Tuesday at 02:06 PM3 days That release announcement sure caught my attention! Let's discuss it, and indicate how our own upgrades went. I haven't taken the plunge yet myself. Looks like this is the version where eisy-ui becomes fully functional. The release notes raise several questions that come to mind:It starts with "We're happy to announce the availability of OS14.4, IoX 6.1.1, UDX 5.0, and eisy-ui 1.2.0 for eisy (only)". Does this mean that the whole upgrade is for the eisy only, or just eisy-ui? Farther down it does mention that you need to be local to your eisy/Polisy, so I'm wondering if the Polisy is supporting this upgrade. There is a link showing the supported Zwave and Zigbee dongles. The ZMatter dongle isn't listed, but I'm hoping that's just an omission. Similarly, is the Zooz 700 series dongle still supported?
Tuesday at 02:36 PM3 days I'm ready to do this, but don't want to be the first. Yeah, call me chicken but ask me why! 😁
Tuesday at 02:53 PM3 days Upgraded to the new release with no apparent problems. Logged into the EISY-UI without any problem. All Insteon, Z-Wave, and Zigbee, and PG3 nodes appear to be working. Successfully edited and saved one program using the EISY-UI.Problem: Although clicking the Admin Console button downloads a new admin.jnlp file, I get an error that Admin Console v.6.0.4 is not compatible with IoX Firmware v6.1.1 RC
Tuesday at 03:01 PM3 days @aeroRC did you delete files and apps from the java console first? that should clear up that problem.I upgraded this morning. pretty much every program within the updated eisy-ui shows "Error loading data". However, the same programs appear to be fine within the AC. I have submitted a new ticket for guidance.Rob
Tuesday at 03:07 PM3 days Rob, deleting the apps from the java console fixed the problem. Thanks for the tip!I have not had any problems with seeing and editing my programs so far.RC
Tuesday at 03:45 PM3 days In testing UD Mobile, the Synchronization finishes with Insteon errors " with "...could not match CMD paramName: ______". The paramNames that could not be matched were: VAL-NAME, MAX-NAME, MIN-NAME, START-NAME, BRT-NAME, RR-NAME, ON-NAME, and OFF-NAME.RC
Tuesday at 03:50 PM3 days Upgraded from the Admin Console.Admin Console logging in without issues. I did delete files and apps from java console before hand.UI looks good. Programs are working correctly.UD Mobile Sync is working without errors. All looks good there.Automations between Eisy and Home Assistant are working as before... So far looking really good. Edited Tuesday at 03:54 PM3 days by MWasson
Tuesday at 03:51 PM3 days 56 minutes ago, aeroRC said:Upgraded to the new release with no apparent problems.Did you upgrade via the admin console or from the EISYUI?My EISYUI says I'm up to date for some reason.Thanks!
Tuesday at 03:58 PM3 days Upgrade itself seemed to go smooth but after finishing and rebooting, my eISY UI customized Home Page is gone. Any way to get that back without re-creating it?
Tuesday at 03:59 PM3 days Anyone have opinion of how long this update is suppose to take, My UD Mobile still says Upgrade Status "Upgrade in Progress! Please Do not power off. " after Upgrade stared 2-1/2 hours ago using Addin console.
Tuesday at 04:00 PM3 days 7 minutes ago, mmb said:Did you upgrade via the admin console or from the EISYUI?My EISYUI says I'm up to date for some reason.Thanks!Instructions clearly state update from AC. The EISYUI upgrade path is not mentioned...Back up your Z-Wave network, if applicable (Z-Wave | Backup)Back up your IoX (File | Backup IoX)Back up your PG3Click Upgrade Packages in Admin Console | Configuration tab2 minutes ago, RP_NY said:Anyone have opinion of how long this update is suppose to take, My UD Mobile still says Upgrade Status "Upgrade in Progress! Please Do not power off. " after Upgrade stared 2-1/2 hours ago using Addin console.Did you close the app and relaunch (forcing it to reconnect to the EISY)?
Tuesday at 04:08 PM3 days Did you close the app and relaunch (forcing it to reconnect to the EISY)? NO,
Tuesday at 04:25 PM3 days @RP_NY Just started the upgrade 40 minutes ago.... my notifications in UDMobile are a bit different. Looks like they progressed where as you did not?
Tuesday at 04:28 PM3 days Thanks for the Info. Since the UD Mobile did not state "Initializing" my guess is the upgrade never started.
Tuesday at 04:40 PM3 days 40 minutes ago, RP_NY said:Upgrade stared 2-1/2 hours ago using Addin consoleAs the release notes say if you haven't had the system come back yet please open a support ticket. https://www.universal-devices.com/my-tickets If your eisy does not come back online within 2 hours, please submit a support ticket
Tuesday at 04:44 PM3 days Not a great experience here. Did the backups.Ran "Update Packages" from the Configuration tab of the Admin Console.Admin console and firmware seemed to update from 6.0,5 to 6.1.1 without issue, and it instructed be to reboot the system. But...eisy-ui is nowhere to be found. PG3 interface report errors that it is not connected to the server.my.isy.io says that my device (eisy R2) is not online.oi...
