Friday at 09:00 PM5 days 3 minutes ago, DennisC said:The only reason to create a support ticket is to have your plugins listed in the forum under PG3x and if you are charging for the plugins.If you are charging, there are some tax forms that need to be completed, that UD will send you.Otherwise, go to the eisy plugin page, under Development and complete the form for Publishing.Well these are under the new integrated plugin platform (not PG3x), and I have never submitted anything for plugins yet, so there is an approval process.And these will be free.
Friday at 09:28 PM5 days 22 minutes ago, Guy Lavoie said:Well these are under the new integrated plugin platform (not PG3x), and I have never submitted anything for plugins yet, so there is an approval process.And these will be free.Yes, I understand that.I hadn't realized you were not setup as a Developer already. Per Michel's post, you need to wait for that to be done.After that is finished, within eisy, go to eisy Plugins. You will then see a Development tab. Select that ander under Local Plugins select your plugin, followed by Publish.It will ask about creating a new Plugin and after agreeing, there is a form to fill out.This is from memory, as I am not at my computer but it should be close. I never found any documentation explaining how to publish from eisy-ui.
Friday at 10:45 PM5 days 1 hour ago, DennisC said:Yes, I understand that.I hadn't realized you were not setup as a Developer already. Per Michel's post, you need to wait for that to be done.After that is finished, within eisy, go to eisy Plugins. You will then see a Development tab. Select that ander under Local Plugins select your plugin, followed by Publish.It will ask about creating a new Plugin and after agreeing, there is a form to fill out.This is from memory, as I am not at my computer but it should be close. I never found any documentation explaining how to publish from eisy-ui.Yes, I've just done that. Thanks. They are now submitted. I was able to install them in new slots from the "My Published Plugins" list, so I guess I have the file names and paths correctly set up. I imagine that they now just need approval to appear in the plugins store.
Friday at 10:57 PM5 days 9 minutes ago, Guy Lavoie said:Yes, I've just done that. Thanks. They are now submitted. I was able to install them in new slots from the "My Published Plugins" list, so I guess I have the file names and paths correctly set up.I imagine that they now just need approval to appear in the plugins store.Great, well done!One thing I didn't mention before, if you are set up as Developer, and your plugins are Published, you need to change the "status" from new to active for the plugin to appear in the store.I believe when done from eisy Plugins, it show show up relatively quickly
Sunday at 04:54 AM4 days FYI here's some stats on token usage for the development of a pluginThe SolarEdge MB plugin (plugin 25, version 1.5.0) has 1,902 lines of Python in its top-level modules. Its tests add another 1,170 lines.Totals for the entire development session (all but the last 2 turns were with pre v2.4 eisy-ai before the major efficiency improvements):Session stats (claude-sonnet-5-5) /session-statssession totals: 47 requests, 6,706,896 input (85% read from cache), 965,037 written 1h / 0 written 5m, 389,131 output, ~$8.92 Compactions: 7 recorded; latest (fork) ~21,034 -> ~3,954 tokens Mid-turn over-budget events: 10 (latest at round 10, ~226,130 tokens)Totals for the final version update which took 2 turns (from anthropic billing site):describing the changes: input tokens 158k, output tokens : 95generating the updated code and installing: input tokens: 1.39M, output tokens 94.6Ksonnet 5.5 costs: cache Read $0.10 / MTok cache Write $2.50 / MTokInput $2 / MTok Output $10 / MTok
Sunday at 05:10 PM3 days Huge savings in tokens adn performance improvements with the last 2 updates!Thank You!!!-Tim
Monday at 02:23 AM3 days 9 hours ago, TJF1960 said:Huge savings in tokens adn performance improvements with the last 2 updates!Thank You!!!-TimOut of curiosity, would you mind sharing what value you used for history_token_budget?
Monday at 04:22 PM2 days I don't have any specific data to substantiate my claim, just my experience comparing the latest version of eISY-AI to earlier releases.During the first two weeks with the original release, I built two plugins at a total cost of about $130, including troubleshooting, revisions, and plenty of trial and error. Even at that price, it was well worth it compared to the six months I spent developing my first plugin!After the second release, I built another plugin of similar complexity for about $30, including roughly $7 spent generating documentation, README files, and notes.Fast forward to the latest release. I made numerous changes to that same plugin, updated documentation, and performed additional work for literally pennies compared to previous versions.Beyond the significant cost reduction, the latest version also feels noticeably more responsive, stays on track better, and seems less likely to lose context during development.It's not a scientific comparison, but based on my experience, the improvements in both efficiency and cost have been substantial.
