.clusters.0.data.inDirection = TrueBoolean DATA devices.59391.endpoints.1.clusters.0.data.outDirection = FalseBoolean DATA devices.59391.endpoints.1.clusters.0.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.1.clusters.0.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.1.clusters.0.data.interviewDone = TrueInteger DATA devices.59391.endpoints.1.clusters.0.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.1.clusters.0.data.isDeepInterviewNeeded = TrueEmpty DATA devices.59391.endpoints.1.clusters.0.data.commandsClient = EmptyEmpty DATA devices.59391.endpoints.1.clusters.0.data.commandsServerReceived = EmptyBinary DATA devices.59391.endpoints.1.clusters.0.data.commandsServerGenerated = byte[1] [00]Integer DATA devices.59391.endpoints.1.clusters.0.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.1.clusters.0.data.redirectTuyaCluster = FalseInteger DATA devices.59391.endpoints.1.clusters.0.data.zclVersion = 3 (0x00000003)Integer DATA devices.59391.endpoints.1.clusters.0.data.applicationVersion = 18 (0x00000012)Integer DATA devices.59391.endpoints.1.clusters.0.data.stackVersion = 101 (0x00000065)Integer DATA devices.59391.endpoints.1.clusters.0.data.hwVersion = 2 (0x00000002)String DATA devices.59391.endpoints.1.clusters.0.data.manufacturerName = "Jasco Products"String DATA devices.59391.endpoints.1.clusters.0.data.modelIdentifier = "43095"Integer DATA devices.59391.endpoints.1.clusters.0.data.powerSource = 1 (0x00000001) Cluster 3 0x03 IDENTIFYZigbee Cluster data for device 59391 endpoint 1 cluster 3 (0x0003)Empty DATA devices.59391.endpoints.1.clusters.3.data = EmptyBoolean DATA devices.59391.endpoints.1.clusters.3.data.inDirection = TrueBoolean DATA devices.59391.endpoints.1.clusters.3.data.outDirection = FalseBoolean DATA devices.59391.endpoints.1.clusters.3.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.1.clusters.3.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.1.clusters.3.data.interviewDone = TrueInteger DATA devices.59391.endpoints.1.clusters.3.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.1.clusters.3.data.isDeepInterviewNeeded = TrueBinary DATA devices.59391.endpoints.1.clusters.3.data.commandsClient = byte[1] [00]Binary DATA devices.59391.endpoints.1.clusters.3.data.commandsServerReceived = byte[2] [0001]Binary DATA devices.59391.endpoints.1.clusters.3.data.commandsServerGenerated = byte[2] [0001]Integer DATA devices.59391.endpoints.1.clusters.3.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.1.clusters.3.data.redirectTuyaCluster = FalseInteger DATA devices.59391.endpoints.1.clusters.3.data.identifyTime = 56 (0x00000038) Cluster 6 0x06 ON_OFF_SWITCHZigbee Cluster data for device 59391 endpoint 1 cluster 6 (0x0006)Empty DATA devices.59391.endpoints.1.clusters.6.data = EmptyBoolean DATA devices.59391.endpoints.1.clusters.6.data.inDirection = TrueBoolean DATA devices.59391.endpoints.1.clusters.6.data.outDirection = FalseBoolean DATA devices.59391.endpoints.1.clusters.6.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.1.clusters.6.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.1.clusters.6.data.interviewDone = TrueInteger DATA devices.59391.endpoints.1.clusters.6.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.1.clusters.6.data.isDeepInterviewNeeded = TrueEmpty DATA devices.59391.endpoints.1.clusters.6.data.commandsClient = EmptyBinary DATA devices.59391.endpoints.1.clusters.6.data.commandsServerReceived = byte[3] [000102]Binary DATA devices.59391.endpoints.1.clusters.6.data.commandsServerGenerated = byte[6] [000102404142]Integer DATA devices.59391.endpoints.1.clusters.6.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.1.clusters.6.data.redirectTuyaCluster = FalseBoolean DATA devices.59391.endpoints.1.clusters.6.data.onOff = FalseBoolean DATA devices.59391.endpoints.1.clusters.6.data.onOff.directionSender = TrueInteger DATA devices.59391.endpoints.1.clusters.6.data.onOff.minIntervalReporting = 2 (0x00000002)Integer DATA devices.59391.endpoints.1.clusters.6.data.onOff.maxIntervalReporting = 65280 (0x0000ff00)Empty DATA devices.59391.endpoints.1.clusters.6.data.onOff.reportableChange = EmptyInteger DATA devices.59391.endpoints.1.clusters.6.data.onOff.timeout = 2 (0x00000002)Boolean DATA devices.59391.endpoints.1.clusters.6.data.onOff.directionReceiver = False Cluster 10 0x0a TIMEZigbee Cluster data for device 59391 endpoint 1 cluster 10 (0x000a)Empty DATA devices.59391.endpoints.1.clusters.10.data = EmptyBoolean DATA devices.59391.endpoints.1.clusters.10.data.inDirection = FalseBoolean DATA devices.59391.endpoints.1.clusters.10.data.outDirection = TrueBoolean DATA devices.59391.endpoints.1.clusters.10.