Tuesday at 04:58 PM3 days After upgrading, the Synchronization with UD Mobile (iOS) produces these errors. However, all the Insteon nodes show up and appear to be fully functional.RC
Tuesday at 05:03 PM3 days Not great for me either. Admin Console appeared to be locked up. Waited a little over an hour. Checked the monitor connected to EISY and nothing appeared to be happening so I restarted it. Everything came back up and I can control things from the admin console, but the EISY-UI doesn't work and the ISY portal shows me offline.Update: Contacted support. The update program was just modified to correct my issue. I re-ran the update and everything is working fine now. Thank you support team! Edited Tuesday at 06:49 PM3 days by JPizzo Update to status
Tuesday at 05:21 PM3 days Upgraded earlier and now have no access via eisy.local or admin console.Ticket submitted.
Tuesday at 05:34 PM3 days Could someone please expand on this requirment for the upgrade ?"remote from your eisy > means not on the same LAN segment or physically not in front of you on the desk connected to a monitor ?Do not attempt the upgrade if you are remote from your eisy/polisy and/or using ISY Portal
Tuesday at 05:41 PM3 days Author Basically, don't do this from any type of remote access. Do the upgrade from Admin Console, on a computer that's in the same physical location and on the local network, such that you can restart the eisy by power cycling if necessary. This avoids any issues that could be dependant on remote access authentication, etc. Edited Tuesday at 05:43 PM3 days by Guy Lavoie
Tuesday at 06:06 PM3 days Thank you Guy Do the upgrade from Admin Console, on a computer that's in the same physical location and on the local network
Tuesday at 06:08 PM3 days Because I can: here is a ChatGPT summary so far: 🤓I reviewed the thread through the comment you linked. The reports are fairly mixed: 3 clearly successful, 4 with significant issues, and 2 successful upgrades with warnings/secondary issues.IoX 6.1.1 upgrade resultsUserUpgrade resultStatusIssues / warnings reportedMWassonSuccessful🟢 SuccessfulAdmin Console, eisy-ui, programs, UD Mobile Sync, and Home Assistant automations all working. Cleared Java files/apps beforehand. UUniversal Devices ForummmbSuccessful🟢 SuccessfulExplicitly reported: “Upgrade went well, no issues.” UUniversal Devices ForumaeroRCSuccessful🟡 Successful + warningsInsteon/Z-Wave/Zigbee/PG3 and eisy-ui worked. Initially Admin Console showed a 6.0.4 incompatibility, fixed by deleting Java files/apps. UD Mobile sync subsequently showed Insteon parameter-name errors, although the nodes remained functional. UUniversal Devices ForumGreg P.Upgrade completed🟡 Successful + warningUpgrade itself was smooth, but the customized eisy-ui Home Page disappeared after reboot. UUniversal Devices ForumRRalstonUpgrade completed🔴 IssuesNearly every program in eisy-ui displayed “Error loading data,” although the same programs worked correctly in Admin Console. Ticket submitted. UUniversal Devices ForumRP_NYProblem during upgrade🔴 Issues / possibly didn't startUD Mobile remained at “Upgrade in Progress” for 2½ hours. Later suspected the upgrade never actually started because the expected “Initializing” notification wasn't seen. UUniversal Devices Forumsteveng57Partial upgrade🔴 Major issuesFirmware/Admin Console appeared to reach 6.1.1, but eisy-ui disappeared, PG3 reported it wasn't connected, and my.isy.io showed the eisy offline. UUniversal Devices ForumJPizzoUpgrade/reboot completed🔴 Major issuesAdmin Console appeared locked for >1 hour; after restarting eisy, Admin Console worked, but eisy-ui didn't and ISY Portal showed offline. UUniversal Devices ForumBlackSheepUpgrade completed🔴 Major issueLost access through both eisy.local and Admin Console; support ticket submitted. UUniversal Devices ForumAt-a-glanceCategoryUsersCount🟢 No issues reportedMWasson, mmb2🟡 Basically successful, but warning/cleanup neededaeroRC, Greg P.2🔴 Significant problemsRRalston, RP_NY, steveng57, JPizzo, BlackSheep5Total users who reported an upgrade attempt9My takeaway: At the point captured by this thread, only 2 of 9 users reported a completely clean upgrade. Another 2 got through successfully but encountered UI/UD Mobile issues. 5 had substantial problems, including several losing eisy-ui, portal connectivity, or Admin Console access. UUniversal Devices ForumOne important caveat: this is a snapshot of the thread at the time you linked, not necessarily the final outcome of each incident. For example, some of the problems may subsequently have been resolved through support.Also, the thread's author clarifies an important upgrade precaution: perform the upgrade locally from Admin Console, on the same LAN, with physical access to the eisy so it can be power-cycled if necessary.