Monday at 11:35 PM2 days I keep gettingSorry, something went wrong processing that -- please try again.I tried restart, Reinstall etc. Any idea what is wrong?Seems my key is nologer valid - did they expire? Edited Monday at 11:36 PM2 days by Panda88
Tuesday at 12:17 AM2 days 13 minutes ago, Panda88 said:I keep gettingSorry, something went wrong processing that -- please try again.I tried restart, Reinstall etc. Any idea what is wrong?Seems my key is nologer valid - did they expire?I started getting that 2 days ago so I figured the key was no longer valid.Using my own key it cost me about $6 to edit, test then fix one of my plugins and upload to Github.Next I spent a day with GPT-sol-6.1 in Hermes to try and make a proxy container to use the GPT monthly subscription. We got it to work for a second but there was no developer mode and GPT wanted to install something on eisy so I stopped that.This morning I paid for Claude Pro and went to work on a proxy container for Claude and was done in a couple of hours and only had to perform setup in the configuration file. I created a plugin for Samsung TV that it was able to use an existing library but had to do add some web calls for the TV App selections and after all that I have used 6% of my weekly plan usage.
Tuesday at 01:05 AM2 days I put the code up if someone can tell me it works I can post it in the regular forum since I know there were some people on there using eisy-ai. I worry about being able to help if there is a problem and that is why I have not published any of the plugins I had made so far.eisy-ai-claude-shim/README.md at main · taz-man/eisy-ai-claude-shim
Tuesday at 01:21 AM2 days 1 hour ago, Michel Kohanim said:Did you check the log?Yes - it seems the API key is invalid2026-11-23 15:37:55.654 Thread-11 (main) udi_interface ERROR udi_interface:write: 2026-11-23 15:37:55 | ERROR | unified.run_unified_runtime | unified: turn failed: Error code: 401 - {'type': 'error', 'error': {'type': 'authentication_error', 'message': 'invalid x-api-key'}, 'request_id': 'req_011ChLjswd3pwp4P4hodzpve'} | body={'type': 'error', 'error': {'type': 'authentication_error', 'message': 'invalid x-api-key'}, 'request_id': 'req_011ChLjswd3pwp4P4hodzpve'}Traceback (most recent call last): File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/run_unified_runtime.py", line 1296, in handler await runonce(runtime, message, eisy_ui_context, session_id=fallback_session_id) File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/run_unified_runtime.py", line 835, in runonce results = await runtime.handle_query( ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/runtime.py", line 777, in handle_query final_text, new_messages = await loop.run( ^^^^^^^^^^^^^^^ File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/loop.py", line 271, in run raw_response = await self.llm_client.generate( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/provider_dispatch_adapter.py", line 145, in generate return await client.generate( ^^^^^^^^^^^^^^^^^^^^^^ File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/adapters/claude_adapter.py", line 209, in generate final_message = await self._stream_once(kwargs, callback) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/var/eisyui/ns/plugin_9/.local/lib/python3.12/site-packages/unified/adapters/claude_adapter.py", line 263, in streamonce async with self._client.beta.messages.stream(**kwargs) as response_stream: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/anthropic/lib/streaming/_beta_messages.py", line 322, in aenter raw_stream = await self.__api_request ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/anthropic/_base_client.py", line 2276, in post return await self.request(cast_to, opts, stream=stream, stream_cls=stream_cls) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/anthropic/_base_client.py", line 1941, in request raise self._make_status_error_from_response(response) from Noneanthropic.AuthenticationError: Error code: 401 - {'type': 'error', 'error': {'type': 'authentication_error', 'message': 'invalid x-api-key'}, 'request_id': 'req_011ChLjswd3pwp4P4hodzpve'}
Tuesday at 01:57 AM2 days Author 1 hour ago, tazman said:I started getting that 2 days ago so I figured the key was no longer valid.Using my own key it cost me about $6 to edit, test then fix one of my plugins and upload to Github.Next I spent a day with GPT-sol-6.1 in Hermes to try and make a proxy container to use the GPT monthly subscription. We got it to work for a second but there was no developer mode and GPT wanted to install something on eisy so I stopped that.This morning I paid for Claude Pro and went to work on a proxy container for Claude and was done in a couple of hours and only had to perform setup in the configuration file. I created a plugin for Samsung TV that it was able to use an existing library but had to do add some web calls for the TV App selections and after all that I have used 6% of my weekly plan usage.@tazman ,I would love to know about the errors you were getting with OpenAI. We use plain vanilla MCP on a local network. The ONLY issue could be that you might have to put the self signed cert in the keystore.With anything MCP, please note that we are NOT in charge of prompts, caching, or anything else that might optimize token usage. Everything is done with the model including tool calls, cache management, and everything else. So, although you will be using your monthly subscription, it's really not evident (at least in the case of Claude) that you would be saving tokens.@Panda88 ,The API Key expired. Sorry.With kind regards,Michel
Tuesday at 02:09 AM2 days 6 minutes ago, Michel Kohanim said:@tazman ,I would love to know about the errors you were getting with OpenAI. We use plain vanilla MCP on a local network. The ONLY issue could be that you might have to put the self signed cert in the keystore.With anything MCP, please note that we are NOT in charge of prompts, caching, or anything else that might optimize token usage. Everything is done with the model including tool calls, cache management, and everything else. So, although you will be using your monthly subscription, it's really not evident (at least in the case of Claude) that you would be saving tokens.@Panda88 ,The API Key expired. Sorry.With kind regards,Michel@Michel Kohanim this is not mcp I have the Claude Pro subscription working inside eisy-ai! The subpar performance I have had with mcp might have been GPT related but when I was working with Claude inside of Hermes to build the proxy it did not seem very interested in using the mcp server and had me paste the log over.