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.1.clusters.10.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.1.clusters.10.data.interviewDone = FalseInteger DATA devices.59391.endpoints.1.clusters.10.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.1.clusters.10.data.isDeepInterviewNeeded = FalseEmpty DATA devices.59391.endpoints.1.clusters.10.data.commandsClient = EmptyEmpty DATA devices.59391.endpoints.1.clusters.10.data.commandsServerReceived = EmptyEmpty DATA devices.59391.endpoints.1.clusters.10.data.commandsServerGenerated = EmptyInteger DATA devices.59391.endpoints.1.clusters.10.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.1.clusters.10.data.redirectTuyaCluster = FalseInteger DATA devices.59391.endpoints.1.clusters.10.data.time = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.timeStatus = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.timeZone = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.dstStart = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.dstEnd = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.dstShift = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.standardTime = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.localTime = 743615217 (0x2c52aaf1)Integer DATA devices.59391.endpoints.1.clusters.10.data.lastSetTime = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.10.data.validUntilTime = 0 (0x00000000) Cluster 1794 0x702 clusterZigbee Cluster data for device 59391 endpoint 1 cluster 1794 (0x0702)Empty DATA devices.59391.endpoints.1.clusters.1794.data = EmptyBoolean DATA devices.59391.endpoints.1.clusters.1794.data.inDirection = TrueBoolean DATA devices.59391.endpoints.1.clusters.1794.data.outDirection = FalseBoolean DATA devices.59391.endpoints.1.clusters.1794.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.1.clusters.1794.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.1.clusters.1794.data.interviewDone = TrueInteger DATA devices.59391.endpoints.1.clusters.1794.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.1.clusters.1794.data.isDeepInterviewNeeded = TrueEmpty DATA devices.59391.endpoints.1.clusters.1794.data.commandsClient = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.commandsServerReceived = EmptyBinary DATA devices.59391.endpoints.1.clusters.1794.data.commandsServerGenerated = byte[10] [00030708090A0B0C0D0E]Integer DATA devices.59391.endpoints.1.clusters.1794.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.1.clusters.1794.data.redirectTuyaCluster = FalseBinary DATA devices.59391.endpoints.1.clusters.1794.data.currentSummationDelivered = byte[6] [000000000000]Integer DATA devices.59391.endpoints.1.clusters.1794.data.unitofMeasure = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.1794.data.summationFormatting = 251 (0x000000fb)Integer DATA devices.59391.endpoints.1.clusters.1794.data.meteringDeviceType = 0 (0x00000000)Empty DATA devices.59391.endpoints.1.clusters.1794.data.fastPoll = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.fastPoll.fastPollUpdatePeriod = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.fastPoll.duration = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionDelivered = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionDelivered.endTime = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionDelivered.status = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionDelivered.profileInterval = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionDelivered.intervals = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionReceived = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionReceived.endTime = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionReceived.status = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionReceived.profileInterval = EmptyEmpty DATA devices.59391.endpoints.1.clusters.1794.data.profile.consumptionReceived.intervals = EmptyFloat DATA devices.59391.endpoints.1.clusters.1794.data.metric = 0.000000Integer DATA devices.59391.endpoints.1.clusters.1794.data.status = 0 (0x00000000)Integer DATA devices.59391.endpoints.1.clusters.1794.data.multiplier = 1 (0x00000001)Integer DATA devices.59391.endpoints.1.clusters.1794.data.divisor = 10000 (0x00002710)Integer DATA devices.59391.endpoints.1.clusters.1794.data.demandFormatting = 11 (0x0000000b)Integer DATA devices.59391.endpoints.1.clusters.1794.data.historicalConsumptionFormatting = 120 (0x00000078)Integer DATA devices.59391.endpoints.1.clusters.1794.data.instantaneousDemand = 0 (0x00000000)And a smaller list on the secondary node:Zigbee Clusters for device 59391.2 []:(Input clusters accept commands/events/data from other devices)(Output clusters send commands/events/data to other devices) Cluster 0 0x00 BASICZigbee Cluster data for device 59391 endpoint 2 cluster 0 (0x0000)Empty DATA devices.59391.endpoints.2.clusters.0.data = EmptyBoolean DATA devices.59391.endpoints.2.clusters.0.data.inDirection = TrueBoolean DATA devices.59391.endpoints.2.clusters.0.data.outDirection = FalseBoolean DATA devices.59391.endpoints.2.clusters.0.