oberkc
Everything posted by oberkc
  1. This is NOT the the web admin portal that replaces the java console. I don't recall the version of IoX that includes the new web interface, but 6.1.2 sounds relatively recent. Try typing your local ip address into the safari address bar and see what you get. It should look something like this:
  2. I did a similar update this morning. Lost zwave. Lost all plugins. After some experimentation, I fond that migrating plugins back to pg3 (where they still did not work) then back to eisy plugin fixed many. Zwave experience was like everyone. Several reboots ultimatey fixed it. There is two hours of my life I am not getting back. It sure makes me hesitant to update an otherwie-working system.
  3. Yes, that is how it worked for me. No. Different QR code. Once you pair it with Alexa app, you must share it FROM Alexa to IoX. That process would generate a different QR code. I have tried. No luck so far. I may try again now that I have the Eero system added to my setup.
  4. Yes, but you had the Echo and Eero system, it sounds like, which had a border router. The point that I was trying to make was that the Eero, alone, appears to me to be unable to add a thread device, even though it has the thread border router. (There appears to be no option in the Eero app to include a thread device into the network). It appears to me that the Eero system requires another device, such as an echo or nest hub, or apple home, in order to initiate the thread device inclusion process. I suspect you are correct, however, that the google or echo devices do not actually need to include thread, themselves, so long as the Eero or another border router exists in your network.
  5. For what it is worth, I have a Google hub, second generation and an Alexa hub, both can act as thread border routers. I have recently added an eero Network to my house which also includes a border router capability. So far, my perception is that the eero works in conjunction with Alexa or Google or Apple or something like that in order to incorporate thread devices into the network. It is my understanding that all my thread border routers work with each other. In order to add a thread device to eisy, one must first add it to something that actually has a border router in it. Such as, again, Alexa, Google, whatever. Whatever. From Google, for example, one adds a new device and either scans the bar code printed on the actual device or by typing him the numeric code by hand. Either seem to work fine for me once added to Google or Alexa, share it from Alexa or Google or something else to eisy. This is done by going to the device in Alexa or Google and sharing it, which would generate another barcode or numeric code. Then, from eisy, go to your protocols, choose matter, and add new matter device from there. It will ask for the code. Type it in. If you are lucky, it will find the device and add it to your nodes. If you are less than lucky, don't hesitate to try it again. Sometimes it takes more than one try. I have had mixed success so far with matter but I remain hopeful that it will continue to improve. I think both Alexa and Google have updated their matter versions on my devices and I also hope that the addition of the ero border routers will improve my long-term consistency. So far, the only thread devices I have are a couple of light bulbs with which I am experimenting. I have a good number of govi devices that have matter over Wi-Fi. Only one remains connected by a matter. At this point. I am waiting for a quiet time to pick it back up and continue trying.
  6. If it works from the app, but Alexa voice cannot control it, my first concern is that the name in Alexa for the device does not match my voice request or is ambiguous. Regardless, this sounds like an Alexa problem.
  7. FWIW, the following appears to be working for me: Twinkly Notification Ring Holidays YolinkLocal Govee AmbientWeather Virtual Caseta Harmony Hub Having said this, when I deleted those "working" migrated plugins from the legacy PG3x system, ALL of my migrated-and-working plugins ceased working. Furthermore, my migrated plugins continue to receive notifications in PG3x (new version available, restart admin console) and do not get these notifications in the new easy-plugin environment. I cannot help but suspect that the eisy-plugin remains dependent on PG3x.
  8. Well, not totally useless. I observed that there seemed to be a relationship between the device type and X-10 code. It appears that the 02 represents house code B. 01 represents house code A, 03 represents house code C, etc... I am one of those. It does
  9. I tried following these instructions as well, and also found the third step elusive. Having said this, the suggestion above from @Guy Lavoie seems to work for me. In different words... from the menu, go to protocols>>Insteon>>add new Insteon device. Give it a name, and X10 control in the address field (such as A1). Leave the third "auto discover" field as is. Choose "OK". If your experience is like mine, you will get an orange banner advising you that it is saving the device. After the popup menu asking whether you want to rename the device or not, it shows up under nodes as an unknown device with an address something like ff XX XX 1. The address format matches some of my old X10 devices created many years ago using the x10 module option and admin console. (see attached image where the last device is my newly-added x10 and all others before it were carry-overs from the admin console). Reminder: the original ability to create an X-10 node and name it was only an option if one purchased the X10 module and added it to the ISY and the admin panel. Otherwise, the only way to transmit an x10 command was via a program. The ability to transmit x10 codes appears to currently remain available in the EISY-UI in programs as well. While I have not tested this (currently don't use X-10), it appears to me that X10 capability still exists fully in the current EISY-UI world.
