August 29Aug 29 I think it was my fault not rebooting the polisy. I was doing shutdown now -r and should have been shutdown -r now , or better to use sudo rebootI will try this next time to make sure the argument order is correct. I am used to linux which doesn't have this issue.However in admin console, restart IoX doesnt seem to work and it hangs, I have to restart again via ssh eg... sudo service isy restart maybe that is not supported command anymore and is old.
August 29Aug 29 13 hours ago, Michel Kohanim said:I'd like to hijack this thread and tease you with our upcoming feature: eisy-ai !With kind regards,MichelCan’t be wait to use it to write programs (maybe not as I enjoy using the brain cells) and do research. Thanks, Michel.
August 29Aug 29 I’ve not seen it discussed here (could have missed it) but starting with 6.1.1 from Michel’s release notes there is a built in restore point that enables us to revert back to the prior version if something happens during an upgrade. Look at eISY-ui System Boot environment. My upgrades have always been fine but it’ll be beyond value if one ever fails. My home is run by eISY. Saying happy wife happy life. Add to that happy eISY I’m not too busy.
Sunday at 03:15 AM5 days 13 hours ago, hart2hart said:Can’t be wait to use it to write programs (maybe not as I enjoy using the brain cells) and do research. Thanks, Michel.Already does very complex ones and can spot and fix errors.With kind regards,Michel
Sunday at 04:23 PM5 days I may well be the slowest guy on this forum! I managed to upgrade the unit to the new firmware - no issues that I can see so far. Took less than 20 minutes...I had to do the usual Java deletes in order for the AC to work - no problem there, Then I notes that the desktop icon was gone and the only way to access AC was through http://isy.ip/admin.jnlp . Worked fine. But I've tried everything I know to re-establish the UD icon for faster logins. The old tried and true way will not leave an icon.
Sunday at 04:37 PM5 days 13 hours ago, Michel Kohanim said:Already does very complex ones and can spot and fix errors.With kind regards,MichelVery interesting Michel, can the eISY AI do a review of all my Programs to determine if there are any problems that need to be addressed? Like AGY AI?
Sunday at 05:29 PM5 days On 8/18/2026 at 10:58 AM, Greg P. said:Upgrade itself seemed to go smooth but after finishing and rebooting, my eISY UI customized Home Page is gone. Any way to get that back without re-creating it?I didn't see a response to this post. Is there a way to get Customized Home Page back?
Sunday at 06:02 PM5 days 33 minutes ago, pkelley said:I didn't see a response to this post. Is there a way to get Customized Home Page back?I think you have to rebuild it... Edited Sunday at 06:03 PM5 days by JimTurner More info
Sunday at 06:13 PM5 days 1 hour ago, mmb said:Very interesting Michel, can the eISY AI do a review of all my Programs to determine if there are any problems that need to be addressed? Like AGY AI?@mmb , currently, if you give it a problem, such as why this is/is not happening, it will review your logs, then reviews all your programs to come up with a reason. It can also summarize all your programs in a folder as well as find relevant programs. It can also figure out if the logic doesn't make sense. What it can't (yet) do is to answer generic questions without any context. For instance, what type of problems? Also, this plugin is configurable to use Claude, ChatGPT, and Grok. So the more expensive the model you use, the better the reasoning. Everything I described above is based on the least expensive models (Claude Haiku and GPT Luna).With kind regards,Michel
Sunday at 06:44 PM5 days Author 25 minutes ago, Michel Kohanim said:@mmb , currently, if you give it a problem, such as why this is/is not happening, it will review your logs, then reviews all your programs to come up with a reason. I get a sense that it might get incorporated into UDI's support, possibly as a self-help screening process if you want to open a ticket. Not that I'm against the idea. Just something that seems to be in the queue. It could be useful for some of the usual questions that can be hard to search on the forum, such as "What updates are still supported on the Polisy?" or "What is the proper procedure to replace a Insteon PLM?".
Sunday at 08:09 PM5 days 3 hours ago, aLf said:re-establish the UD icon for faster logins. The old tried and true way will not leave an icon.@aLf Make sure the "Keep temporary files on my computer" box in Java Control Panel>Temporary File Settings is checked.
Monday at 02:40 AM4 days 7 hours ago, Guy Lavoie said:I get a sense that it might get incorporated into UDI's support, possibly as a self-help screening process if you want to open a ticket. Well AI engines have pretty much sucked up all knowledge on the internet, so my goto when I have a question as you suggested is just head to Gemini or AGY.For me what will be nice is eISY’s plug-in to dig into logs and coding, and suggest/make changes.