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.2.clusters.0.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.2.clusters.0.data.interviewDone = TrueInteger DATA devices.59391.endpoints.2.clusters.0.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.2.clusters.0.data.isDeepInterviewNeeded = TrueEmpty DATA devices.59391.endpoints.2.clusters.0.data.commandsClient = EmptyEmpty DATA devices.59391.endpoints.2.clusters.0.data.commandsServerReceived = EmptyBinary DATA devices.59391.endpoints.2.clusters.0.data.commandsServerGenerated = byte[1] [00]Integer DATA devices.59391.endpoints.2.clusters.0.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.2.clusters.0.data.redirectTuyaCluster = FalseInteger DATA devices.59391.endpoints.2.clusters.0.data.zclVersion = 3 (0x00000003)Integer DATA devices.59391.endpoints.2.clusters.0.data.applicationVersion = 18 (0x00000012)Integer DATA devices.59391.endpoints.2.clusters.0.data.stackVersion = 101 (0x00000065)Integer DATA devices.59391.endpoints.2.clusters.0.data.hwVersion = 2 (0x00000002)String DATA devices.59391.endpoints.2.clusters.0.data.manufacturerName = "Jasco Products"String DATA devices.59391.endpoints.2.clusters.0.data.modelIdentifier = "43095"Integer DATA devices.59391.endpoints.2.clusters.0.data.powerSource = 1 (0x00000001) Cluster 3 0x03 IDENTIFYZigbee Cluster data for device 59391 endpoint 2 cluster 3 (0x0003)Empty DATA devices.59391.endpoints.2.clusters.3.data = EmptyBoolean DATA devices.59391.endpoints.2.clusters.3.data.inDirection = TrueBoolean DATA devices.59391.endpoints.2.clusters.3.data.outDirection = TrueBoolean DATA devices.59391.endpoints.2.clusters.3.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.2.clusters.3.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.2.clusters.3.data.interviewDone = TrueInteger DATA devices.59391.endpoints.2.clusters.3.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.2.clusters.3.data.isDeepInterviewNeeded = TrueBinary DATA devices.59391.endpoints.2.clusters.3.data.commandsClient = byte[1] [00]Binary DATA devices.59391.endpoints.2.clusters.3.data.commandsServerReceived = byte[2] [0001]Binary DATA devices.59391.endpoints.2.clusters.3.data.commandsServerGenerated = byte[2] [0001]Integer DATA devices.59391.endpoints.2.clusters.3.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.2.clusters.3.data.redirectTuyaCluster = FalseInteger DATA devices.59391.endpoints.2.clusters.3.data.identifyTime = 54 (0x00000036) Cluster 6 0x06 ON_OFF_SWITCHZigbee Cluster data for device 59391 endpoint 2 cluster 6 (0x0006)Empty DATA devices.59391.endpoints.2.clusters.6.data = EmptyBoolean DATA devices.59391.endpoints.2.clusters.6.data.inDirection = FalseBoolean DATA devices.59391.endpoints.2.clusters.6.data.outDirection = TrueBoolean DATA devices.59391.endpoints.2.clusters.6.data.sendUnsupported = FalseInteger DATA devices.59391.endpoints.2.clusters.6.data.version = 1 (0x00000001)Boolean DATA devices.59391.endpoints.2.clusters.6.data.interviewDone = FalseInteger DATA devices.59391.endpoints.2.clusters.6.data.interviewCounter = 10 (0x0000000a)Boolean DATA devices.59391.endpoints.2.clusters.6.data.isDeepInterviewNeeded = TrueBinary DATA devices.59391.endpoints.2.clusters.6.data.commandsClient = byte[3] [000102]Binary DATA devices.59391.endpoints.2.clusters.6.data.commandsServerReceived = byte[3] [000102]Empty DATA devices.59391.endpoints.2.clusters.6.data.commandsServerGenerated = EmptyInteger DATA devices.59391.endpoints.2.clusters.6.data.profileId = 260 (0x00000104)Boolean DATA devices.59391.endpoints.2.clusters.6.data.redirectTuyaCluster = FalseBoolean DATA devices.59391.endpoints.2.clusters.6.data.onOff = FalseBoolean DATA devices.59391.endpoints.2.clusters.6.data.globalSceneControl = TrueInteger DATA devices.59391.endpoints.2.clusters.6.data.onTime = 0 (0x00000000)Integer DATA devices.59391.endpoints.2.clusters.6.data.offWaitTime = 0 (0x00000000)
