March 4Mar 4 Just made a quick change from SMTP @gmail toe "Use Default" and ran a test and it's back to working again. This is hit and miss.Uploading Attachment...
March 4Mar 4 34 minutes ago, PhanTomiZ said:So how does this setting affect my Gmail account and the ISY for the "TLS negotiation failed? Sounds like a google password/authentication problem?Nothing changes for your Gmail account. The change affects use of their smtp servers that you use to move email. It's well known that certain people abuse smtp to send spam and other garbage. Stronger authentication tries to ensure that the right people are using their smtp servers.ISY supports Basic authentication for their smtp servers, Google no longer supports Basic authentication for reason describe above. They say you have to use their procedure to generate an approved strong password (16 character) if you want to continue to use Basic authentication..BI now supports Oauth which allows you to use your usual Google username and password for authentication to their smtp servers. Edited March 4Mar 4 by mmb
March 4Mar 4 On 3/3/2026 at 3:16 PM, mmb said:Google began phasing out Basic Authentication which is a simple password over TLS in 2022 with a final cutoff date of March 2025. I changed my ISY to their approved password for less secure Apps in 2022. Since then it hasn't missed a beat.Yeah, that's why the wiki changed in 2022. Google finally phased out the simple password, but if users had already changed over to 2FA and the app password it has always worked that way. Nothing in that standing changed after 2022 or 2025. I've had mine setup using Gmail since I started with ISY994 in 2016+/- and aside from a few times can't recall there being a large issue with how the setup worked.On 3/3/2026 at 1:02 PM, Ross said:I've forgotten the process and will need to do some research.The steps to setup (but also same to change) the app password are in the UD wiki, but it basically used the Google support steps to direct users where to go to setup/change the app password. But if you go the route of the support ticket please post back what troubleshooting finds and if there's a larger issue that is being addressed or might need to be corrected in the setup and ultimately in the UD wiki instructions. But since they work for some/most something else has to be the root for some accounts getting this error.21 hours ago, Ross said:Please offer your "Instruction Services" to UDI and write the definitive instructions to Migrate to an EISY! I needed it this past weekend.What do you mean? All they did was copy/paste the UD Wiki information. The wiki has had this info (updated) since 2022 - and prior to that worked for how Gmail used to work. As for instructions about the migration they're in the wiki as well, but probably not the most easy to follow. They're simple and written for when Polisy and eisy were first released.
March 4Mar 4 3 hours ago, Geddy said:I've had mine setup using Gmail since I started with ISY994 in 2016+/- and aside from a few times can't recall there being a large issue with how the setup worked.My ISY has been on Gmail since 2012/2013, likewise never a problem,. Back in the days of LeeG etc.
March 5Mar 5 I've gone as far down the road as I can. There seems to be no way to make the notifications work. I've stuck with my 994 as long as I can (it still works perfect). The fact that eventually everything reaches a life end, I have decided to just buy a new EISY and get somewhat back to the future... That said, I'm on the waiting list now for new stock to arrive. I never would've thought there was a backlog of chip supply again. Hope the wait isn't long. In the meantime, my 994 just wont be able to send me emails - but it will work everything else.
March 5Mar 5 19 hours ago, Geddy said:Yeah, that's why the wiki changed in 2022. Google finally phased out the simple password, but if users had already changed over to 2FA and the app password it has always worked that way. Nothing in that standing changed after 2022 or 2025. I've had mine setup using Gmail since I started with ISY994 in 2016+/- and aside from a few times can't recall there being a large issue with how the setup worked.The steps to setup (but also same to change) the app password are in the UD wiki, but it basically used the Google support steps to direct users where to go to setup/change the app password. But if you go the route of the support ticket please post back what troubleshooting finds and if there's a larger issue that is being addressed or might need to be corrected in the setup and ultimately in the UD wiki instructions. But since they work for some/most something else has to be the root for some accounts getting this error.What do you mean? All they did was copy/paste the UD Wiki information. The wiki has had this info (updated) since 2022 - and prior to that worked for how Gmail used to work. As for instructions about the migration they're in the wiki as well, but probably not the most easy to follow. They're simple and written for when Polisy and eisy were first released.I too did the app password deal 4 years ago with NO issue's until now. I have tried the new app password route and nothing works anymore. I even went as far as to setup a GMX account to try and have it do the sending. It didn't work either. In researching it, it comes down to TLS 1.3 vs. TLS 1.0. 1.3 will not allow the format of sending from the 994. The only way would be to find an email provider that gives TLS in the lesser form! I gave up as my last post details. I'm just going to buy new hardware from UD when it becomes available. Why some folks are still Gmailing is beyond anyone but maybe a geek at Google. My guess is their day will come too.
