February 24Feb 24 20 hours ago, jaysmc said: My eisy seems to be comfortable with 5.8.4. I've tried updating repeatedly over the past few days, and it's still on 5.8.4. It's not a critical update for me though, I won't be using any matter devices soon and everything is functioning fine as is. I'll probably have to open a ticket sometime. How have you tried to update?
February 25Feb 25 Hi, just wanted to share my experience here. I have both eISY and POLISY devices and both had 5.8.4 prior to the upgrade to 5.9.1. The eISY upgraded without any issue. I left it for 30 mins after I clicked on the upgrade packages button, and then rebooted it. I restarted the admin console and I saw that it's on 5.9.1 and I confirm the OS version via https://eisy.local:8443/WEB/sysconfig.txt and it is at 14.1. And that's very seamless. Then I shut my eISY and turn on my POLISY device (I don't think I need to do this but I just didn't want to get confuse). POLISY is my backup device so it's typically off and I only turn it on when I need to update the firmware or if I want to do some testing. Anyway, same thing I did but this time the UUID was set to 00:00:00:00:00:01 and showing everything else okay (version 5.9.1 - OS 14.1). So I opened a ticket and Michel jump on it right away (really great folks at UD), he gave me few instructions and then did gotosupport session. He said that the POLISY did not complete the upgrade and he did everything manually. We spent about 20-30mins on the session and all is good after that. Then I did a couple of reboot to make sure it's booting up properly before I shut it down and it did and run my eISY up again without any issues on all my devices and 3rd party integration. But here's my experience so far on eISY. The next morning, most of my main lights are on (Insteon, z-wave, and wemo). I just turn them off and decided to monitor it for now. But today (3rd day), my z-wave and zigbee devices were not responding and found out that both are not working (clicking on the Z-Wave and Zigbee menu and only saw something in line "not responding"). I restarted eISY and all devices are functioning well again. Let see what happens tomorrow. Anyone had/having a bizarre experience after upgrading to 5.9.1? Thank you! Edited February 25Feb 25 by JCS
February 26Feb 26 On 2/24/2025 at 7:25 AM, DennisC said: How have you tried to update? By clicking the Upgrade Packages button under the System tab. I'm currently on firmware 5.8.4, an OS 13.2
February 26Feb 26 9 hours ago, jaysmc said: By clicking the Upgrade Packages button under the System tab. I'm currently on firmware 5.8.4, an OS 13.2 If you power cycle eisy and the upgrade button still doesn't work to upgrade you, you can try using the multifunction button. Look in the wiki for the correct number of presses of the button. If that still doesn't work, it would be best to open a support ticket.
February 28Feb 28 Hey All. I've been waiting/watching how things are going for the rest of you before pulling the trigger on this update. I'm running a Polisy with the Zmatter board installed. For those of you with Polisy's that had upgrade issues, did UDI determine if there was a common cause or a missing prerequisite?
February 28Feb 28 If a common cause was identified, it wasn't mentioned here... But it's interesting that only some Polisys got bricked, and no eisys as far as I know.
February 28Feb 28 1 hour ago, bcdavis75 said: For those of you with Polisy's that had upgrade issues, did UDI determine if there was a common cause or a missing prerequisite? As @Guy Lavoie says I think there might have been something (perhaps) internally that UD found a connection, but no users here have said what was their common link. The basic thing is more or less have you kept your Polisy up to date or has it stayed on a very old version of something? I don't personally have a Polisy, but was helping with one before this release to at least get it up to current release to be ready for the update and it bricked. It was a very early Polisy build. If you're concerned I would suggest possibly opening a support ticket to ask UD directly if they knew/determined what the common thread is and possibly review your system or give you the processes to review your system to see if it would be at risk. Some that seemed to have a bricked device appear to have a way to resolve it. At that point it becomes a situation of if you've got the pieces and experience to fix the device. Support ticket: https://www.universal-devices.com/my-tickets
February 28Feb 28 I had one of the early release polisys. IIFC there was an early BIOS chip that had to be udated. UDI spec'd a microSSD to USB interface and gave me an image to update the BIOS, and I still run my polisy with the latest updates. IIRC the USB/microSSD adapter cost about $9 on amazon.com.
March 1Mar 1 On 2/17/2025 at 10:09 AM, kzboray said: The second and third Polisy I upgraded went a lot faster. Both units started OS 13.2 AC 5.8.4. This time I run AC => upgrade and waited until the Polisy was visible in AC again. Unlike the first unit, they both after about 10 minutes showed up in AC again. They still showed AC 5.8.4 and OS 13.2 so then I pushed the front panel button ONE time and with both units all the front lights started flashing as they should during an upgrade, this lasted for about 10 minutes and then the units rebooted and were running OS 14.1 and AC 5.9.1. THIS IS NOT THE APPROVED METHOD OF UPGRADE. It's just my experience. On 2/16/2025 at 10:28 PM, xlurkr said: Polisy is so....interesting. This morning, after letting it sit overnight doing an "upgrade" (no beeps, no AC disconnect, no flashing LEDs) I checked the status. Still 13.1. I rebooted, and when it came back I launched yet another upgrade attempt. This time, it worked. Beeped, AC disconnect, and LEDs started flashing. About 30 minutes later, it was done. 14.1. Catching up on this thread, I realize that I never finished my story. My second unit's upgrade, which was the one in service and which had therefore been kept up to date (5.8.4 13.2) went 100% smoothly. I didn't have to anything beyond pushing the upgrade packages button in the AC and waiting about 10-20 minutes. -Tom
March 1Mar 1 3 hours ago, larryllix said: I had one of the early release polisys. I pre-ordered my Polisy as soon as they were announced. I would imagine it was as early of a release as any. No BIOS updates for me, as far as I know (though there was a session I had with UD where they did a lot of fixing of things that I was unable to follow...perhaps they loaded this BIOS?). No problem since, including uneventful update. I have updated all the UD Mobile apps I have on android and iOS devices. I have synced them all. Everything that I see and can recognize suggests that matter is incorporated and active. I have yet to have, or have read about, a successful addition of a matter device into iOX. Edited March 1Mar 1 by oberkc
March 1Mar 1 I also had an early-release Polisy. It required some UD support sessions to get it running initially - I had waited a couple of years from when I purchased it to actually turning it on. I was fully up to date (5.8.4 and 13.2) when I attempted the upgrade. It totally bricked. Used the usb adaptor to reflash the ssd which brought it back to limping mode. Required a few hours of Michel’s magic to get it fully running and upgraded.
