10 hours ago10 hr Author 7 minutes ago, Michel Kohanim said:@Guy Lavoie , ah, wrong wording. It will work with all supported Zigbee dongles including ZMatter USB.With kind regards,MichelHmm, it's not. I only get on/off control.
10 hours ago10 hr Author 2 minutes ago, Michel Kohanim said:@Guy Lavoie , did you remove and then add it back?With kind regards,MichelYes, and also tried adding two other modules that had never been added before. Same result.
9 hours ago9 hr Does 6.1.1 fully support Zwave LRUpdate went smoothly, no problemsRe : Where to buy the Zooz Zwave dongle, add https://www.thesmartesthouse.comTheir price is lower than Amazon
9 hours ago9 hr 10 minutes ago, Guy Lavoie said:Yes, and also tried adding two other modules that had never been added before. Same result.I don't know what to say. Are these thirdreality switches? I have one right here:8 minutes ago, Techman said:Does 6.1.1 fully support Zwave LRUpdate went smoothly, no problemsRe : Where to buy the Zooz Zwave dongle, add https://www.thesmartesthouse.comTheir price is lower than AmazonYes in the code but LR requires UI changes that didn't make the cut due to not being fully tested. Same as i3 keypad load button assignment.We should have another build shortly that includes both LR as well as i3 keypad load button assignment.With kind regards,Michel
9 hours ago9 hr Author 2 minutes ago, Michel Kohanim said:I don't know what to say. Are these thirdreality switches? I have one right here:Yes in the code but LR requires UI changes that didn't make the cut due to not being fully tested. Same as i3 keypad load button assignment.We should have another build shortly that includes both LR as well as i3 keypad load button assignment.With kind regards,MichelMine are Enbrighten (Jasco) ZB4103 (as indicated in the Zigbee thread). They are the ones that generated the cluster information I sent you in March. I also have a GE branded one (ZB4101) that seems to also be a rebranded Jasco.
9 hours ago9 hr 2 minutes ago, Guy Lavoie said:Mine are Enbrighten (Jasco) ZB4103 (as indicated in the Zigbee thread). They are the ones that generated the cluster information I sent you in March. I also have a GE branded one (ZB4101) that seems to also be a rebranded Jasco.They probably don't report energy cluster. You can use Zigbee menu | Capture Log | Start and remove/add them again. You should see energy cluster reported if they support it.With kind regards,Michel
9 hours ago9 hr Author 2 minutes ago, Michel Kohanim said:They probably don't report energy cluster. You can use Zigbee menu | Capture Log | Start and remove/add them again. You should see energy cluster reported if they support it.With kind regards,MichelOk, let me try that and a few more things. Thanks!
8 hours ago8 hr Nice work on the update. Updated tonight in probably ~20 minutes. I wasn't watching it like a hawk, but started the process about just after 5pm and was rebooted and back into the system by 5:40. The web UI is a nice update to have. Looking forward to how it continues to develop. I'll be one (of the few) that will miss the java admin console if/when it's officially not available. It's so reliable. 😉Nice work UD team!
6 hours ago6 hr 9 minutes ago, JSchumann said:So remove the @ from email addresses? Then put them back in?The "&" in the resource name. The admin Console does not encode them, which causes issues in xml parsers.
6 hours ago6 hr 10 hours ago, Michel Kohanim said:sudo pkg upgrade udx isy eisyui pg3xI get "No repositories are enabled." Context: attempting to upgrade on a Polisy.-Tom
5 hours ago5 hr Author 35 minutes ago, xlurkr said:I get "No repositories are enabled." Context: attempting to upgrade on a Polisy.-TomThat's odd. Were you previously updated to 6.0.5? Try this: try the usual upgrade procedure first within Admin Console (Upgrade Packages), this might enable something. The upgrade itself should fail, as per the log file will show you. Then try the upgrade again with the command line method. Remember the release announcement warning:If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system.
1 hour ago1 hr @Michel Kohanim That was the trick. I typed "sudo repo.util staging" and then repeated your "pkg upgrade ..." and it worked. It did not upgrade udx, which is on version 5.0.0. I hope that's correct. Also, please let me know if this repo.util command has any other side effects. I'm a total FreeBSD noob.-Tom
1 hour ago1 hr @xlurkr ,The repos are locked for polisy. So, next time you need to upgrade, just repeat the same command and use prod. Again, this only temporarily unlocks the repo (till next boot). No other side effects.