March 5Mar 5 Author 10 minutes ago, aLf said:I too did the app password deal 4 years ago with NO issue's until now. I have tried the new app password route and nothing works anymore. I even went as far as to setup a GMX account to try and have it do the sending. It didn't work either. In researching it, it comes down to TLS 1.3 vs. TLS 1.0. 1.3 will not allow the format of sending from the 994. The only way would be to find an email provider that gives TLS in the lesser form! I gave up as my last post details. I'm just going to buy new hardware from UD when it becomes available. Why some folks are still Gmailing is beyond anyone but maybe a geek at Google. My guess is their day will come too.The "Default" is working for me, but for whatever reason seems to be more of a delay when sending to my Gmail addresses. As much as an hour sometimes between sending and the mailbox receiving to my iPhone. I used to send to my AT&T text messages, but AT&T killed that some months ago. I'm looking into setting up Pushover using the Network Resources. If you have this option on your 994 it may be the best solution. Still in the learning mode.
March 5Mar 5 9 minutes ago, BCreekDave said:I'm looking into setting up Pushover using the Network Resources. If you have this option on your 994 it may be the best solution. Still in the learning mode.That is a no regret solution. It takes a little to set it up, especially the extremely long Network Resource links. But once you work through those it's a solid, fast solution that is relatively easy to change and expand to new notices.Its additional advantages are what Pushover calls Apps. What they call Apps is actually folders, you can sort your notifications in different folders and each group has a different notification sound and a presence. I have house notices = report kinds of things like sump pump daily activity.. no notification, just there to review. I have another "App" for Battery levels, and one for House Alerts for critical things that screams.Another advantage is that other non-eisy things like firmware upgrades for my router. Those come through an Pushover RSS feed from Zapier. There are a ton of alternative inputs
March 5Mar 5 1 hour ago, BCreekDave said:The "Default" is working for me, but for whatever reason seems to be more of a delay when sending to my Gmail addresses. As much as an hour sometimes between sending and the mailbox receiving to my iPhone. I used to send to my AT&T text messages, but AT&T killed that some months ago.I'm looking into setting up Pushover using the Network Resources. If you have this option on your 994 it may be the best solution. Still in the learning mode.I'm all ears...How do you set this up? 994?I was also told that "Home Assistant" would import all of ISY and it would provide notifications. Anyone done that?Thanks.
March 5Mar 5 Author 1 hour ago, aLf said:I'm all ears...How do you set this up? 994?I was also told that "Home Assistant" would import all of ISY and it would provide notifications. Anyone done that?Thanks.Pushover isn't free. It costs a one time $5.00USD per device.Here are a few links to help the setup process (in no particular order, the last one may be impossible as UDI has blocked any updates to the 994):https://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Networking:Mobile_Notification#Pushoverhttps://pushover.net/apps (don't need polyglot)Use Pushover as an alternative to SMS or email notification | Home Automation GuruAdd the Network Module to your ISY-994i for enhanced functionality | Home Automation Guru Edited March 5Mar 5 by BCreekDave
March 5Mar 5 2 hours ago, aLf said:I'm all ears...How do you set this up? 994?I was also told that "Home Assistant" would import all of ISY and it would provide notifications. Anyone done that?Thanks.There is a Home Assistant Integration for UDI products.. Think of it sort of as what a plugin is to eisy. You install the "Universal Devices ISY/IoX" integreaton on your local Home Assistant server on you local network, and configure it to log into your ISY on your local network. IMO the Home Assistant built in notifications are very unsophisticated, good for debugging programs, that kind of thing. The don't seem to be kept for long after you view them. I think UDM notifications are more sophisticated / better.For Pushover, another option if you have a policy / eisy, is to get the paid for notification server plugin from the plugin store, it works very well and has options galore. This gives details on how "how to"
March 20Mar 20 So I have the same issue as many others. I have two homes. Both have ISY994i ZW/IR Pro v. 5.3.4. Both stopped working with my gmail account on Feb 23. I tried 1) creating a new app password in gmail, 2) removing the account from ISY and putting it back and 3) using default. Nothing worked on either ISY. I switched to my AOL account and all is now working fine. Must be something that the folks at Google changed.