Monday at 01:05 PM4 days Started my upgrade and it proceeds as expected then stops and says Check Logs? I see nothing in the logs... I will open a ticket
Monday at 01:48 PM4 days 20 hours ago, pkelley said:I didn't see a response to this post. Is there a way to get Customized Home Page back?First of all, it would be very odd to lose the Favorites page following an upgrade. Did you restore a backup or something?The only solution really is to restore a backup from just before the upgrade.Just restore eisy-ui, like this:
Monday at 01:59 PM4 days 4 minutes ago, bmercier said:First of all, it would be very odd to lose the Favorites page following an upgrade. Did you restore a backup or something?The only solution really is to restore a backup from just before the upgrade.Just restore eisy-ui, like this:No Restores were performed. Upgrade went pretty much as expected. I did have issues with 2 plugins (iox-matter and VenstarCT). A second restart resolved the VenstarCT problem, and I had to reinstall iox-matter to resolve that issue. All is working exactly or better than it did before the upgrade. Losing the Custom Page is not a big deal this time. I'm really liking what you can do with the new UI after this upgrade, so will be a bigger deal if it happens again.
Monday at 08:45 PM4 days 9 hours ago, Michel Kohanim said:@mmb , currently, if you give it a problem, such as why this is/is not happening, it will review your logs, then reviews all your programs to come up with a reason. It can also summarize all your programs in a folder as well as find relevant programs. It can also figure out if the logic doesn't make sense. What it can't (yet) do is to answer generic questions without any context. For instance, what type of problems?Also, this plugin is configurable to use Claude, ChatGPT, and Grok. So the more expensive the model you use, the better the reasoning. Everything I described above is based on the least expensive models (Claude Haiku and GPT Luna).With kind regards,MichelOn 8/28/2026 at 10:52 PM, brians said:I think it was my fault not rebooting the polisy. I was doing shutdown now -r and should have been shutdown -r now , or better to use sudo rebootI will try this next time to make sure the argument order is correct. I am used to linux which doesn't have this issue.However in admin console, restart IoX doesnt seem to work and it hangs, I have to restart again via ssh eg... sudo service isy restart maybe that is not supported command anymore and is old.To clarify, I was using restart IoX in a program (action, system, restart IoX). The System program action's "Restart IoX" doesn't restart it fully and hung needing service isy restart to recover. The Configuration menu's reboot works fine and appears to use a different method as it restarts the entire Polisy. Therefore should the program action be pointed at that one or is this something specific to my Polisy and fixed or not issue in EISY? Or this this old and nobody uses anymore? I honestly see no use for it on a regular basis but maybe someone does.
Wednesday at 11:43 AM2 days 8 hours ago, apostolakisl said:Just updated to 6.1.2_3. All looks good.Did you update date from the Staging repo?
Wednesday at 05:24 PM2 days 4 hours ago, apostolakisl said:YesThanks. I’m looking so forward to repositioning my very small zwave network from mesh to star topology with 6.1.2 Long Range update. Most of my zwave network is there only to provide mesh for critical devices that provide energy information to detect that the device is currently pulling current.
Wednesday at 05:29 PM2 days @hart2hart ,Please note that your devices must support LR for that to work. Not all do.With kind regards,Michel
Wednesday at 07:02 PM2 days 1 hour ago, Michel Kohanim said:@hart2hart ,Please note that your devices must support LR for that to work. Not all do.With kind regards,MichelThanks, Michel. They are on my desk awaiting their install!
Wednesday at 09:45 PM2 days Here's an interesting AI article on Zwave LR battery operated devices@hart2hart When you install your Zwave LR device(s) could you post the results Zwave LR battery life.pdf
Wednesday at 10:19 PM2 days 13 minutes ago, Techman said:Here's an interesting AI article on Zwave LR battery operated devices@hart2hartWhen you install your Zwave LR device(s) could you post the resultsZwave LR battery life.pdfI’ll definitely post results but sorry to pre-disappoint as they are all mains powered. I had read something similar on the results as they only talk to hub and are not constantly repeating within the mesh. I may consider expanding zwave usage if it all works as expected. I’m a big Insteon user with between75 and a 100 devices. I got into zwave for deadbolts and then expanded it when Insteon SyncroLincs died. At this point, the only important devices are for energy reporting needs. Retired zwave deadbolts a few years ago.
Yesterday at 12:54 PM1 day I like to know more about this. I read about Java going away. Sadly I dont understand any of this ioo upgarde and not afraid to admit it. Any one will to shed some light in non engineer terms
