Everything posted by oberkc
Integrated plugins: list of what works ok?
FWIW, the following appears to be working for me: Twinkly Notification Ring Holidays YolinkLocal Govee AmbientWeather Virtual Caseta Harmony Hub Having said this, when I deleted those "working" migrated plugins from the legacy PG3x system, ALL of my migrated-and-working plugins ceased working. Furthermore, my migrated plugins continue to receive notifications in PG3x (new version available, restart admin console) and do not get these notifications in the new easy-plugin environment. I cannot help but suspect that the eisy-plugin remains dependent on PG3x.
How to add old X10 devices to EISY-UI?
Well, not totally useless. I observed that there seemed to be a relationship between the device type and X-10 code. It appears that the 02 represents house code B. 01 represents house code A, 03 represents house code C, etc... I am one of those. It does
I tried following these instructions as well, and also found the third step elusive. Having said this, the suggestion above from @Guy Lavoie seems to work for me. In different words... from the menu, go to protocols>>Insteon>>add new Insteon device. Give it a name, and X10 control in the address field (such as A1). Leave the third "auto discover" field as is. Choose "OK". If your experience is like mine, you will get an orange banner advising you that it is saving the device. After the popup menu asking whether you want to rename the device or not, it shows up under nodes as an unknown device with an address something like ff XX XX 1. The address format matches some of my old X10 devices created many years ago using the x10 module option and admin console. (see attached image where the last device is my newly-added x10 and all others before it were carry-overs from the admin console). Reminder: the original ability to create an X-10 node and name it was only an option if one purchased the X10 module and added it to the ISY and the admin panel. Otherwise, the only way to transmit an x10 command was via a program. The ability to transmit x10 codes appears to currently remain available in the EISY-UI in programs as well. While I have not tested this (currently don't use X-10), it appears to me that X10 capability still exists fully in the current EISY-UI world.
Scene Controller Behavior in eisy-ui / UD Mobile
It may depend on how the keypadlinc is set up. Did you use mutual-exclusive relationships built into the keypad? If so, then I suspect that the backlights will be correct only at the device. I would have responded the same as Javi...I don't believe that remotely controlling a device (whether from the admin console or mobilinc or udmobile) would ever trigger a scene response. As far as I remember back, Insteon devices only act as scene controllers when physically toggled locally. As Javi pointed out, the potential workaround would be to control the scene, but use the individual device as a status indicator.
Adding YoLink sensors to an ISY setup — what should
Yes, you need the Yolink hub. Additionally, you would need the Yolink plugin for PG3 (or the EISY-plugin). I don't remember the details, but I recall that it took a few steps to get working. I don't recall any surprises. I started with the original "hub", then migrated to the "local hub". If I recall correctly, the local hub required a different plugin as well. Both worked reliably and the local hub continues to do so. Your choice of hub, as far as I can tell, depends entirely on how important is it to you that your system can operate without an active internet connection. I use motion sensors, moisture sensors, and a power strip. It is among the plugins that I consider rock solid.
Plugin Migration
It makes me wonder about the purpose of the "delete" option and whether the new EISY-plugin is actually working.
Plugin Migration
Sorry to hear this. So that you know, I have again migrated (some of my) plugins to "plugin", but have not yet deleted them from PG3. After a few hours, everything is still working. I will keep you informed.
Plugin Migration
A few days ago, I migrated most of my plugins from "legacy" PG3 to the EISY Plugins. Most worked well with a couple requiring extra steps to get working. Since they were now working in the new EISY plugin, I chose to delete from PG3. Soon thereafter, all of the nodes associated with the various plugins were gone. Ultimately, I was able to restore a recent backup and the PG3 was repopulated with the configuration prior to migration, and all the programs and scenes containing the plugin nodes were restored. Has anyone else experienced this problem? Was this problem associated with my decision to delete the migrated plugins from PG3? Has anyone else deleted migrated plugins from PG3? Other thoughts?
