Tuesday at 06:52 PM4 days Just did the upgrade (insteon, zwave, plugins). Everything went fine. No issues.Gary
Tuesday at 07:56 PM4 days @JimTurner It's possible that Java ran out of memory, try either increasing the Java memory allocation or deleting part of your log file
Wednesday at 06:27 PM3 days My first eisy upgraded without any issues, following the upgrade procedure. The second eisy completed the upgrade, but after two reboots, eisy.ui was reported as not found. After performing 6x presses of the multifunction button to shut down the eisy, pulling and reconnecting power, the eisy booted fine and eisy.ui is now accessible.
Thursday at 07:55 PM2 days Just did an update packages from eisy ui. It seemed to go fine, didn't take terribly long. Though I needed to restart all my plugins after the update. Something I hadn't seen before is that opening the admin console told me that iox finder was on the new version and iox was still on the old (6.1.1/6.1.2) It asked if I wanted to update iox, I said yes. I was then able to immediately re-open the admin console, so I don't know what update happened, couldn't have ben much in that ime. I have seen the opposite of that message before where I had to clear out Java. I believe this is the first time I have updated from the eisy upgrade packages vs the admin console trigger, not sure what if anything that changes.
Friday at 01:02 AM2 days That is interesting, I had to clear java as usual...I updated about a week ago, with no issues.
Friday at 01:16 AM2 days Author 5 hours ago, apostolakisl said:Just did an update packages from eisy ui. It seemed to go fine, didn't take terribly long. Though I needed to restart all my plugins after the update. Something I hadn't seen before is that opening the admin console told me that iox finder was on the new version and iox was still on the old (6.1.1/6.1.2) It asked if I wanted to update iox, I said yes. I was then able to immediately re-open the admin console, so I don't know what update happened, couldn't have ben much in that ime. I have seen the opposite of that message before where I had to clear out Java. I believe this is the first time I have updated from the eisy upgrade packages vs the admin console trigger, not sure what if anything that changes.What version did you upgrade from?
Friday at 02:12 PM1 day Just updated. Took about 15 minutes from start to reboot! First look at programs in eisy-ui looks good. Great job UD team!
Friday at 02:36 PM1 day 13 hours ago, Guy Lavoie said:What version did you upgrade from?6.1.1-6.1.2 Edited Friday at 02:37 PM1 day by apostolakisl
Friday at 04:12 PM1 day 59 minutes ago, hart2hart said:ARe you using the Staging Repo?Not sure what that is.
Friday at 04:26 PM1 day In the new eisl-ui, there are 3 update repositories. Production, Beta, and Staging. This give UD the ability to tell you they could use your help or you need a feature/fix not yet ready for all users the Beta level or in rare cases the Staging level. The reason I asked is the 6.1.2 only shows under the Staging level from my view.
Friday at 08:11 PM1 day On 8/24/2026 at 1:54 PM, Sticklizard said:I'm glad to finally see the web UI gain access to programs and better access to devices/scenes. I do have some trouble reading the screen due to recent eye surgery. I can magnify but many of the colors are too dim on my display to be read easily.Try changing to light mode Alt + t. (theme)
Friday at 08:12 PM1 day Upgrade failed, and I'm still on 6.0.5From the AC, I clicked to "upgrade packages" then went to SSH to look at the logs, as it was over an hour and nothing seemed to be happening.I am running I0X 6.0.5_10, and the /var/log/messages shows that only one file updated:polisy pkg[17912]: udx upgraded: 4.5.0_7 -> 5.0.0I rebooted my Polisy, waited until everything finished discovering (20 min), and then clicked to Upgrade Packages again, this time IoX presented a different message: (see attached file)I accepted by clicking Yes, and after 90 minutes, still no activity in the /var/log/messages file.I rebooted a second time, and click again to upgrade, no difference, nothing is upgrading according to the /var/log/messages fileThoughts?