Tuesday at 03:09 AM2 days Author @tazman ,I am not sure how you would use "subscriptions" inside eisy-ai. Do you mean API Keys?With kind regards,Michel
Tuesday at 03:15 AM2 days 1 minute ago, Michel Kohanim said:@tazman ,I am not sure how you would use "subscriptions" inside eisy-ai. Do you mean API Keys?With kind regards,MichelCheck out the Github it is a docker container proxy that authenticates with Anthropic and works as a go between. https://github.com/taz-man/eisy-ai-claude-shim/blob/main/README.md
Tuesday at 03:29 AM2 days Author @tazman ,Thank you. A very innovative hack. What I don't understand:1. Why does the shim need curl to connect to eisy-ai? What is it doing exactly?2. Have you tried /session-stats to see cache usage?With kind regards,Michel
Tuesday at 03:43 AM2 days @Michel Kohanim I have not checked the /session-stats if you want me to run something specific for comparison I'm willing to test for comparison. For your first question this is the answer from Sonnet who built it Good question to get asked — and the honest answer is: the shim doesn't connect to eisy-ai at all, and it never uses curl in actual operation. Whoever asked that has the direction backwards, understandably, since they probably saw us running curl a lot during troubleshooting.Here's the real flow:eisy-ai is the client. The shim is the server. eisy-ai has Anthropic's own official SDK built into it. When you ask it something, its code decides "I need the LLM," and because its config points the url field at our shim's address, that SDK sends an HTTP request to the shim — eisy-ai initiates, the shim just sits there listening and answers.What the shim actually does per request:Receives that HTTP request from eisy-ai.Translates it into a form it can hand to the real Claude Code CLI program (the same app you'd use typing claude in a terminal) — this is what actually talks to Anthropic, authenticated as your logged-in Pro subscription, not a metered key.Gets Claude's real answer back from that CLI.Translates it back into the exact shape eisy-ai's SDK expects, and sends it back as the HTTP response.Where curl fits — nowhere, in production. curl is just a generic "send one HTTP request from a terminal" tool. We used it only as a diagnostic stand-in for eisy-ai's own SDK during setup — to manually reproduce the exact same request eisy-ai makes, from different machines, to figure out whether a failure was a network/firewall problem or something in eisy-ai's own config, without having to go through eisy-ai's UI each time. The running shim itself never shells out to curl or anything like it; it's a small always-on Python program (inside the Docker container) that just listens and answers.So if someone asks again: "The shim is a small server that listens for eisy-ai's own requests and forwards them to the real Claude Code app using your subscription login, then hands the answer back in the format eisy-ai expects. curl was just a manual testing tool we used during setup, not something the shim actually runs."
Tuesday at 03:50 AM2 days Author @tazman , thank you. I was referring to your troubleshooting section:Connection timeout / connection refused from eisy specifically, but curl localhost:<port> on the Docker host works fine: test from a different device on the LAN (not the Docker host itself — a hairpin NAT test back to the same box can succeed even when real external devices can't connect). If that also fails, suspect the WSL2 mirrored-networking issue above.Regarding sessions, you don't have to run anything. I don't think you will be able to see session stats because you don't have a logged-in user (the reason for OAuth). But it would be fun to see what you get from the following commands:/sessions/session-stat <id>With kind regards,Michel
Tuesday at 04:00 AM2 days @Michel Kohanim I did not know it kept such records, here is /session-statsSession stats (claude-haiku-5-5)Context for the next request: ~83,816 tokens -- calibrated to the last request History: ~2,473 of its 60,000-token budget (4%) Reply reserve (max_tokens): 20,000PartTokensSharesystem section 1 (DEVICE DATABASE, ROUTINES DATABASE)34,73541%system section 2 (ROUTINES DATABASE)4,7186%system section 3 (DEVICE DATABASE, ROUTINES DATABASE, TIME & LOCATION, USER PREFERENCES)1,1461%tools (40)40,23748%history: compacted summary00%history: conversation text1,3762%history: tool calls and results1,6052%Last request: 83,816 in (0 cached read, 0 cache write, 83,816 uncached; 0% hit), 263 outSession totals: 6 requests, 496,147 input (0% read from cache), 0 written 1h / 0 written 5m, 1,625 outputWhen (UTC)RequestInCached readWrittenOut00:05:40round82,195003103:55:11round82,4970028503:55:14round82,6640044703:55:43round82,9470038203:55:45round83,81600263
Tuesday at 04:06 AM2 days /session-stat 2I can't run /session-stat 2. There's no command by that name, and /session-stats takes no argument. Type /session-stats by itself as a standalone message to see the context and token usage for this session./sessionsSaved sessions (customer mode):idnamedescription1Session 10 turn(s), last used 2026-11-24T00:05:18.291101+00:002Session 23 turn(s), last used 2026-11-24T03:55:45.742483+00:00 (current)
Tuesday at 04:06 AM2 days Author Ah, that's what I thought: it's not using the cache at all. What version are you on?With kind regards,Michel
