Everything posted by DennisC
ambient weather rain data
Sorry, had a long day yesterday......
Well, above you wrote: "My program was activated by this data, but it is written to activate only if daily precipitation is >0.45", but the program you posted says "<= 0.750 Inches"?
Smoke \ Co2
That is exactly my point. By doing this, you are not using the built in Elk smoke detection input, notifications, & quick action buttons. Also, by code, there are other requirements that need to be met when using a relay for smoke detection (supervised monitoring of relay). According to the Kidde documentation, these devices are meant to be for auxiliary warning devices, not primary notification and alarming. Would they work, probably, but......
Smoke \ Co2
How would they tie in to the Elk dedicated smoke detector terminals, which requires a 4 wire smoke detector?
Smoke \ Co2
This is what I am currently using: https://www.jmac.com/UTC_Formerly_GE_SecurityESL_541NCSXT_p/UTC-GE-ESL-541NCSXT.htm
Polisy Offline after firmware upgrade
Start with rebooting eisy.
New to plugin(s)
You can start here: https://wiki.universal-devices.com/Eisy:User_Guide#eisy_(PG3)_Dashboard Once you decide on your first plugin, go to the store and select the plugin you are interested in. Most of the plugins have a more button, following that link will take you to specific instructions to configure the plugin.
eisy not responding, PLM "Not Connected" error
If you are using eisy with a serial PLM, a special cable is needed. Are you using the correct cable and if so, could the cable be defective?
ZSE50 - Power Outage Detection
I use Yolink Power Failure device at two locations, along with Yolink Plugin. Works flawlessly.
Admin Console cannot run; JRE install error 1603
I have to agree with @Geddy , strange file location. When you reboot, are you shutting down and restarting, or just restarting? I would suggest you shutdown, restart, and then follow these instructions: https://www.java.com/en/download/help/uninstall_java.html to run the Microsoft utility listed under troubleshooting. That will repair any corrupted files and stray registry entries. Afterwards, shutdown, reboot, and then try the offline installer.
Since you deleted that folder, have you tried rebooting, followed by using the instructions in the troubleshooting guide? That note about "investigating" this issue has been around for several years. I wouldn't wait on them finding an issue.
I have experienced the Java 1603 a couple of times over the years when updating. While this doesn't sound like it will help you, I was able to correct it by using the offline installer listed here: https://www.java.com/en/download/help/error_1603.html
Can I get MyQ to work with eisy
That is not completely true. Even with Liftmaster coded system, you can use one of the below listed opener switches and then connect dry contacts to the terminal board. I did this a few years ago with a new Liftmfaster torsion bar garage door opener. https://www.amazon.com/883LMW-LiftMaster-Button-Control-Security/dp/B07W5RMN56/ref=asc_df_B07W5RMN56?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80470717339467&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=m&hvlocint=&hvlocphy=98524&hvtargid=pla-4584070199414765&psc=1&msclkid=382c3ea2718c12808f9857558fc91362
UD Mobile Suggestion to Open to Favorites
That's weird and I don't really have an answer for you. However, I would offer up one clarification, just to be sure. After long pressing the app icon, are you then selecting "add to home screen" or are you again long pressing on the word "Favorites" and holding it until your home screen appears? When I do it, I hold the word Favorites and release it on the home page. I know this works, because I did it two weeks ago on 2 new phones.
Shouldn't be, I have been using UD Mobile on my phone and my wife's phone since it came out. I have never lost the Favorites app icon and it always opens to the Favorites tab. Maybe try again?
It has always been in the UD Mobile WIKI: https://wiki.universal-devices.com/UD_Mobile#Favorites
For Android, go to the main app and long press it. In the pop up, you will see Favorites with a + sign. Hit that followed by add to home screen. The new short cut on the home screen will open to Favorites.
INIT TO causing variable to be zeroed out
That's why I posted the link to the wiki instructions. That is the closest thing we have available to a "book". Once you take the plunge, it's not that hard. Most have a free trail period you can take advantage of before purchasing.
Part of the UD universe included being able to connect different devices to their automation controllers using Plugins, formerly called Nodeservers. One of those Plugins is called TimeData. Here is a link to more information: GitHubDocs/TimedataPG3 at main · ve7gel/DocsREADME.md files for PG3 nodeservers. Contribute to ve7gel/Docs development by creating an account on GitHub.Here is a link to the Plugin store: https://polyglot.universal-devices.com/ Here is a link to the wiki instructions for getting started: https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#eisy_(PG3)_Dashboard Let me know if you need something more.
Detecting Mobile Phone Entered and Exited WiFi Range
I typically recommend this: https://guardline-electronics.myshopify.com/products/guardline-500-ft-wireless-driveway-alarm Been using it for about 6 or 7 years without an issue. This one has a range of 500 feet, but they also have ones with a longer range. In my case, I connect it to my Elk and with the Elk plugin, get it to my eisy. You could also connect it to an IO Link.
Right click on the program name and select copy to clipboard. Are you aware there is a plugin for using dates in programs?
How to find my current EISY software version numbers
For the latest upgrade (v6.5.0), UD has advised to upgrade from the admin console. Got to the admin console, system configuration and select upgrade packages.
Suspend option?
As long as you are not in the Elk plugin at the time, you should not have to stop the plugin manually. Just start and connect with ElkRP. The Elk plugin will reconnect when the connection is available again.
Recent upgrade to 6.0.5, PG3X not found
As a follow up, it is possible the update did not complete correctly. First try getting in through https://eisy.local If that doesn't work, then go back to admin console and run update packages again. Be sure to reboot after the upgrade is complete.
Not sure what you are showing in your screenshot labeled eisy.local, but your screenshot shows admin console, not eisy local. Have you tried: https://eisy.local This should be done from your home network and you should accept the security warnings and continue.