Friday at 08:29 PM1 day Author A Polisy won't upgrade from a menu. You need to do it from the command line, using ssh.sudo pkg upgrade udx isy eisyui pg3xThis is explained earlier in this thread.
Friday at 08:38 PM1 day When I go to SSH and issue:sudo pkg upgrade udx isy eisyui pg3xI supply my admin credentials, and then SSH shows"No repositories are enabled"Figured it out, I had to issue: sudo repo.util prod to first activate the repository.Upgrade went fine after that, and all is working including integration to Home Assistant. Appreciate the support from this forum. Edited Friday at 09:06 PM1 day by Peter Henneberry
Friday at 10:55 PM1 day 2 hours ago, Guy Lavoie said:A Polisy won't upgrade from a menu. You need to do it from the command line, using ssh.sudo pkg upgrade udx isy eisyui pg3xThis is explained earlier in this thread.Yes, I noticed that a few days ago on a minor update. It did nothing. I can select the repository and look at the updates, but the button doesn’t do anything. I wonder why they can’t make that work. I guess we’re fortunate enough to have a polisy version though.
Friday at 11:21 PM1 day Author 20 minutes ago, brians said:Yes, I noticed that a few days ago on a minor update. It did nothing. I can select the repository and look at the updates, but the button doesn’t do anything. I wonder why they can’t make that work. I guess we’re fortunate enough to have a polisy version though.UDI did signal last January that support for the Polisy would be in a maintenance mode, meaning that updates would continue as long as they were feasable, but if any new eisy features aren't possible on the Polisy for whatever reason (such as the operating system version) then so be it. Some people are still using their isy994i, so the Polisy probably still has a lot of life left in it, unless you want the absolute latest in performance.
Friday at 11:48 PM1 day my polisy after update and reboot via ssh didn't come back.. this happened before last time and had to hard power it... will do when I am at home...
Yesterday at 12:08 AM1 day I'd like to hijack this thread and tease you with our upcoming feature: eisy-ai !With kind regards,Michel
Yesterday at 12:22 AM1 day 31 minutes ago, brians said:my polisy after update and reboot via ssh didn't come back.. this happened before last time and had to hard power it... will do when I am at home...Some here may not like this, but I bought one of these https://a.co/d/048nO7yN from Amazon. I can do a power off / on remotely if absolutely necessary. $23
Yesterday at 12:42 AM1 day Author Ah yes, in that case do34 minutes ago, Michel Kohanim said:I'd like to hijack this thread and tease you with our upcoming feature: eisy-ai !With kind regards,MichelA new buzzword is born: eisy-ai clever!
Yesterday at 01:16 AM1 day 18 minutes ago, JimTurner said:Some here may not like this, but I bought one of these https://a.co/d/048nO7yN from Amazon. I can do a power off / on remotely if absolutely necessary. $23Yes I have several solutions for that but too lazy to implement LOL. But a good idea.and look after a hard reboot is up again and updated ;)
Yesterday at 03:18 AM1 day I waited a little, but the upgrade took less than 15 minutes and things look good. I upgraded to an SSD earlier this year and the speed seems evident upgrading to OS 14.4.I haven't dug into everything yet but Hue, Insteon, Yolink, Schlage, and ZWave shades work LiFX may have finally died and I only have 5 devices left because the plugin is no longer supported.[UPDATE]: Had to run Upgrade Dev Packages twice and LIFX is working again!ERROR udi_interface:write: Traceback (most recent call last):ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b902615e_5/lifx-poly.py", line 10, in <module>ERROR udi_interface:write: import lifxlanERROR udi_interface:write: ModuleNotFoundErrorERROR udi_interface:write: :ERROR udi_interface:write: No module named 'lifxlan' Edited yesterday at 03:53 AM1 day by JRissmiller
Yesterday at 04:22 AM1 day Every time I log in I am told there is an upgrade to install. However, it does not appear that this is the case.