  10. It may depend on how the keypadlinc is set up. Did you use mutual-exclusive relationships built into the keypad? If so, then I suspect that the backlights will be correct only at the device. I would have responded the same as Javi...I don't believe that remotely controlling a device (whether from the admin console or mobilinc or udmobile) would ever trigger a scene response. As far as I remember back, Insteon devices only act as scene controllers when physically toggled locally. As Javi pointed out, the potential workaround would be to control the scene, but use the individual device as a status indicator.
  11. Yes, you need the Yolink hub. Additionally, you would need the Yolink plugin for PG3 (or the EISY-plugin). I don't remember the details, but I recall that it took a few steps to get working. I don't recall any surprises. I started with the original "hub", then migrated to the "local hub". If I recall correctly, the local hub required a different plugin as well. Both worked reliably and the local hub continues to do so. Your choice of hub, as far as I can tell, depends entirely on how important is it to you that your system can operate without an active internet connection. I use motion sensors, moisture sensors, and a power strip. It is among the plugins that I consider rock solid.
  12. oberkc replied to oberkc's topic in eisy
    It makes me wonder about the purpose of the "delete" option and whether the new EISY-plugin is actually working.
  13. oberkc replied to oberkc's topic in eisy
    Sorry to hear this. So that you know, I have again migrated (some of my) plugins to "plugin", but have not yet deleted them from PG3. After a few hours, everything is still working. I will keep you informed.
  14. oberkc posted a topic in eisy
    A few days ago, I migrated most of my plugins from "legacy" PG3 to the EISY Plugins. Most worked well with a couple requiring extra steps to get working. Since they were now working in the new EISY plugin, I chose to delete from PG3. Soon thereafter, all of the nodes associated with the various plugins were gone. Ultimately, I was able to restore a recent backup and the PG3 was repopulated with the configuration prior to migration, and all the programs and scenes containing the plugin nodes were restored. Has anyone else experienced this problem? Was this problem associated with my decision to delete the migrated plugins from PG3? Has anyone else deleted migrated plugins from PG3? Other thoughts?
  15. I believe that is done by creating" an empty" widget and then using that empty widget to create the spaces you desire.
  16. oberkc replied to SHM's topic in YoLink
    I will add that mine local plugin quit working when I migrated to the EISY "Plugin" from PG3. I migrated back to PG3 and it is remains non-functional, with all node and controller fields blank. I have restarted the PG3 node server and rebooted the EISY. Still no luck. Update: I rebooted the PG3 node server again and it seems to be back online.
  17. Yes. I am confused, then. The registration page shows 10 - 11am (presumed and confirmed PST). The Email response shows 10 - 11 EST.
  18. I have had similar experience with the single thread device with which I am experimenting. I also have similar experience with matter-over-wifi devices. I have never satisfied myself that I know the root cause. For now, I am not adding any more matter devices.
  19. I assume all posted times, including at the registration page, are PST
  20. I have not experienced this problem. My plugins always restart and work fine after power outages or other unexpected reboots. A while ago, I recall a few plugins that may not have worked after a power outage, but I percieved this was the result of a plugin restarting faster than the associated hub (hue plugin restarted faster than did the hue hub, for example). I have not noticed such problems recently, however.
  21. Are your ue devices integrated via the hue hub? If so, I thought one could create a group in the hue app, which would show up as its own single node in the EISY. I am wondering aloud if this single node could be controlled as you wish.
  22. Twice a year this topic arises. Give it an extra day and (if your experience matches mine) it will fix itself.
  23. oberkc replied to shadowb's topic in eisy
    I understand. A few years ago, I believe there was confusion between how insteon defined scenes versus how UD defined them. But...when one is wondering where the scenes are shown and created/edited, it seemed worth mentioning.
  24. oberkc replied to shadowb's topic in eisy
    Also, "scenes" are now "groups".
  25. Yours looks a lot different than mine:
