November 16Nov 16 Looking for ways to lower the cost if I get my own Claude developers account. Do it not work?
November 16Nov 16 Author @photogeek54 ,There's no such a thing as Claude Developer account. You can buy API Keys, or you can use your own subscription (if you have) and then use MCP.With kind regards,Michel
November 16Nov 16 Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?
November 16Nov 16 Author 17 minutes ago, Guy Lavoie said:Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?Unfortunately not without making public everyone's usage. 1 minute ago, SHM said:Yes, I am using the latest version of the plugin and latest eisy firmwarePlease submit a ticketWith kind regards,Michel
November 16Nov 16 1 hour ago, Guy Lavoie said:Actually, knowing our token usage would be a good part of learning to use eisy-ai. It would allow us to guage our activity to a cost. Is there a way to see it ourselves?If you are using Claude, token usage appears to be available from the Dashboard - Token Volume.
November 16Nov 16 Token usage is shown if you purchased your own tokens. I bought Claude tokens so I can get working but understanding how to keep it cost effective would be very important. Cost me $15 for a very simple fix of an error eisy-ai made. Seems like each time you give eisy-ai a developer command it might have to re-send every file in a plugin plus info on all your programs/devices/variables. That’s a lot. I asked eisy-ai about ways to conserve tokens but mostly it gave suggestions that would be useful to eisy-ai itself.
November 16Nov 16 Author 16 minutes ago, photogeek54 said:Seems like each time you give eisy-ai a developer command it might have to re-send every file in a plugin plus info on all your programs/devices/variablesAbsolutely false. That's the whole purpose behind developer vs. customer modes: they have their own prompt, context and session.What eats up tokens is chatter that cannot be cached. dramatic changes from one turn to the other. And if the context window is too large (say 100K), then it might eventually run out of cache space. And, finally, "simple" for you does not mean simple if it has to review all the files and understands where the mistake is.With kind regards,Michel
November 16Nov 16 Do we have control over the context window? Does it need to be a certain size to handle most development tasks? Is 20000 the correct number to put in the json? Any other suggestions?
November 16Nov 16 Author Context Window is defined by the model. You have control over history_usage. So, if you use 20,000, then when the context gets to about 20K, eisy-ai will try to compact it.With kind regards,Michel
November 17Nov 17 Jusy a quick suggestion - It would be great if the program number was displayed like the variable number in esy-ui - AI often refers to the program numbers in complex programs rather than the name of the program. This is when using AI to generate home automation programs - not plugins
November 17Nov 17 30 minutes ago, Panda88 said:Jusy a quick suggestion - It would be great if the program number was displayed like the variable number in esy-ui - AI often refers to the program numbers in complex programs rather than the name of the program. This is when using AI to generate home automation programs - not pluginsIs there a specific place you are suggesting?The program ID number is already displayed in eisy-ui, right after Next Scheduled Run Time when on the main Program folder line.
November 17Nov 17 The issue is when eisy-ai is active and you are viewing a program it covers the program number - if you are reading the response from AI and it references program numbers it makes it difficult - maybe add it next to the program name when viewing a program
November 17Nov 17 HOW TO ADD FILE UPLOAD TO A PLUGIN IN EISY-AIMy Solaredge Modbus plugin needs to read a complex json file. The version in the store had this functionalityCustom Typed Configuration ParametersZIP File UploadThis will upload the zip file and extract it to the "data" directory of the plugin.Please see plugin help for more details on file upload.and a "select file to upload" button hereI've asked eisy-ai to add this same functionality to my plugin but it doesn't seem to know how. Any suggestions how I get eisy-AI to add this?
November 17Nov 17 Author @Panda88 ,When eisy-ai refers to a program, there's also a link that you can click.@photogeek54 ,Not implemented. For now, you can easily add it by editing your plugin.With kind regards,Michel
November 17Nov 17 Sometimes there is a link. Other times there is not - not is when you need the number
November 17Nov 17 Author It would be great if you can paste an example. This is a bug that needs to be fixed.With kind regards,Michel
November 17Nov 17 Here is a good example : 201 and 212 are highlighted (linked) but 94 and 100 are not Things to checkThe Night off step turns off Garage Light Outdoor, s Garage Light, and Driveway Dual Extra, but the on step doesn't turn those on. That may be intended, but it's worth confirming.Front House appears in both the on and off steps' final section, so it's turned off twice. That's harmless but untidy.The four-light switch routines 201 and 212 are disabled, so only 94 and the disabled 100 currently control these lights.
November 17Nov 17 My tickets site not responding right now, but want to let you know that the new anthropic api works. Pretty amazing so far.
November 17Nov 17 Author 3 hours ago, Panda88 said:Here is a good example : 201 and 212 are highlighted (linked) but 94 and 100 are not Things to checkThe Night off step turns off Garage Light Outdoor, s Garage Light, and Driveway Dual Extra, but the on step doesn't turn those on. That may be intended, but it's worth confirming.Front House appears in both the on and off steps' final section, so it's turned off twice. That's harmless but untidy.The four-light switch routines 201 and 212 are disabled, so only 94 and the disabled 100 currently control these lights.Do these have names?22 minutes ago, SHM said:My tickets site not responding right now, but want to let you know that the new anthropic api works. Pretty amazing so far.So glad to hear! Ticket site should be fixed now.With kind regards,Michel
November 18Nov 18 Author I cannot reproduce at all. So, it's always giving your program numbers instead of names???? Always?With kind regards,Michel