March 2Mar 2 I'm happy to report that after working up the courage ( and making ample backups), I pulled the trigger and the upgrade appears to to have worked without a hitch. This has however led to a number of other questions: 1) I now see the ability to add matter devices via the ios app with a QR code. I might be wrong but I beleive if a matter devices has already been added to Apple Home, for example, adding it to another controller is done by using a code. I'm not seeing a way to do that that though. Am I missing it? 2) I see the matter menu in the admin console now. Is there an explanation of what these menu items actually do and when to use them?
March 3Mar 3 On 3/2/2025 at 3:03 PM, bcdavis75 said: This has however led to a number of other questions: @bcdavis75 probably best to start your questions in the ZMatter area of the forum rather than "hidden" in the support thread for 5.9.1. Glad the update went well.
March 4Mar 4 On 3/2/2025 at 3:03 PM, bcdavis75 said: Am I missing it? I don't see a way to add a matter device to UDMobile via code...only by QR. Sharing from google home can provide a QR code, but Alexa does not. I don't see how apple does it, but I do not have an apple matter router. I have hear someone found a way to convert a numeric code into a QR code. Regardless of all this, I don't believe the UDMobile app is working yet WRT adding matter devices.
March 4Mar 4 You can create a QR code here: https://qrfy.com/?utm_source=Google&utm_medium=CPC&utm_campaign=17317470455&utm_term=make a qr code free online&gad_source=1&gclid=CjwKCAiA5pq-BhBuEiwAvkzVZfy_UW8SDHl3_jj1ioTPcJ5J-vaRQYxDKxsh6VysN1mk_7Pd19OsphoCPfQQAvD_BwE Just choose "text" and enter the code as text, as I've done here:
March 4Mar 4 3 hours ago, Guy Lavoie said: You can create a QR code here: Very cool thanks! So has anyone had any success actually adding a matter device? I've attempted to add several deviced using a QR code but I always get an error.
March 4Mar 4 Just now, bcdavis75 said: I've attempted to add several deviced using a QR code but I always get an error. Join the club. If anyone has had success, they haven't said so here.
March 4Mar 4 4 hours ago, Guy Lavoie said: You can create a QR code here: https://qrfy.com/?utm_source=Google&utm_medium=CPC&utm_campaign=17317470455&utm_term=make a qr code free online&gad_source=1&gclid=CjwKCAiA5pq-BhBuEiwAvkzVZfy_UW8SDHl3_jj1ioTPcJ5J-vaRQYxDKxsh6VysN1mk_7Pd19OsphoCPfQQAvD_BwE Just choose "text" and enter the code as text, as I've done here: Oops, look like I got ahead of myself. The QR code isn't just an encoding of the PIN code. Other than including some additional information (Vendor ID and product ID) there is also Base38 encoding. Detailed information here: https://www.matteralpha.com/article/how-does-matter-qr-code-work Edited March 4Mar 4 by Guy Lavoie
March 5Mar 5 I know that many folks are trying to add Matter device on eISY but how about seeing eISY devices (Insteon) in Apple Home App? I saw a video of this on the news page.
March 5Mar 5 Updated my Polisy today, which was at latest I could get before this update, i.e. 13.2 and 5.8.4, and it worked fine. I was an early buyer of the Polisy but I went through the pain of getting updated BIOS, etc. some time ago. I made some popcorn and watched it happening in real time by opening a Putty session and typing in: sudo tail -f /var/udx/logs/log It did appear to skip some things (like OS upgrade) the first time around to do some other things first then go back to do the things it skipped, with long pauses along the way so that's why I guess it takes a while. Guessing 15 mins in my case. I saw a lot of messages about things not needed or up to date, so that helped timewise in this case.
March 6Mar 6 3 hours ago, JCS said: I know that many folks are trying to add Matter device on eISY but how about seeing eISY devices (Insteon) in Apple Home App? I saw a video of this on the news page. I think you're expecting too much, too soon. The release notes say "installs HomeKit plumbing," not HomeKit itself, similar to the way it says "installs eisyui plumbing," not eisyui (presumably the forthcoming browser-based UI).
March 6Mar 6 17 hours ago, GHenry said: I think you're expecting too much, too soon. The release notes say "installs HomeKit plumbing," not HomeKit itself, similar to the way it says "installs eisyui plumbing," not eisyui (presumably the forthcoming browser-based UI). Homekit support was supposed to come out “next week” last month. Edited March 6Mar 6 by brians
March 8Mar 8 Any word on HomeKit? Just upgraded to eisy and purchased an Apple TV in preparation of the integration… Edited March 8Mar 8 by superjuice