Spaces on Favorites window
I believe that is done by creating" an empty" widget and then using that empty widget to create the spaces you desire.
upgrade fails in eisy ui
I will add that mine local plugin quit working when I migrated to the EISY "Plugin" from PG3. I migrated back to PG3 and it is remains non-functional, with all node and controller fields blank. I have restarted the PG3 node server and rebooted the EISY. Still no luck. Update: I rebooted the PG3 node server again and it seems to be back online.
Webinar Time Poll
Yes. I am confused, then. The registration page shows 10 - 11am (presumed and confirmed PST). The Email response shows 10 - 11 EST.
Matter thread devices lost connections
I have had similar experience with the single thread device with which I am experimenting. I also have similar experience with matter-over-wifi devices. I have never satisfied myself that I know the root cause. For now, I am not adding any more matter devices.
Webinar Time Poll
I assume all posted times, including at the registration page, are PST
Plugins Fail After Reboot of Eisy
I have not experienced this problem. My plugins always restart and work fine after power outages or other unexpected reboots. A while ago, I recall a few plugins that may not have worked after a power outage, but I percieved this was the result of a plugin restarting faster than the associated hub (hue plugin restarted faster than did the hue hub, for example). I have not noticed such problems recently, however.
Changing multiple Hue bulbs' Colors in a Scene
Are your ue devices integrated via the hue hub? If so, I thought one could create a group in the hue app, which would show up as its own single node in the EISY. I am wondering aloud if this single node could be controlled as you wish.
Sunrise/Sunset Off w/ Time Change
Twice a year this topic arises. Give it an extra day and (if your experience matches mine) it will fix itself.
No Scenes in eisy-ui!
I understand. A few years ago, I believe there was confusion between how insteon defined scenes versus how UD defined them. But...when one is wondering where the scenes are shown and created/edited, it seemed worth mentioning.
Also, "scenes" are now "groups".
Looking for documentation on EisyUI plugin migration
Well, I tried migrating one (Caseta) plugin. It showed up in the EISY-plugin and told me to hit the black button on the back of the caseta hub (I did). The nodes did not show up. All old caseta nodes are gone, and no new nodes showed up. I did a Quick Look at the log and it showed a bunch of lines with error messages. I went back to PG3x and had to recreate all the former scene and folder memberships. I am inclined to wait a bit longer in the hope that these types of problems will be resolved.
Polisy Pro Migration to eisy lite-Feedback Requested
I had the zmatter stick, so I did not have any first hand experience with a non-UD zwave dongle. I do not recall an option at that time to backup and restore a zooz device. Others may have better recollection. I recall, also, that there may now be a backup method for aftermarket dongles in one of the newer updates to eisy-ui. Of course, if true, this would necessitate updating your polisy, which sounds like a burdensome task. Hopefully, others may have better news.
The best instructions I have seen for migration is in the wiki: https://wiki.universal-devices.com/Eisy:User_Guide#Migration
Trigger a Program in Mobile; no device in "If"
I believe, to define a program as a favorite, one must pick "command" as the type of favorite. After filling in the basic favorite fields, UD mobile will prompt you for the command. At this point you pick the node (the program in this case) and the command to execute (run if, run then, run else). At least, this is how I have done it and it seems to work for me.
IOS Location Access setting uncommanded change
I assume this is unrelated, but I have been having ongoing problems with geolocation on android. Sometimes it works, sometimes it does not. Sometimes the entry and exit commands turn up missing. I do not believe that I have seen many cases of location permission (always on) changing. I have tried various options in the app to try to force location updates, without any impact that I can recognize. If this is not helpful, feel free to ignore.
GoVee and matter control via insteon keypad
I have started to play around with some of these parameters. Based on memory, if you define color temperature, you will generally get a “white”, with warmer ir cooler tones. I have also had some luck asking mr google what xy numbers one can use for a given color. My experience so far is that the admin panel may not reflect the actual status. I plan to contine to continue to explore this capability. Perhaps we can share notes with each other.