March 21Mar 21 22 hours ago, cwagner2401 said:So I have the same issue as many others. I have two homes. Both have ISY994i ZW/IR Pro v. 5.3.4. Both stopped working with my gmail account on Feb 23. I tried 1) creating a new app password in gmail, 2) removing the account from ISY and putting it back and 3) using default. Nothing worked on either ISY. I switched to my AOL account and all is now working fine. Must be something that the folks at Google changed.My experience as well, EISY and Polisy work fine with Gmail but the ISY doesn't work at all.The ISY Default smtp setting does work fine for me, first try actually.
March 21Mar 21 For what it's worth, long time ISY994 user here; still love it. Also long time user of gmail with ISY, app password, etc. Same recent gmail failure issues. Research for me identified likely issue is that Google/gmail finally/officially deprecated TLS 1.0, which I understand is what ISY uses. Needed new SMTP server. Now using SMTP2GO.com; SMTP2GO still supporting TLS 1.0 for legacy applications. I'm using free plan = 1000 emails/month; working without a hitch.
March 22Mar 22 Interesting. Guess Google just spending too much time, energy and money on their LLM claim to fame...
March 22Mar 22 11 hours ago, Michel Kohanim said:994 supports up to TLS 1.2: Network Security.With kind regards,MichelCurious @Michel Kohanim what is causing the ISY Default smtp failures on the ISY? Even when firmware is updated.It seems so straight forward.
March 22Mar 22 36 minutes ago, mmb said:what is causing the ISY Default smtp failures on the ISY? Even when firmware is updated.Read his earlier reply. Perhaps some changes have finally broken the last ISY994 firmware settings. I recall that there was a time that 4.x and early 5.x wouldn't work with the default due to the changes.
April 2Apr 2 Here is a document I put together on how to locally solve the SMTP email problems that crop up with older devices like the ISY994i. It is pretty simple and straight forward to set up, taking only a few minutes to do, and covers installing E-MailRelay SMTP software on 1 (or more) PCs in your home intranet network. Once installed, you can simply configure your devices to SMTP to the Windows relay PC within your intranet, and have the relay PC do all the "modern day" stuff (encryption, sending to gmail/etc. using TLS port 587, etc.). This should "future proof" SMTP errors from just about any device (ISY, Cameras/NVRs, etc.) within your intranet. I tried to make it understandable, so hopefully I succeeded and it helps someone.*edited: Person reached out regarding a non-ISY device they also have that requires a sender id and password to be entered for the SMTP config on that device. I added a blurb to the page 6 Misc Notes section for that scenario. EmailRelay and ISY994i Setup.pdf Edited April 12Apr 12 by ters Person reached out regarding a non-ISY device they also have that requires a sender id and password to be entered for the SMTP config on that device. I added a blurb to the page 6 Misc Notes section for that scenario.
April 3Apr 3 Edit - August, 6th, 2026: Just wanted to update that I had an opportunity to get into the new car (eisy) and the issue is the same with default. So not sure what changed but it is not reliable and Pushover is still a solid solution for notifications for me at least. The default with ISY is intermittent and over the years I have had similar instances so resorting to gmail and Pushover was the resolution until now where Pushover is still solid.I am still seeing the default working at times but again is inconsistent. For example, most of the day yesterday it was not working and come late evening it started working again. I do not know what is going on when it doesn't and when it doesn't, there is an error when running a test (did not capture my bad) but if it were due to changes, I would expect it to be not working at all. That is not the case and wonder if eisy users see this as well.I do not have any complex use with the ISY which is why it still works well for me on the latest version aside from this. I even pay the higher portal fees over the eisy as the benefit to me is not there to go with eisy at this time. Maybe in the future, but it's like getting a new car when yours is fine and still has low miles serving the purpose getting you where you need to be.Remaining optimistic as I don't need a new car just yet.Able to catch when the ISY default doesn't work error. Interesting thing is it worked and just a minute later did not. Edited August 6Aug 6 by sdynak Adding error screenshot
